    XKCD not updating
    4 Posts 2 Posters 1.2k Views 2 Watching
      ruskythegreat
      So I’ve tried both the DailyXKCD and MMM-XKCD but I can’t get either to update. They will refresh if I restart MM though.
      This is my current extract: -
               module: 'DailyXKCD',
              position: 'top_right',
                  updateInterval: 3600000,
                  grayScale: false,
                  invertColors: true,
                  limitComicWidth: 400,
                  limitComicHeight: 0,
                  randomComic: true,
                  showTitle: true,
      Any ideas please?
        sdetweil @ruskythegreat
        @ruskythegreat according to the site they add a new image 3 times a WEEK, Monday, Wednesday, Friday
        R 1 Reply Last reply
          ruskythegreat @sdetweil
          @sdetweil Yup, there’s an option in both modules.
          In DailyXKCD:
          randomComic Set to true, if you want to see a random comic on days, when there is no new comic.
          In MMM-XKCD there’s also an alwaysRandom option:
          randomComic bool false Display a random comic, where no new comic is available.
          alwaysRandom bool false If you always want to see a random comic, even on days where a new comic is available. Note: Only effective if randomComic is set to true.
          I’m currently running DailyXKCD, so If I’m reading that right, my config has updateInterval set to 3600000 which is 1h, I should get a new comic every hour (for testing!).
            @ruskythegreat no idea really… code looks ok… there is a small timing problem on startup, but
            open the developers window, ctrl-shift-i, select the tab labeled console, and put a unique part of the module name in the filter field (xkcd)
            see if there are any errors reported
            i did what the node_helper does to get an image, and it looks good…
