    MMM-MarineWeather doen't work..
    10 Posts 4 Posters 2.3k Views 4 Watching
      RIKKO14
      it has been several months since I touched my magic mirror.
      For several days the MMM-MarineWeather mod has not worked, it remains loading on my screen.
      I uninstalled it then reinstalled by updating but nothing helps, it is still loading …
      What to do ?
      Do I have to update my magic mirror? (I do not know the version and I am afraid if I do so of having once again the problem of Electron which is displayed instead of my modules.
      Thank you for your help.
      KamiSchamiK 1 Reply Last reply Reply Quote 0
      • KamiSchamiK Offline
        KamiSchami @RIKKO14
        Hi, i have the same problem … :-/
        Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
          sdetweil @KamiSchami
          @kamischami this is probably the expired certificate problem fixed in 2.17.1 (an electron bug, not our code)
          u might see the error reported in the developer window
          ctrl-shift-i, select the tab labeled console , and put a unique part of the module name in the filter field
          marine (for example here)
          use my script to upgrade
          see https://github.com/sdetweil/MagicMirror_scripts
            RIKKO14 @sdetweil
            @sdetweil I followed your link and the command lines and this is what I got :
            pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
            $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
            $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
            $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
            $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
            $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
            $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
            \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                    \______/
            install log being saved to /home/pi/install.log
            Installing helper tools ...
            Updating packages ...
            Minimum Node version: v14.0.0
            Installed Node version: v10.24.1
            Node should be upgraded.
            A Node process is currently running. Can't upgrade.
            Please quit all Node processes and restart the installer.
            Usage: grep [OPTION]... PATTERNS [FILE]...
            Exécutez « grep --help » pour obtenir des renseignements complémentaires.
            pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
            No LSB modules are available.
            pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
            doing test run = false
            pi@raspberrypi:~ $
              sdetweil @RIKKO14
              @rikko14 is MagicMirror running? must stop first
              if using pm2 , do
              pm2 stop all
                sdetweil @RIKKO14
                @rikko14 I just submitted an update for the script to fix the grep error message
                  RIKKO14 @sdetweil
                  @sdetweil I do pm2 stop all and after bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" BUT MMM-MarineWeather still not work, It still loading…
                  AND I have lost 2 modules : MMM-Weather and MMM-Shom (find here : http://wiki.bugsounet.fr/en/MMM-Shom) , I Have try npm install -g npm but I have this (see the enclosed : https://www.cjoint.com/c/KKopWKz3GpT)
                  Finally, after upgrade 2.17 I have on the top of my screen “a new update is available”
                  My MM when it’s work well :
                  My MM now :
                  Thanks for your help
                    sdetweil @RIKKO14
                    @rikko14 can u show me the ~/installers/upgrade.log (maybe send via email to my same userid at gmail)
                    also do
                    grep version package.json
                    I do not think you are running 2.17
                      RIKKO14
                      @sdetweil,
                      I was able to update, with patience and tenacity, to 2.17 by following the instructions of Bugsounet (http://forum.bugsounet.fr/topic/604/i-lost-mmm-weather-and-mmm-shom- after-upgrading-mm-2-12-to-2-17 / 27)
                      however, I noticed that after the update I lost the sound of my two small speakers connected in jacks, how can I recover the sound?
                      is there a radio module that works in the background (i.e. without displaying anything on the MM screen)
                      bugsounetB 1 Reply Last reply Reply Quote 0
                      • bugsounetB Offline
                        bugsounet Banned @RIKKO14
                        It’s not my job, it’s the job of this forum :)
                        but sometime i’m kind…
                        It’s not related to the update, it’s related to your OS. See the desktop os and check Sound icon to set your card by default
                        Please stop opening many topic everywhere… it’s the good way to have bad response and breaking entire OS
