    MMM-remote-control Restart MM not possible
    6 Posts 2 Posters 1.3k Views 4 Watching
    • O Offline
      OberfragGER
      today i reinstalled my MagicMirror.
      I installed Buster and used the script from @sdetweil for it. I installed some modules without any problem and also MMM-remote-control.
      After the install i recieved “PM2 ist not installed or unlinked”. So i did
      cd ~/MagicMirror/modules/MMM-Remote-Control
      npm link pm2
      This error was gone. Bit now another error inside the module. The log means:
      [24.11.2021 22:19.44.993] [LOG]   PM2 process: restart mm
      [24.11.2021 22:19.45.041] [LOG]   Error: process or namespace not found
          at /usr/lib/node_modules/pm2/lib/API.js:1524:28
          at /usr/lib/node_modules/pm2/lib/Client.js:735:12
          at /usr/lib/node_modules/pm2/node_modules/pm2-axon-rpc/lib/client.js:45:10
          at Parser.<anonymous> (/usr/lib/node_modules/pm2/node_modules/pm2-axon/lib/sockets/req.js:67:8)
          at Parser.emit (events.js:315:20)
          at Parser._write (/usr/lib/node_modules/pm2/node_modules/amp/lib/stream.js:91:16)
          at writeOrBuffer (internal/streams/writable.js:358:12)
          at Parser.Writable.write (internal/streams/writable.js:303:10)
          at Socket.ondata (internal/streams/readable.js:719:22)
          at Socket.emit (events.js:315:20)
      Any ideas how to fix that?
        sdetweil @OberfragGER
        @oberfragger said in MMM-remote-control Restart MM not possible:
        my script names the MM process MagicMirror
        pm2 status will show you the names of the processes it manages
        so, I think u have to change the rc parm for the pm2 process name
        • O Offline
          OberfragGER @sdetweil
          @sdetweil Thanks for your Info.
          Sorry for asking… i dnot know what you mean with “RC”
          or how tho change the process name…
          • O Offline
            OberfragGER @OberfragGER
            @sdetweil Ui. I just found a possible solution.
            I editet the node_helper.js in the folder /home/pi/MagicMirror/modules/MMM-Remote-Control
            Line 959 from:
                        let processName = query.processName || this.thisConfig.pm2ProcessName || "mm";
            to
                        let processName = query.processName || this.thisConfig.pm2ProcessName || "MagicMirror";
            Lets see how dirty this is…and if this destroys other things.
              @oberfragger this.thisConfig.pm2ProcessName
              means there is a configuration option for the remote control (aka rc) module, so you don’t have to change the code
              • O Offline
                @sdetweil Thanks a lot. Found it now. Its ‘pm2ProcessName’.
