    MMM-Remote-Control can not turn ON monitor
    23 Posts 3 Posters 8.3k Views 3 Watching
      sdetweil @anaghd
      @anaghd it does not turn off
      A 1 Reply Last reply
      • A
        anaghd @sdetweil
        @sdetweil I almost know our problem has something to with the monitorStatusCommand. Both the monitorONCommand and the monitorOffCommand first get the status from the status command and then decide whether to run or not. But I don’t know how to fix this.
        Maybe @ezeholz can help here?
          sdetweil @anaghd
          @anaghd I see this
          sudo cec-client -r
          using settings from EEPROM
          No device type given. Using 'recording device'
          CEC Parser created - libCEC version 6.0.2
          no serial port given. trying autodetect:
           path:     Raspberry Pi
           com port: RPI
          opening a connection to the CEC adapter...
          DEBUG:   [             567]	Broadcast (F): osd name set to 'Broadcast'
          DEBUG:   [             568]	Open - vc_cec initialised
          DEBUG:   [             568]	logical address changed to Free use (e)
          NOTICE:  [             568]	connection opened
          DEBUG:   [             568]	<< Broadcast (F) -> TV (0): POLL
          DEBUG:   [             568]	initiator 'Broadcast' is not supported by the CEC adapter. using 'Free use' instead
          TRAFFIC: [             568]	<< e0
          DEBUG:   [             568]	processor thread started
          DEBUG:   [             569]	initiator 'Broadcast' is not supported by the CEC adapter. using 'Free use' instead
          TRAFFIC: [             569]	<< e0
          DEBUG:   [             569]	>> POLL not sent
          DEBUG:   [             569]	TV (0): device status changed into 'not present'
          DEBUG:   [             569]	registering new CEC client - v6.0.2
          DEBUG:   [             569]	SetClientVersion - using client version '6.0.2'
          NOTICE:  [             569]	setting HDMI port to 1 on device TV (0)
          DEBUG:   [             569]	<< Broadcast (F) -> TV (0): POLL
          DEBUG:   [             570]	>> POLL not sent
          DEBUG:   [             570]	SetConfiguration: double tap timeout = 200ms, repeat rate = 0ms, release delay = 500ms
          DEBUG:   [             570]	detecting logical address for type 'recording device'
          DEBUG:   [             570]	trying logical address 'Recorder 1'
          DEBUG:   [             570]	<< Recorder 1 (1) -> Recorder 1 (1): POLL
          TRAFFIC: [             570]	<< 11
          DEBUG:   [             570]	using logical address 'Recorder 1'
          DEBUG:   [             570]	Recorder 1 (1): device status changed into 'handled by libCEC'
          DEBUG:   [             570]	Recorder 1 (1): power status changed from 'unknown' to 'on'
          DEBUG:   [             570]	Recorder 1 (1): vendor = Pulse Eight (001582)
          DEBUG:   [             570]	Recorder 1 (1): CEC version 1.4
          DEBUG:   [             570]	AllocateLogicalAddresses - device '0', type 'recording device', LA '1'
          DEBUG:   [             571]	logical address changed to Recorder 1 (1)
          DEBUG:   [             571]	Recorder 1 (1): osd name set to ''
          DEBUG:   [             571]	Recorder 1 (1): menu language set to 'eng'
          DEBUG:   [             571]	GetPhysicalAddress - physical address = 1000
          DEBUG:   [             571]	using auto-detected physical address 1000
          DEBUG:   [             571]	Recorder 1 (1): physical address changed from ffff to 1000
          DEBUG:   [             571]	<< Recorder 1 (1) -> broadcast (F): physical address 1000
          TRAFFIC: [             571]	<< 1f:84:10:00:01
          NOTICE:  [             571]	CEC client registered: libCEC version = 6.0.2, client version = 6.0.2, firmware version = 1, logical address(es) = Recorder 1 (1) , physical address: 1.0.0.0, compiled on Linux-4.15.0-128-generic ... , features: P8_USB, DRM, P8_detect, randr, RPi, Exynos, AOCEC
          DEBUG:   [             571]	<< Recorder 1 (1) -> TV (0): OSD name ''
          DEBUG:   [             571]	<< Recorder 1 (1) -> TV (0): POLL
          TRAFFIC: [             571]	<< 10
          DEBUG:   [             571]	>> POLL not sent
          DEBUG:   [             571]	not sending command 'set osd name': destination device 'TV' marked as not present
          waiting for input
          DEBUG:   [             571]	<< requesting power status of 'TV' (0)
          DEBUG:   [             571]	not sending command 'give device power status': destination device 'TV' marked as not present
          the tv sees the pi connection but it is not connectable (from the TV side)
          note this is Ubuntu 21.04 on pi.
