mmpm connection to MagicMirror failed
9 Posts 2 Posters 1.6k Views 2 Watching
  • K Offline
    Kab
    Hi all,
    I just started using MagicMirror and wanted to use the package manager mpmm with it.
    • MagicMirror has been installed via the MagicMirrorOS on a RaspberryPi
    • I can see the MagicMirror output on the screen connected to the Pi and via the URL (192.168.2.76:8080)
    • I installed mpmm via
    sudo apt install libffi-dev nginx-full -y
    python3 -m pip install --upgrade --no-cache-dir mmpm
    mmpm --guided-setup
    echo 'export PATH="$PATH:$HOME/.local/bin"' >> ~/.bashrc
    • I can access the mpmm GUI but it is showing “Unable to retrieve active modules”
    • my mmpm settings are:
        MMPM_IS_DOCKER_IMAGE: false
        MMPM_MAGICMIRROR_DOCKER_COMPOSE_FILE: /home/pi/magicmirror/run/docker-compose.yml
        MMPM_MAGICMIRROR_PM2_PROCESS_NAME:
        MMPM_MAGICMIRROR_ROOT: /home/pi/magicmirror
        MMPM_MAGICMIRROR_URI: http://192.168.2.76:8080
    Alsp a mmpm mm-ctl --status shows that it failed to connect to MagicMirror. At least I am not aware that I use pm2.
    The mmpm log file shows a Connection to namespace /mmpm was rejected:
    Back up of database complete
    2021-10-28 00:23:57,221.221 INFO core - display_magicmirror_modules_status: attempting to connect to '/mmpm' namespace within MagicMirror websocket
    2021-10-28 00:23:57,273.273 INFO client - _handle_eio_connect: Engine.IO connection established
    2021-10-28 00:23:57,311.311 INFO client - _handle_error: Connection to namespace /mmpm was rejected
    2021-10-28 00:23:58,315.315 INFO client - _handle_eio_disconnect: Engine.IO connection dropped
    2021-10-28 00:23:58,328.328 ERROR utils - error_msg: Failed to connect to MagicMirror, closing socket. Is MagicMirror running?
    2021-10-28 00:23:58,330.330 ERROR core - display_magicmirror_modules_status: One or more namespaces failed to connect
    2021-10-28 00:23:58,332.332 INFO utils - socketio_client_disconnect: attempting to disconnect from MagicMirror websocket
    What could be wrong? Is the MMPM_MAGICMIRROR_ROOT correct for the MagicMirrorOS installation?
    Thanks for reading that far,
    Kab
    K 1 Reply Last reply Oct 28, 2021, 6:31 PM Reply Quote 0
    • K Offline
      karsten13 @Kab
      @kab
      you should check for errors when loading the GUI in the browser, CTRL+SHIFT+I opens then console.
      • K Offline
        Kab
        Thanks @karsten13
        MagicMirrorPackageManager
        The debug console on the mmpm shows an error that it couldn’t find a favicon and several source map Errors (as Warnings) like :
        Source-Map-Fehler: Error: request failed with status 404
        Ressourcen-Adresse: http://192.168.2.76:7890/static/assets/monaco/vs/editor/editor.main.js
        Source-Map-Adresse: ../../../min-maps/vs/editor/editor.main.js.map
        Its also the
        • assets/monaco/vs/loader.js
        • assets/monaco/vs/editor/editor.main.js
        • assets/monaco/vs/editor/editor.main.nls.js
        • assets/monaco/vs/base/worker/workerMain.js#editorWorkerService
        • assets/monaco/vs/base/worker/workerMain.js#json
        with the same Warnings. Plus it complains about the zoom property.
        MagicMirror
        On the MagicMirror site it shows
        GEThttp://192.168.2.76:8080/modules/mmpm/mmpm.js
        [HTTP/1.1 404 Not Found 16ms]
        Die Ressource von "http://192.168.2.76:8080/modules/mmpm/mmpm.js" wurde wegen eines MIME-Typ-Konfliktes ("text/html") blockiert (X-Content-Type-Options: nosniff).
