    MMM-Remote-Control can not turn ON monitor
    23 Posts 3 Posters 8.3k Views 3 Watching
      sdetweil @anaghd
      @anaghd i have the reverse problem… I can turn it on, but not off…
      Walmart Spectre 55in tv.
      A 1 Reply Last reply
      • A
        anaghd @sdetweil
        @sdetweil That is weird. Can you send the "sudo echo ‘standby 0’ | cec-client -s -d 1” command in terminal and turn the monitor off?
          sdetweil @anaghd
          @anaghd it does not turn off
          • A
            anaghd @sdetweil
            @sdetweil I almost know our problem has something to with the monitorStatusCommand. Both the monitorONCommand and the monitorOffCommand first get the status from the status command and then decide whether to run or not. But I don’t know how to fix this.
            Maybe @ezeholz can help here?
              sdetweil @anaghd
              @anaghd I see this
              sudo cec-client -r
              using settings from EEPROM
              No device type given. Using 'recording device'
              CEC Parser created - libCEC version 6.0.2
              no serial port given. trying autodetect:
               path:     Raspberry Pi
               com port: RPI
              opening a connection to the CEC adapter...
              DEBUG:   [             567]	Broadcast (F): osd name set to 'Broadcast'
              DEBUG:   [             568]	Open - vc_cec initialised
              DEBUG:   [             568]	logical address changed to Free use (e)
              NOTICE:  [             568]	connection opened
              DEBUG:   [             568]	<< Broadcast (F) -> TV (0): POLL
              DEBUG:   [             568]	initiator 'Broadcast' is not supported by the CEC adapter. using 'Free use' instead
              TRAFFIC: [             568]	<< e0
              DEBUG:   [             568]	processor thread started
              DEBUG:   [             569]	initiator 'Broadcast' is not supported by the CEC adapter. using 'Free use' instead
              TRAFFIC: [             569]	<< e0
              DEBUG:   [             569]	>> POLL not sent
              DEBUG:   [             569]	TV (0): device status changed into 'not present'
              DEBUG:   [             569]	registering new CEC client - v6.0.2
              DEBUG:   [             569]	SetClientVersion - using client version '6.0.2'
              NOTICE:  [             569]	setting HDMI port to 1 on device TV (0)
              DEBUG:   [             569]	<< Broadcast (F) -> TV (0): POLL
              DEBUG:   [             570]	>> POLL not sent
              DEBUG:   [             570]	SetConfiguration: double tap timeout = 200ms, repeat rate = 0ms, release delay = 500ms
              DEBUG:   [             570]	detecting logical address for type 'recording device'
              DEBUG:   [             570]	trying logical address 'Recorder 1'
              DEBUG:   [             570]	<< Recorder 1 (1) -> Recorder 1 (1): POLL
              TRAFFIC: [             570]	<< 11
              DEBUG:   [             570]	using logical address 'Recorder 1'
              DEBUG:   [             570]	Recorder 1 (1): device status changed into 'handled by libCEC'
              DEBUG:   [             570]	Recorder 1 (1): power status changed from 'unknown' to 'on'
              DEBUG:   [             570]	Recorder 1 (1): vendor = Pulse Eight (001582)
              DEBUG:   [             570]	Recorder 1 (1): CEC version 1.4
              DEBUG:   [             570]	AllocateLogicalAddresses - device '0', type 'recording device', LA '1'
              DEBUG:   [             571]	logical address changed to Recorder 1 (1)
              DEBUG:   [             571]	Recorder 1 (1): osd name set to ''
              DEBUG:   [             571]	Recorder 1 (1): menu language set to 'eng'
              DEBUG:   [             571]	GetPhysicalAddress - physical address = 1000
              DEBUG:   [             571]	using auto-detected physical address 1000
              DEBUG:   [             571]	Recorder 1 (1): physical address changed from ffff to 1000
              DEBUG:   [             571]	<< Recorder 1 (1) -> broadcast (F): physical address 1000
              TRAFFIC: [             571]	<< 1f:84:10:00:01
              NOTICE:  [             571]	CEC client registered: libCEC version = 6.0.2, client version = 6.0.2, firmware version = 1, logical address(es) = Recorder 1 (1) , physical address: 1.0.0.0, compiled on Linux-4.15.0-128-generic ... , features: P8_USB, DRM, P8_detect, randr, RPi, Exynos, AOCEC
              DEBUG:   [             571]	<< Recorder 1 (1) -> TV (0): OSD name ''
              DEBUG:   [             571]	<< Recorder 1 (1) -> TV (0): POLL
              TRAFFIC: [             571]	<< 10
              DEBUG:   [             571]	>> POLL not sent
              DEBUG:   [             571]	not sending command 'set osd name': destination device 'TV' marked as not present
              waiting for input
              DEBUG:   [             571]	<< requesting power status of 'TV' (0)
              DEBUG:   [             571]	not sending command 'give device power status': destination device 'TV' marked as not present
              the tv sees the pi connection but it is not connectable (from the TV side)
              note this is Ubuntu 21.04 on pi.
