    MMM-CalendarExt
    198 Posts 45 Posters 276.1k Views 45 Watching
      A Former User
      MMM-CalendarExt
      Alternative calendar module for MagicMirror
      Screenshots
      Features
      • daily, weekly, monthly, month, upcoming, current views are supported.
      • All/any views in any regions.
      • Profiles are supported (MMM-ProfileSwitcher or any modules which use CHANGED_PROFILE notification)
      • Configuration can be changed by profile.
      • Runtime-Configuration available.
      • Your other module can add, update and remove instant events.
      • Your other module can ask events and get answers.
      • Almost everything customizable with configuration and CSS.
      more information
      See the Wiki
      Download:
      [card:eouia/MMM-CalendarExt]
      N 1 Reply Last reply
      Reply Quote 3
      • V
        Vauxdvihl
        Thanks a lot for this great module
        I have a few questions:
        1.)
        Can you please share your config for the 2nd above standing screen (with the “current” and the “upcoming” one) as an example?
        2.)
        Is it possible to load an ical file from the storage?
        Thanks a lot
        ? 2 Replies Last reply
          A Former User @Vauxdvihl
          @Vauxdvihl said in MMM-CalendarExt:
          1.)
            system: {
              show: ['upcoming', 'current'], //you can select views which you want to show.
            views: {
              upcoming: {
                title: "UPCOMING EVENTS",
                limit: 5,
              current: {
                title: "CURRENT EVENTS",
                limit: 5,
                name: "US Holiday",
                url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
          For more detailed configuration, See https://github.com/eouia/MMM-CalendarExt/wiki/Configuration
          2.)
          You can put your ical to MagicMirror root directory and use it as http://localhost:8080/yourIcal.ics. I think it could be, but i didn’t try. After some test, I could tell you more exact information.
          Reply Quote 3
            @Vauxdvihl
            You can use like this;
            1. put your ical file (test.ics) to MMM-CalendarExt directory
            2. Use this url. http://localhost:8080/modules/MMM-CalendarExt/test.ics
            It works.
            Reply Quote 1
            • V
              Vauxdvihl
              Thanks a lot
              Both works
              I have a few more questions
              3.)
              Having the month view, it displays me 6 weeks (2 old ones)
              Is there a “screw” where i can change it
              Display “only” 4 weeks and no “old” one
              4.)
              Can i overrite dates and make them to “complete day meetings” (like in your example “Hausmüll”)
              Here in me ical is it a entry from 10 to 11 and in the view “upcoming” there is an entry in the calendar which is viewn as [object Object] ==> Also i want to save some space with a complete date entry
              5.)
              Is there a possibility instead of using symbols to use names?
              Like “Mama” or “Papa”…
              Thanks a lot
              ? 1 Reply Last reply
                @Vauxdvihl
                3.)
                What did you mean ‘screw’?
                Anyway month view cannot be done for that.
                But you can use ‘daily’ view for that purpose.(with ‘counts:28’) However some css adjusting might be needed for your mirror’s look.
                4.)
                Can you send me your ical file? I need to inspect.
                For fulldayevents, you should have created that events as fullday. Or you could modify event time from 00:00-24:00
                For saving space, see the wiki page. And some css technics would be help.
                5.)
                Well, I think you can prepend or append some text in specific style with css virtual selector(‘:before’).
                Sorry for my non-pragmatic answers.
                I’m not in front of device now, so I cannot make any real solution with real code. During weekends, I have no time for console works. I’ll check your questions again on Monday.
                • V
                  Vauxdvihl
                  3.)
                  With a “screw” i mean something to adjust…no problem ok
                  4.)
                  Here u are…
                  Seems to me i do not have the right to upload here something
                  Here is some extract…
                  STATUS:CONFIRMED
                  END:VEVENT
                  BEGIN:VEVENT
                  DTSTART:20170201T080000Z
                  DTEND:20170201T090000Z
                  LOCATION;LANGUAGE=de:, 82343 POECKING
                  TRANSP:OPAQUE
                  SEQUENCE:0
                  UID: 2171943
                  DTSTAMP:20171014T081346Z
                  DESCRIPTION;LANGUAGE=de:
                  SUMMARY;LANGUAGE=de:Restmuelltonne
                  PRIORITY:9
                  CLASS:PUBLIC
                  URL:
                  STATUS:CONFIRMED
                  END:VEVENT
                  BEGIN:VEVENT
                  DTSTART:20170215T080000Z
                  DTEND:20170215T090000Z
                  TRANSP:OPAQUE
                  SEQUENCE:0
                  UID: 2171944
                  PRIORITY:9
                  CLASS:PUBLIC
                  URL:
                  5.)
                  Ok,
                  i will play a little bit
                  • Z
                    Zooooooom
                    Thank you for a great module! I second @Vauxdvihl about only wanting see the the current week, plus the next 3. Google calendar has that feature. Basically, a clone of the month view, but not starting from the 1st of the month, but from the first day of the current week.
                    I tried doing what you suggested with using daily and 28 and it’s close to what I want. But I am only seeing 6 per row. What do I need to modify to make sure I am seeing 7 days?
                    Also, is there a way to completely remove the icon and the space for it? I don’t see it in any on the defined styles. I would prefer to have a little more extra breathing room on my fairly narrow monitor.
                    Again, thanks for a great module!
                      A Former User @Zooooooom
                      @Zooooooom I’ll provide some tricks for ‘next 28 days(7 per week) view’ on Monday. It needs some css tricks.
