    Losing display output after 5 minutes
    14 Posts 3 Posters 5.2k Views 3 Watching
      sdetweil @danjvd
      @danjvd if you stop MagicMirror, does the screen turn off?
        danjvd @sdetweil
        @sdetweil I have not tried that. I will let you know later today of the outcome.
        Thanks Sam!
        Z 1 Reply Last reply Reply Quote 0
        • Z Offline
          Zoltan @danjvd
          @danjvd It sounds as if your screen saver wasn’t disabled correctly?
          https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi
            sdetweil @Zoltan
            @zoltan if u run my install script it will turn off screensavers if u say yes.
            also a separate script if u change your mind
            we are still waiting to see if it’s mm related or not
              danjvd @sdetweil
              @sdetweil With MM turned off, the Pi keep display HDMI without issues. Are there any error logs that I should look at?
              @Zoltan Thanks for the steps. I did complete this when I first created the MM pi over a year ago. It always a good thing to veirfy!
                @danjvd ok so this means one of the modules you are using is turning off the display
                can you do
                grep module: ~/MagicMirror/config/config.js
                to show us a list of the modules used
                  danjvd @sdetweil
                  @sdetweil said in Losing display output after 5 minutes:
                  Here are the modules that I have been using for the past 6 months before the issues started. I have not added/removed any modules after this setup, only updates.
                    module: "alert",
                    module: 'MMM-BackgroundSlideshow',
                    module: "updatenotification",
                    module: "clock",
                    module: 'MMM-CalendarExt2',
                    module: "MMM-OpenWeatherMapForecast",
                    sdetweil @danjvd
                    @danjvd weird.
                    so next I would disable one module at a time.
                    (not the defaults)
                    add
                    disabled:true,
                    after the module: line
                      danjvd @sdetweil
                      Before I was able to start disabling modules, MM would not start this morning. There are the logs that I got from pm2:
                      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                      2 info using npm@6.14.12
                      3 info using node@v10.24.1
                      5 info lifecycle magicmirror@2.17.1~prestart: magicmirror@2.17.1
                      6 info lifecycle magicmirror@2.17.1~start: magicmirror@2.17.1
                      7 verbose lifecycle magicmirror@2.17.1~start: unsafe-perm in lifecycle true
                      8 verbose lifecycle magicmirror@2.17.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/bin:/bin
                      9 verbose lifecycle magicmirror@2.17.1~start: CWD: /home/pi/MagicMirror
                      10 silly lifecycle magicmirror@2.17.1~start: Args: [ '-c',
                      10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
                      11 info lifecycle magicmirror@2.17.1~start: Failed to exec start script
                      12 verbose stack Error: magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                      12 verbose stack spawn ENOENT
                      12 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:48:18)
                      12 verbose stack     at ChildProcess.emit (events.js:198:13)
                      12 verbose stack     at maybeClose (internal/child_process.js:982:16)
                      12 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                      13 verbose pkgid magicmirror@2.17.1
                      14 verbose cwd /home/pi/MagicMirror
                      15 verbose Linux 5.10.63-v7l+
                      16 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                      17 verbose node v10.24.1
                      18 verbose npm  v6.14.12
                      19 error code ELIFECYCLE
                      20 error syscall spawn
                      21 error file sh
                      22 error errno ENOENT
                      23 error magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                      23 error spawn ENOENT
                      24 error Failed at the magicmirror@2.17.1 start script.
                      24 error This is probably not a problem with npm. There is likely additional logging output above.
                      25 verbose exit [ 1, true ]
                        danjvd @danjvd
                        Give you a little update after finding the error above. I have reinstalled dependency and built electron.
                        npm install
                        cd ~/MagicMirror/node_modules/electron/
                        node install.js
                        The reinstall came with the following warnings
                        npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        I restarted MM with npm start, now getting the following:
                        [24.11.2021 17:34.23.187] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'valid-url'
                        Require stack:
                        - /home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js
                        I disable that mode and was able to get MM restarted. I’m guessing there is an issue with MMM-CalendarExt2.
                          sdetweil @danjvd
                          @danjvd valid-url see
