    CalenderExt2 module won't show when using weather module
    4 Posts 2 Posters 1.1k Views 2 Watching
      aunrea
      The CalenderExt2 module works fine, but I want to use the default weather module. I want to show the current weather and the forecast. But when I add the forecast, the calendar will no longer show up.
      Here is my weather module config info:
      // TOP CENTER
                  module: "weather",
                  position: "top_center",
                  header: "Currently in",
                    weatherProvider: "weathergov",
                    type: "current",
                    apiBase: "https://api.weather.gov/points/",
                    weatherEndpoint: "/forecast/hourly",
                    lat: "42.834",
                    lon: "-71.6618",
                    initialLoadDelay: 1000,
                    showHumidity: true,
                    degreeLabel: true,
                    updateInterval: 600000,
              // TOP RIGHT
                  module: "weather",
                  header: "Forecast",
                    type: "forecast",
                    weatherEndpoint: "/forecast",
                    lat: "42.834",
                    lon: "-71.6618",
                    initialLoadDelay: 2000,
                    ignoreToday: true,
                    fade: false,
                    tableClass: "medium",
                    degreeLabel: true,
      The area with the calendar shows this html:
      <div class="region middle center"><div class="container" style="display: none;"></div></div>
        aunrea @aunrea
        I solved the problem by updating MagicMirror.
          aunrea @aunrea
          Is there possibly a conflict between the weather module and CalendarExt2? I don’t know why using the weather module in 2 locations causes the calendar to not show up. There are no errors in the logs either.
            DJBOOB66
            Since I updated to 2.17 if I use the internet function in GAv3 the mirror crashes with no errors unless I disable CalExt2 this only happen after updating MM
              aunrea @aunrea
