    Module fade out temporarily and fade it in by touch ?
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    13 Posts 2 Posters 5.4k Views 2 Watching
    • KamiSchamiK
      KamiSchami @sdetweil
      @sdetweil … on screen
      Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
        sdetweil @KamiSchami
        @kamischami what module is providing the button support?
        KamiSchamiK 1 Reply Last reply
        • KamiSchamiK
          @sdetweil , i use MMM-TouchNavigation
            @kamischami and profileswitcher…
            so this module doesn’t do much… but its SO close…
            MM can only show or hide modules. when u switch profiles and a module disappears, its because it is hidden, (but still running)
            SO, you could make another profile with whatever module you want to hide from THIS profile
            and cause a switch to that profile
            • KamiSchamiK
              Hello, yes I can of course create a new profile and change the time. I would like the buttons to hide and be there again when they are touched. So I could create a clean design.
              PS: I hope google translated it well.
                @kamischami oh. THAT is a different problem
                so the trick will be to hide the existing buttons and replace with a transparent button, which clicked reverses the process.
                if u hide a module or an html element (style display: none), then it is not active anymore, and can’t be clicked
                one might be able to change the opaqueness to 0 and have the buttons active but invisible.
                then each button click handler will need to check if it’s invisible and change that vs doing it’s normal assignment.
                • KamiSchamiK
                  @sdetweil Yes, that would of course be possible … now the question is how to implement it
                    @kamischami the code for the MMM-TouchNavigation module needs to be changed
                    and some styles for the fade out/in transition, and the timing logic for fade out (after 5 minutes, or 1 or…)
                    and config for this support hideAfter: true/false (default false) might be able to do it with a number (the delay time, default 0)
                    I don’t know which approach works… (or works better) create another div and toggle active
                    or opacity only
                      @KamiSchami l said in Module fade out temporarily and fade it in by touch ?:
                      MMM-TouchNavigation
                      well, I gave it a try and the opacity approach works
                      rename your MMM-TouchNavigation folder and get mine
                      https://github.com/sdetweil/MMM-TouchNavigation
                      two new config parms
                      fadeButtons: true (default is false, buttons on screen all the time)
                      fadeDelay: milliseconds , default 15000… how long til u want them to fade out
                      if u touch a button the timer is restarted
                      once faded (to 20%, just barely visible, so u know where to touch), then they are surfaced, but the specific button notification was not sent… have to push button when not faded to send profile switch
                        @kamischami did u try my updated module?
                        • KamiSchamiK
                          @sdetweil Hi, oooh that’s great. I haven’t had time to implement it yet. I will call you. Thanks very much!
