    MMM-CalendarExt Multiple Calendars
    4 Posts 2 Posters 1.4k Views 2 Watching
      pastormingle
      Re: MMM-CalendarExtI am new to CalendarExt and need a little guidance concerning multiple calendars… I need to have 3 additional calendars add to the view but not sure how to do that and also not able to find how to change the time from 24 to 12… any help please?
      • BKeyportB Online
        BKeyport Module Developer @pastormingle
        @pastormingle I’d first switch to CalendarExt2. It’s the newer of the two, and more extensive. However, some of this below may work with the original.
        This is an example of how the config should be for multiple calendars. Expand as needed.
        			module: "MMM-CalendarExt2", // https://github.com/MMM-CalendarExt2/MMM-CalendarExt2
        				calendars : [
        						url: "URL1",
        						name: "Calendar 1", // Optional, Recommended
        						// Other Options
        						url: "URL2",
        						// Other Options
        					// etc
        				views: [
        						mode: // Pick Mode
        						position: // Pick Position
        						name: // Name Calendar Group
        						calendars: ["Calendar 1". "Calendar 2"],
        						// other options
        					// OR, if you'd like the calendars independant from each other:
        						mode: // Pick Mode
        						calendars: ["Calendar 1"],
        						// Other Options
        						mode: // Pick Mode
        						calendars: ["Calendar 2"],
        						// Other Options
        				scenes: [
          pastormingle @BKeyport
          @bkeyport thanks so much for your help. I did install the calendatExt2 but has several issues as my current config wouldn’t work. But the calendarext did work
          With the added calendars. I still didn’t find an option to change from 24 time to 12. If you can point me in the right direction please.
          • BKeyportB Online
            @pastormingle I believe the time would be set by the master time format option.
            see: https://docs.magicmirror.builders/getting-started/configuration.html#general
