    Just updated to newest MagicMirror and now it won't load.
    6 Posts 3 Posters 1.4k Views 3 Watching
      aunrea
      I just updated to the newest MagicMirror. I get a black screen and the following error in my error log:
      Gdk-Message: 15:16:59.854: electron: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
      python3: can't open file 'stats.py': [Errno 2] No such file or directory
      [05.11.2021 15:18.22.355] [ERROR] WARNING! Could not find config file. Please create one. Starting with default configuration.
      Gdk-Message: 15:44:39.377: electron: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
      [05.11.2021 15:45.58.895] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
      Require stack:
      - /home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js
      [05.11.2021 15:45.58.920] [ERROR] App threw an error during load
      [05.11.2021 15:45.58.926] [ERROR] Error: Cannot find module 'request'
      Require stack:
          at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
          at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (internal/modules/cjs/loader.js:732:27)
          at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
          at Module.require (internal/modules/cjs/loader.js:959:19)
          at require (internal/modules/cjs/helpers.js:88:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js:4:17)
          at Module._compile (internal/modules/cjs/loader.js:1078:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
      [05.11.2021 15:45.58.932] [ERROR] Whoops! There was an uncaught exception...
      [05.11.2021 15:45.58.944] [ERROR] Error: Cannot find module 'request'
      Require stack:
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js',
          '/home/pi/MagicMirror/js/app.js',
          '/home/pi/MagicMirror/js/electron.js',
          '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
          undefined
      [05.11.2021 15:45.58.946] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [05.11.2021 15:45.58.947] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      I don’t know what the stats.py file is or where it should be. I also do have a config file, which has all my code in it exactly as before I updated. I don’t know why I am getting all these errors or what many of them mean.
        sdetweil @aunrea
        @aunrea https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
          aunrea @sdetweil
          @sdetweil Sorry I did look at that but didn’t understand it or my logs so didn’t realize they were related. Reading it again I realized I needed install request and that fixed the issue. Thank you and sorry for posting when the question was already answered.
            sdetweil @aunrea
            @aunrea your logs shows
              bjoern
              open another module directory and look for a “node_modules” folder and see if there is a “request” folder there. then copy this to your module where it is missing. that also helped and worked for me. Maybe more are missing. I searched my node_modules folder until I had everything together.
                sdetweil @bjoern
                @bjoern said in Just updated to newest MagicMirror and now it won't load.:
                NOOOOOOOOOO
                use npm thats what it is for
                follow the instructions in the linked pinned topic in troubleshooting…