              A 2 Replies Last reply
              • A
                anaghd @sdetweil
                @sdetweil said in MMM-Remote-Control can not turn ON monitor:
                sudo cec-client -r
                No device type given. Using ‘recording device’
                CEC Parser created - libCEC version 4.0.7
                path: Raspberry Pi
                com port: RPI
                opening a connection to the CEC adapter…
                DEBUG: [ 64] Broadcast (F): osd name set to ‘Broadcast’
                DEBUG: [ 64] Open - vc_cec initialised
                DEBUG: [ 64] logical address changed to Free use (e)
                NOTICE: [ 64] connection opened
                DEBUG: [ 65] processor thread started
                DEBUG: [ 65] << Broadcast (F) -> TV (0): POLL
                DEBUG: [ 65] initiator ‘Broadcast’ is not supported by the CEC adapter. using ‘Free use’ instead
                TRAFFIC: [ 65] << e0
                DEBUG: [ 125] >> POLL sent
                DEBUG: [ 125] TV (0): device status changed into ‘present’
                DEBUG: [ 125] << requesting vendor ID of ‘TV’ (0)
                TRAFFIC: [ 125] << e0:8c
                TRAFFIC: [ 497] >> 0e:00:8c:04
                DEBUG: [ 497] marking opcode ‘give device vendor id’ as unsupported feature for device ‘TV’
                DEBUG: [ 497] expected response received (87: device vendor id)
                DEBUG: [ 497] registering new CEC client - v4.0.7
                DEBUG: [ 497] SetClientVersion - using client version ‘4.0.7’
                NOTICE: [ 498] setting HDMI port to 1 on device TV (0)
                DEBUG: [ 498] SetConfiguration: double tap timeout = 200ms, repeat rate = 0ms, release delay = 500ms
                DEBUG: [ 498] detecting logical address for type ‘recording device’
                DEBUG: [ 498] trying logical address ‘Recorder 1’
                DEBUG: [ 498] << Recorder 1 (1) -> Recorder 1 (1): POLL
                TRAFFIC: [ 498] << 11
                TRAFFIC: [ 768] << 11
                DEBUG: [ 1039] >> POLL not sent
                DEBUG: [ 1039] using logical address ‘Recorder 1’
                DEBUG: [ 1039] Recorder 1 (1): device status changed into ‘handled by libCEC’
                DEBUG: [ 1039] Recorder 1 (1): power status changed from ‘unknown’ to ‘on’
                DEBUG: [ 1039] Recorder 1 (1): vendor = Pulse Eight (001582)
                DEBUG: [ 1039] Recorder 1 (1): CEC version 1.4
                DEBUG: [ 1039] AllocateLogicalAddresses - device ‘0’, type ‘recording device’, LA ‘1’
                DEBUG: [ 1039] Recorder 1 (1): osd name set to ‘’
                DEBUG: [ 1039] Recorder 1 (1): menu language set to ‘eng’
                DEBUG: [ 1039] logical address changed to Recorder 1 (1)
                DEBUG: [ 1039] GetPhysicalAddress - physical address = 2000
                DEBUG: [ 1039] using auto-detected physical address 2000
                DEBUG: [ 1039] Recorder 1 (1): physical address changed from ffff to 2000
                DEBUG: [ 1039] << Recorder 1 (1) -> broadcast (F): physical address 2000
                TRAFFIC: [ 1040] << 1f:84:20:00:01
                NOTICE: [ 1190] CEC client registered: libCEC version = 4.0.7, client version = 4.0.7, firmware version = 1, logical address(es) = Recorder 1 (1) , physical address: 2.0.0.0, compiled on Linux-5.10.17-v8+ … , features: P8_USB, DRM, P8_detect, randr, RPi, Exynos, Linux, AOCEC
                DEBUG: [ 1190] << Recorder 1 (1) -> TV (0): OSD name ‘’
                TRAFFIC: [ 1190] << 10:47
                DEBUG: [ 1251] << requesting power status of ‘TV’ (0)
                TRAFFIC: [ 1251] << 10:8f
                TRAFFIC: [ 1478] >> 01:46
                DEBUG: [ 1478] << Recorder 1 (1) -> TV (0): OSD name ‘’
                TRAFFIC: [ 1478] << 10:47
                DEBUG: [ 1479] >> TV (0) -> Recorder 1 (1): give osd name (46)
                TRAFFIC: [ 1797] >> 01:90:00
                waiting for input
                DEBUG: [ 1797] TV (0): power status changed from ‘unknown’ to ‘on’
                DEBUG: [ 1797] expected response received (90: report power status)
                DEBUG: [ 1797] >> TV (0) -> Recorder 1 (1): report power status (90)
                TRAFFIC: [ 3104] >> 01:46
                DEBUG: [ 3104] << Recorder 1 (1) -> TV (0): OSD name ‘’
                TRAFFIC: [ 3104] << 10:47
                DEBUG: [ 3104] >> TV (0) -> Recorder 1 (1): give osd name (46)
                • A
                  anaghd @sdetweil
                  @sdetweil sorry, this is way beyond my pay grade
                    sdetweil @anaghd
                    @anaghd mine too!