        192.168.2.76:8080
        Error on loading script: modules/mmpm/mmpm.js
        onerror http://192.168.2.76:8080/js/loader.js:194
            (Async: EventHandlerNonNull)
            loadFile http://192.168.2.76:8080/js/loader.js:193
            loadModule http://192.168.2.76:8080/js/loader.js:140
            loadNextModule http://192.168.2.76:8080/js/loader.js:27
            loadNextModule http://192.168.2.76:8080/js/loader.js:29
            afterLoad http://192.168.2.76:8080/js/loader.js:130
            bootstrapModule http://192.168.2.76:8080/js/loader.js:166
            loadTranslations http://192.168.2.76:8080/js/module.js:316
            bootstrapModule http://192.168.2.76:8080/js/loader.js:163
            loadNextDependency http://192.168.2.76:8080/js/module.js:296
            loadNextDependency http://192.168.2.76:8080/js/module.js:293
            onload http://192.168.2.76:8080/js/loader.js:210
            loadFile http://192.168.2.76:8080/js/loader.js:208
            loadFile http://192.168.2.76:8080/js/loader.js:268
            loadNextDependency http://192.168.2.76:8080/js/module.js:291
            loadDependencies http://192.168.2.76:8080/js/module.js:300
            loadStyles http://192.168.2.76:8080/js/module.js:267
            bootstrapModule http://192.168.2.76:8080/js/loader.js:161
            loadFile http://192.168.2.76:8080/js/loader.js:245
            loadScripts http://192.168.2.76:8080/js/module.js:276
            bootstrapModule http://192.168.2.76:8080/js/loader.js:159
            afterLoad http://192.168.2.76:8080/js/loader.js:129
            loadModule http://192.168.2.76:8080/js/loader.js:142
            onload http://192.168.2.76:8080/js/loader.js:190
            loadFile http://192.168.2.76:8080/js/loader.js:188
            loadTranslations http://192.168.2.76:8080/js/module.js:332
            load http://192.168.2.76:8080/js/translator.js:117
            onreadystatechange http://192.168.2.76:8080/js/translator.js:30
            loadJSON http://192.168.2.76:8080/js/translator.js:20
            load http://192.168.2.76:8080/js/translator.js:114
            loadTranslations http://192.168.2.76:8080/js/module.js:328
        and
        Template render error: (templates/module.njk) [Line 64, Column 55]
          ReferenceError: version is not defined
            t lib.js:38
            render environment.js:489
            root nunjucks.min.js line 2 > Function:256
            render environment.js:478
            render environment.js:314
            getTemplate environment.js:261
            o environment.js:273
            getSource web-loaders.js:50
            onreadystatechange web-loaders.js:74
        module.js:94:11
            getDom module.js:94
            x environment.js:20
            call browser-asap.js:48
            u browser-raw.js:52
        Does anything of this makes sense to you?
        Or can it be the installation procedure? I installed the Docker-based MagicMirrorOS. Do I need to install the mmpm also via the Docker route?
        K 1 Reply Last reply Oct 29, 2021, 5:46 PM Reply Quote 0
        • K Offline
          karsten13 @Kab
          @kab
          not really … never tested this setup.
          Would try to run with 2 containers, setup here.
          You have already all the files in ~/magicmirror/run/ folder, just save the content of docker-compose.yml (only if you changed something) and then cp ~/magicmirror/run/rpi_mmpm.yml ~/magicmirror/run/docker-compose.yml and restart the container.
          K 1 Reply Last reply Oct 29, 2021, 9:59 PM Reply Quote 0
          • K Offline
            Kab @karsten13
            Hi @karsten13
            I did the cp ~/magicmirror/run/rpi_mmpm.yml ~/magicmirror/run/docker-compose.yml and reboot but got a black screen for the MagicMirror. So I replaced docker-compose.yml by the original file and rebooted again but the screen is still black.
            I don’t know much about docker containers. I tried docker exec -it mm bash and it opened as usual.
            What else is changed after reboot with the other container?
            K 1 Reply Last reply Oct 29, 2021, 10:05 PM Reply Quote 0
            • K Offline
              karsten13 @Kab
              @kab
              nothing
              You can look into these yaml files, it`s all text.
              You can see which containers are running with docker ps and may something is in the logs docker logs mm.
              It takes some time pulling new images (this is done after a reboot).
              K 1 Reply Last reply Oct 29, 2021, 10:38 PM Reply Quote 0
              • K Offline
                Kab @karsten13
                Hi @karsten13
                docker ps shows
                CONTAINER ID   IMAGE                          COMMAND                  CREATED      STATUS          PORTS     NAMES
                04fcaa798d2e   karsten13/magicmirror:latest   "/usr/bin/tini -- ./…"   3 days ago   Up 28 minutes             mm
                and the first error in the log is
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin        /electron js/electron.js`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the magicmirror@2.17.1 start script.
                npm ERR! This is probably not a problem with npm. There is likely additional log        ging output above.
                npm ERR!     /home/node/.npm/_logs/2021-10-29T20_22_53_399Z-debug.log
                However, /home/node/.npm/_logs/2021-10-29T20_22_53_399Z-debug.log does not exist.
                K 1 Reply Last reply Oct 30, 2021, 8:13 AM Reply Quote 0
                • K Offline
                  karsten13 @Kab
                  @kab
                  the file is in the container, after executing docker exec -it mm bash you are in the container and then you should be able to see this file.
                  But the whole thing is strange.
                  You could reset the setup by
                  • stop the container: navigate to ~/magicmirror/run and run docker-compose down
                  • test there is no container running with docker ps
                  • navigate to home directory executing cd
                  • rename magicmirror folder with mv magicmirror magicmirror-old
                  • reboot your pi
                  While starting the now missing magicmirror folder will be recreated from scratch.
                  K 1 Reply Last reply Oct 30, 2021, 11:44 PM Reply Quote 0
                  • K Offline
                    Kab @karsten13
                    Hi @karsten13
                    Thanks, that helped. I could go back to the previous setup.
                    mmpm still doesn’t work, though. I think I installed it wrong but need to dig deeper.
                    If I just ssh on the PI I can use mmpm but If I go into the mm container with docker exec -it mm bash it cannot find the mmpm command. Now I need to figure out how to remove my mpmm installation.