          A 2 Replies Last reply
          • A
            anaghd @sdetweil
            @sdetweil said in MMM-Remote-Control can not turn ON monitor:
            sudo cec-client -r
            No device type given. Using ‘recording device’
            CEC Parser created - libCEC version 4.0.7
            path: Raspberry Pi
            com port: RPI
            opening a connection to the CEC adapter…
            DEBUG: [ 64] Broadcast (F): osd name set to ‘Broadcast’
            DEBUG: [ 64] Open - vc_cec initialised
            DEBUG: [ 64] logical address changed to Free use (e)
            NOTICE: [ 64] connection opened
            DEBUG: [ 65] processor thread started
            DEBUG: [ 65] << Broadcast (F) -> TV (0): POLL
            DEBUG: [ 65] initiator ‘Broadcast’ is not supported by the CEC adapter. using ‘Free use’ instead
            TRAFFIC: [ 65] << e0
            DEBUG: [ 125] >> POLL sent
            DEBUG: [ 125] TV (0): device status changed into ‘present’
            DEBUG: [ 125] << requesting vendor ID of ‘TV’ (0)
            TRAFFIC: [ 125] << e0:8c
            TRAFFIC: [ 497] >> 0e:00:8c:04
            DEBUG: [ 497] marking opcode ‘give device vendor id’ as unsupported feature for device ‘TV’
            DEBUG: [ 497] expected response received (87: device vendor id)
            DEBUG: [ 497] registering new CEC client - v4.0.7
            DEBUG: [ 497] SetClientVersion - using client version ‘4.0.7’
            NOTICE: [ 498] setting HDMI port to 1 on device TV (0)
            DEBUG: [ 498] SetConfiguration: double tap timeout = 200ms, repeat rate = 0ms, release delay = 500ms
            DEBUG: [ 498] detecting logical address for type ‘recording device’
            DEBUG: [ 498] trying logical address ‘Recorder 1’
            DEBUG: [ 498] << Recorder 1 (1) -> Recorder 1 (1): POLL
            TRAFFIC: [ 498] << 11
            TRAFFIC: [ 768] << 11
            DEBUG: [ 1039] >> POLL not sent
            DEBUG: [ 1039] using logical address ‘Recorder 1’
            DEBUG: [ 1039] Recorder 1 (1): device status changed into ‘handled by libCEC’
            DEBUG: [ 1039] Recorder 1 (1): power status changed from ‘unknown’ to ‘on’
            DEBUG: [ 1039] Recorder 1 (1): vendor = Pulse Eight (001582)
            DEBUG: [ 1039] Recorder 1 (1): CEC version 1.4
            DEBUG: [ 1039] AllocateLogicalAddresses - device ‘0’, type ‘recording device’, LA ‘1’
            DEBUG: [ 1039] Recorder 1 (1): osd name set to ‘’
            DEBUG: [ 1039] Recorder 1 (1): menu language set to ‘eng’
            DEBUG: [ 1039] logical address changed to Recorder 1 (1)
            DEBUG: [ 1039] GetPhysicalAddress - physical address = 2000
            DEBUG: [ 1039] using auto-detected physical address 2000
            DEBUG: [ 1039] Recorder 1 (1): physical address changed from ffff to 2000
            DEBUG: [ 1039] << Recorder 1 (1) -> broadcast (F): physical address 2000
            TRAFFIC: [ 1040] << 1f:84:20:00:01
            NOTICE: [ 1190] CEC client registered: libCEC version = 4.0.7, client version = 4.0.7, firmware version = 1, logical address(es) = Recorder 1 (1) , physical address: 2.0.0.0, compiled on Linux-5.10.17-v8+ … , features: P8_USB, DRM, P8_detect, randr, RPi, Exynos, Linux, AOCEC
            DEBUG: [ 1190] << Recorder 1 (1) -> TV (0): OSD name ‘’
            TRAFFIC: [ 1190] << 10:47
            DEBUG: [ 1251] << requesting power status of ‘TV’ (0)
            TRAFFIC: [ 1251] << 10:8f
            TRAFFIC: [ 1478] >> 01:46
            DEBUG: [ 1478] << Recorder 1 (1) -> TV (0): OSD name ‘’
            TRAFFIC: [ 1478] << 10:47
            DEBUG: [ 1479] >> TV (0) -> Recorder 1 (1): give osd name (46)
            TRAFFIC: [ 1797] >> 01:90:00
            waiting for input
            DEBUG: [ 1797] TV (0): power status changed from ‘unknown’ to ‘on’
            DEBUG: [ 1797] expected response received (90: report power status)
            DEBUG: [ 1797] >> TV (0) -> Recorder 1 (1): report power status (90)
            TRAFFIC: [ 3104] >> 01:46
            DEBUG: [ 3104] << Recorder 1 (1) -> TV (0): OSD name ‘’
            TRAFFIC: [ 3104] << 10:47
            DEBUG: [ 3104] >> TV (0) -> Recorder 1 (1): give osd name (46)
            • A
              anaghd @sdetweil
              @sdetweil sorry, this is way beyond my pay grade
                sdetweil @anaghd
                @anaghd mine too!