                    • A
                      anaghd @sdetweil
                      @sdetweil See if this gives you any ideas. I couldn’t figure it out.
                      https://githubmemory.com/repo/Jopyth/MMM-Remote-Control/issues/178?page=1
                        sdetweil @anaghd
                        @anaghd vcgencmd turns off the hdmi port… not the monitor… and then I get an ugly no input message
                        • A
                          anaghd @sdetweil
                          @sdetweil I was wondering if we can do something similar to what they have done but modify it for cec utilities, especially in regards to the status command.
                            sdetweil @anaghd
                            @anaghd sorry don’t understand
                            if we could do something??
                            • A
                              anaghd @sdetweil
                              @sdetweil can we modify this to include cec-utility commands instead of the vcgencmd?
                              monitorStatusCommand: ‘if vcgencmd display power | grep 1 >/dev/null 2>&1; then echo true; else echo false; fi’
                                sdetweil @anaghd
                                @anaghd oh… I don’t know the module internals or config at all…
                                • A
                                  anaghd @sdetweil
                                  @sdetweil I finally have a solution that worked for me.
                                  In the node_helper.js file, there is a function with the name “monitorControl”. In there, I used 2 things as shown below. Essentially, we want it to execute both, vcgen and cec, when we turn the monitor on and off. So I added the cec command to the already existing vcgencmd command. Now it looks like this.
                                  this.thisConfig.customCommand.monitorOnCommand:
                                  “vcgencmd display_power 1 && sudo echo 'on 0 | cec-client -s -d 1”;
                                  this.thisConfig.customCommand.monitorOffCommand:
                                  “vcgencmd display_power 0 && sudo echo 'standby 0 | cec-client -s -d 1”;
                                  I did not change anything in the statusCommand part.
                                  After that, I removed the customCommands from my config so that the module uses the default commands above for turning monitor ON and Off. That worked for me. See if it works for you.
                                  S S 2 Replies Last reply
                                    sdetweil @anaghd
                                    @anaghd no, but you could have put the same strings in your custom commands
                                    • A
                                      anaghd @sdetweil
                                      @sdetweil I tried doing that initially but that did not work for me.
                                        stevegoble @anaghd
                                        @anaghd said in MMM-Remote-Control can not turn ON monitor:
                                        I am not a programmer but there seems to be a syntax error in this line of code (and the next one too). Shouldn’t there be a closing ’ after the opening 'standby ?
                                          stevegoble @stevegoble
                                          @anaghd
                                          Even adding what I think is the correct syntax I still get an error. I am having the same issue where the TV will not turn back on after it goes to “sleep”. Initially (with unmodified code), as long as it is searching for the HDMI signal it will turn the monitor back on; however, when the signal search stops these commands will not turn the TV back on.
                                          Here is the error:
                                          Whoops! There was an uncaught exception…
                                          0|mm | [01.01.2022 06:21.55.922] [ERROR]
                                          0|mm | /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:640
                                          0|mm | “vcgencmd display_power 1” && sudo echo ‘on 0’ | cec-client -s -d 1”;
                                          0|mm | ^^^^
                                            sdetweil @stevegoble
                                            @stevegoble do you have the cec code installed?
                                            do
                                            cec-client
                                            if you get command not found
                                            do
                                            sudo apt install cec-utils
