    MMM-CalendarExt
    198 Posts 45 Posters 276.6k Views 45 Watching
      A Former User @Vauxdvihl
      @Vauxdvihl said in MMM-CalendarExt:
      1.)
      Can you please share your config for the 2nd above standing screen (with the “current” and the “upcoming” one) as an example?
        system: {
          show: ['upcoming', 'current'], //you can select views which you want to show.
        views: {
          upcoming: {
            title: "UPCOMING EVENTS",
            limit: 5,
          current: {
            title: "CURRENT EVENTS",
            limit: 5,
            name: "US Holiday",
            url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
      For more detailed configuration, See https://github.com/eouia/MMM-CalendarExt/wiki/Configuration
      2.)
      Is it possible to load an ical file from the storage?
      You can put your ical to MagicMirror root directory and use it as http://localhost:8080/yourIcal.ics. I think it could be, but i didn’t try. After some test, I could tell you more exact information.
      Reply Quote 3
        @Vauxdvihl
        You can use like this;
        1. put your ical file (test.ics) to MMM-CalendarExt directory
        2. Use this url. http://localhost:8080/modules/MMM-CalendarExt/test.ics
        It works.
        • V
          Vauxdvihl
          Thanks a lot
          Both works
          I have a few more questions
          3.)
          Having the month view, it displays me 6 weeks (2 old ones)
          Is there a “screw” where i can change it
          Display “only” 4 weeks and no “old” one
          4.)
          Can i overrite dates and make them to “complete day meetings” (like in your example “Hausmüll”)
          Here in me ical is it a entry from 10 to 11 and in the view “upcoming” there is an entry in the calendar which is viewn as [object Object] ==> Also i want to save some space with a complete date entry
          5.)
          Is there a possibility instead of using symbols to use names?
          Like “Mama” or “Papa”…
          Thanks a lot
          ? 1 Reply Last reply
            @Vauxdvihl
            3.)
            What did you mean ‘screw’?
            Anyway month view cannot be done for that.
            But you can use ‘daily’ view for that purpose.(with ‘counts:28’) However some css adjusting might be needed for your mirror’s look.
            4.)
            Can you send me your ical file? I need to inspect.
            For fulldayevents, you should have created that events as fullday. Or you could modify event time from 00:00-24:00
            For saving space, see the wiki page. And some css technics would be help.
            5.)
            Well, I think you can prepend or append some text in specific style with css virtual selector(‘:before’).
            Sorry for my non-pragmatic answers.
            I’m not in front of device now, so I cannot make any real solution with real code. During weekends, I have no time for console works. I’ll check your questions again on Monday.
            • V
              Vauxdvihl
              3.)
              With a “screw” i mean something to adjust…no problem ok
              4.)
              Here u are…
              Seems to me i do not have the right to upload here something
              Here is some extract…
              STATUS:CONFIRMED
              END:VEVENT
              BEGIN:VEVENT
              DTSTART:20170201T080000Z
              DTEND:20170201T090000Z
              LOCATION;LANGUAGE=de:, 82343 POECKING
              TRANSP:OPAQUE
              SEQUENCE:0
              UID: 2171943
              DTSTAMP:20171014T081346Z
              DESCRIPTION;LANGUAGE=de:
              SUMMARY;LANGUAGE=de:Restmuelltonne
              PRIORITY:9
              CLASS:PUBLIC
              URL:
              STATUS:CONFIRMED
              END:VEVENT
              BEGIN:VEVENT
              DTSTART:20170215T080000Z
              DTEND:20170215T090000Z
              TRANSP:OPAQUE
              SEQUENCE:0
              UID: 2171944
              PRIORITY:9
              CLASS:PUBLIC
              URL:
              5.)
              Ok,
              i will play a little bit
              • Z
                Zooooooom
                Thank you for a great module! I second @Vauxdvihl about only wanting see the the current week, plus the next 3. Google calendar has that feature. Basically, a clone of the month view, but not starting from the 1st of the month, but from the first day of the current week.
                I tried doing what you suggested with using daily and 28 and it’s close to what I want. But I am only seeing 6 per row. What do I need to modify to make sure I am seeing 7 days?
                Also, is there a way to completely remove the icon and the space for it? I don’t see it in any on the defined styles. I would prefer to have a little more extra breathing room on my fairly narrow monitor.
                Again, thanks for a great module!
                  A Former User @Zooooooom
                  @Zooooooom I’ll provide some tricks for ‘next 28 days(7 per week) view’ on Monday. It needs some css tricks.
                  Your other question also could be considered at that time.
                  Thanks for using.
                    A Former User
                    @Zooooooom @Vauxdvihl
                    Here is some ‘next 28 days view’ sample.