                • A
                  anaghd @sdetweil
                  @sdetweil See if this gives you any ideas. I couldn’t figure it out.
                  https://githubmemory.com/repo/Jopyth/MMM-Remote-Control/issues/178?page=1
                    sdetweil @anaghd
                    @anaghd vcgencmd turns off the hdmi port… not the monitor… and then I get an ugly no input message
                    • A
                      anaghd @sdetweil
                      @sdetweil I was wondering if we can do something similar to what they have done but modify it for cec utilities, especially in regards to the status command.
                        sdetweil @anaghd
                        @anaghd sorry don’t understand
                        if we could do something??
                        • A
                          anaghd @sdetweil
                          @sdetweil can we modify this to include cec-utility commands instead of the vcgencmd?
                          monitorStatusCommand: ‘if vcgencmd display power | grep 1 >/dev/null 2>&1; then echo true; else echo false; fi’
                            sdetweil @anaghd
                            @anaghd oh… I don’t know the module internals or config at all…
                            • A
                              anaghd @sdetweil
                              @sdetweil I finally have a solution that worked for me.
                              In the node_helper.js file, there is a function with the name “monitorControl”. In there, I used 2 things as shown below. Essentially, we want it to execute both, vcgen and cec, when we turn the monitor on and off. So I added the cec command to the already existing vcgencmd command. Now it looks like this.
                              this.thisConfig.customCommand.monitorOnCommand:
                              “vcgencmd display_power 1 && sudo echo 'on 0 | cec-client -s -d 1”;
                              this.thisConfig.customCommand.monitorOffCommand:
                              “vcgencmd display_power 0 && sudo echo 'standby 0 | cec-client -s -d 1”;
                              I did not change anything in the statusCommand part.
                              After that, I removed the customCommands from my config so that the module uses the default commands above for turning monitor ON and Off. That worked for me. See if it works for you.
                              S S 2 Replies Last reply
                                sdetweil @anaghd
                                @anaghd no, but you could have put the same strings in your custom commands
                                • A
                                  anaghd @sdetweil
                                  @sdetweil I tried doing that initially but that did not work for me.
                                    stevegoble @anaghd
                                    @anaghd said in MMM-Remote-Control can not turn ON monitor:
                                    I am not a programmer but there seems to be a syntax error in this line of code (and the next one too). Shouldn’t there be a closing ’ after the opening 'standby ?
                                      stevegoble @stevegoble
                                      @anaghd
                                      Even adding what I think is the correct syntax I still get an error. I am having the same issue where the TV will not turn back on after it goes to “sleep”. Initially (with unmodified code), as long as it is searching for the HDMI signal it will turn the monitor back on; however, when the signal search stops these commands will not turn the TV back on.
                                      Here is the error:
                                      Whoops! There was an uncaught exception…
                                      0|mm | [01.01.2022 06:21.55.922] [ERROR]
                                      0|mm | /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:640
                                      0|mm | “vcgencmd display_power 1” && sudo echo ‘on 0’ | cec-client -s -d 1”;
                                      0|mm | ^^^^
                                        sdetweil @stevegoble
                                        @stevegoble do you have the cec code installed?
                                        do
                                        cec-client
                                        if you get command not found
                                        do
                                        sudo apt install cec-utils