                      Your other question also could be considered at that time.
                      Thanks for using.
                      Reply Quote 1
                        A Former User
                        @Zooooooom @Vauxdvihl
                        Here is some ‘next 28 days view’ sample.
                        1. Open your css/custom.css and append these code;
                        /* CSS adjusting for 28days view */
                        /* hide unnecessary components */
                        #CALEXT_daily .eventTime,
                        #CALEXT_daily .eventLocation,
                        #CALEXT_daily .symbol {
                          display:none;
                        /* smaller size for events */
                        #CALEXT_daily .eventContent {
                          font-size:0.8em;
                          font-weight:normal;
                        /* makes "slot" 1/7 of 100% */
                        #CALEXT_daily .slot {
                          max-width:13%;
                          flex-basis:13%;
                        #CALEXT_daily .slot .header {
                          font-size:0.5em;
                          border-radius:0;
                          font-weight:normal;
                        /* add some style sample */
                        #CALEXT_daily .style_custom2 {
                          background-color:rgba(255, 127, 255, 1.0);
                        /* add some additional content sample */
                        #CALEXT_daily .style_custom2 .eventContent::before{
                          content: "[@]";
                        1. open your config.js, put these codes.
                              module: 'MMM-CalendarExt',
                              position: "top_center", // ignore this.
                                system: {
                                  show: ['daily'],
                                  locale: 'en',
                                views: {
                                  daily: {
                                    position:'bottom_bar',
                                    counts:28,
                                    //overflowRolling:1,
                                    //overflowHeight:50,
                                calendars :[
                                    styleName: "style_custom1",
                                    oneLineEvent: 1,
                                    url: "webcal://www.google.com/calendar/ical/en5624jps9pfbtgsd7op2him0k%40group.calendar.google.com/public/basic.ics",
                                    styleName: "style_custom2",
                                    //oneLineEvent: 1,
                                    url: "webcal://www.google.com/calendar/ical/0efdnrqt4c9qruabf7u33742ps%40group.calendar.google.com/public/basic.ics",
                                    styleName: "style_custom3",
                                    oneLineEvent: 1,
                                    url: "http://ical.grips-theater.de/grips.ics",
                        1. You can refer also https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks
                        2. Main trick is
                          max-width:13%;
                          flex-basis:13%;
                        You might need to adjust the value 13% to your circumstances. Because of margin and padding, 14% might not work.
                        1. You can also consider overflow and oneLineEvent and titleReplace for saving spaces.
                        Anyway, under 700px width, this could not work. That is too narrow to display 7 slots.
                        Reply Quote 1
                          BEGIN:VEVENT
                          TRANSP:OPAQUE
                          SEQUENCE:0
                          UID: 2171943
                          PRIORITY:9
                          CLASS:PUBLIC
                          URL:
                          STATUS:CONFIRMED
                          END:VEVENT
                          I found what’s wrong. you ical location format is slightly different with others.
                          I’ve committed hotfix for that. git pull again and re-run your mirror.
                          Reply Quote 1
                            A Former User
                            And I also added weeks view for your exact wish. pull new source and see the wiki.
                            So, you have two options.
                            28days view
                            vs
                            4weeks view.
                            both are slightly different. 28days always starts from today. 4weeks always starts from weekday(0) - Monday or Sunday - of this week.
                            Use anything you want.
                            Z 1 Reply Last reply
                            Reply Quote 1
                            • Z
                              Zooooooom @Guest
                              @Sean Beautiful! Exactly what I wanted.
                              • V
                                Vauxdvihl
                                Great Job
                                Thanks a lot
                                • V
                                  Vauxdvihl
                                  Hi Sean,
                                  i have a few more questions
                                  Please look to my attached screen:
                                  a.)
                                  Today is “not viewable” because it is “more or less” complete white
                                  Any Idea
                                  b.)
                                  Is there a chance to increase the size of the symbols (i mean the symbols in front of the date…like the football)
                                  c.)
                                  I was wondering that your dates a looking a little bit different
                                  In your dates you have the information about the timing and the location.
                                  I have put the same infos in my google calendar but they will not be shown
                                  Thats a lot
                                    a.)
                                    Any Idea
                                    That is my fault. After some CSS test, my experimental CSS was committed by accident, I thought.
                                    I’ll fix it ASAP.(after answer of this)
                                    b.)
                                    in your css/custom.css
                                    you can put these;
                                    div.CALEXT  .event .symbol {
                                        order:1;
                                        display:block;
                                        flex-basis: 30px; // Modify this
                                        text-align:center;
                                        min-width: 30px; // Modify this
                                        font-size: 150%; // Add this
                                    c.)
                                    Thats a lot
                                    This is also same with answer of a). Sorry again.
                                      @Vauxdvihl
                                      I think I’ve fixed it. pull the source and try again.
                                      • V
                                        Vauxdvihl
                                        Amazing
                                        Thanks a lot
                                        • V
                                          Vauxdvihl
                                          Hi Sean,
                                          according to b.)
                                          Sorry to asked again.
                                          While playing a little bit with the config parameters, i can “only” adjust the size of the area within the symbol is located.
                                          But it doesn’t change the size of the symbol itself
                                          Thanks a lot
                                            @Vauxdvihl
                                            Did you add this?
                                            Give bigger value for that.(And you need to change value of *-width for adjusting)
                                            • 9
                                            • 10
                                            • 1 / 10