                    1. Open your css/custom.css and append these code;
                    /* CSS adjusting for 28days view */
                    /* hide unnecessary components */
                    #CALEXT_daily .eventTime,
                    #CALEXT_daily .eventLocation,
                    #CALEXT_daily .symbol {
                      display:none;
                    /* smaller size for events */
                    #CALEXT_daily .eventContent {
                      font-size:0.8em;
                      font-weight:normal;
                    /* makes "slot" 1/7 of 100% */
                    #CALEXT_daily .slot {
                      max-width:13%;
                      flex-basis:13%;
                    #CALEXT_daily .slot .header {
                      font-size:0.5em;
                      border-radius:0;
                      font-weight:normal;
                    /* add some style sample */
                    #CALEXT_daily .style_custom2 {
                      background-color:rgba(255, 127, 255, 1.0);
                    /* add some additional content sample */
                    #CALEXT_daily .style_custom2 .eventContent::before{
                      content: "[@]";
                    1. open your config.js, put these codes.
                          module: 'MMM-CalendarExt',
                          position: "top_center", // ignore this.
                            system: {
                              show: ['daily'],
                              locale: 'en',
                            views: {
                              daily: {
                                position:'bottom_bar',
                                counts:28,
                                //overflowRolling:1,
                                //overflowHeight:50,
                            calendars :[
                                styleName: "style_custom1",
                                oneLineEvent: 1,
                                url: "webcal://www.google.com/calendar/ical/en5624jps9pfbtgsd7op2him0k%40group.calendar.google.com/public/basic.ics",
                                styleName: "style_custom2",
                                //oneLineEvent: 1,
                                url: "webcal://www.google.com/calendar/ical/0efdnrqt4c9qruabf7u33742ps%40group.calendar.google.com/public/basic.ics",
                                styleName: "style_custom3",
                                oneLineEvent: 1,
                                url: "http://ical.grips-theater.de/grips.ics",
                    1. You can refer also https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks
                    2. Main trick is
                      max-width:13%;
                      flex-basis:13%;
                    You might need to adjust the value 13% to your circumstances. Because of margin and padding, 14% might not work.
                    1. You can also consider overflow and oneLineEvent and titleReplace for saving spaces.
                    Anyway, under 700px width, this could not work. That is too narrow to display 7 slots.
                    N 1 Reply Last reply
                      BEGIN:VEVENT
                      TRANSP:OPAQUE
                      SEQUENCE:0
                      UID: 2171943
                      PRIORITY:9
                      CLASS:PUBLIC
                      URL:
                      STATUS:CONFIRMED
                      END:VEVENT
                      I found what’s wrong. you ical location format is slightly different with others.
                      I’ve committed hotfix for that. git pull again and re-run your mirror.
                        A Former User
                        And I also added weeks view for your exact wish. pull new source and see the wiki.
                        So, you have two options.
                        28days view
                        vs
                        4weeks view.
                        both are slightly different. 28days always starts from today. 4weeks always starts from weekday(0) - Monday or Sunday - of this week.
                        Use anything you want.
                        Z 1 Reply Last reply
                        • Z
                          Zooooooom @Guest
                          @Sean Beautiful! Exactly what I wanted.
                          • V
                            Vauxdvihl
                            Great Job
                            Thanks a lot
                            • V
                              Vauxdvihl
                              Hi Sean,
                              i have a few more questions
                              Please look to my attached screen:
                              a.)
                              Today is “not viewable” because it is “more or less” complete white
                              Any Idea
                              b.)
                              Is there a chance to increase the size of the symbols (i mean the symbols in front of the date…like the football)
                              c.)
                              I was wondering that your dates a looking a little bit different
                              In your dates you have the information about the timing and the location.
                              I have put the same infos in my google calendar but they will not be shown
                              Thats a lot
                              ? 2 Replies Last reply
                                a.)
                                Any Idea
                                That is my fault. After some CSS test, my experimental CSS was committed by accident, I thought.
                                I’ll fix it ASAP.(after answer of this)
                                b.)
                                in your css/custom.css
                                you can put these;
                                div.CALEXT  .event .symbol {
                                    order:1;
                                    display:block;
                                    flex-basis: 30px; // Modify this
                                    text-align:center;
                                    min-width: 30px; // Modify this
                                    font-size: 150%; // Add this
                                c.)
                                Thats a lot
                                This is also same with answer of a). Sorry again.
                                  @Vauxdvihl
                                  I think I’ve fixed it. pull the source and try again.
                                  • V
                                    Vauxdvihl
                                    Amazing
                                    Thanks a lot
                                    • V
                                      Vauxdvihl
                                      Hi Sean,
                                      according to b.)
                                      Sorry to asked again.
                                      While playing a little bit with the config parameters, i can “only” adjust the size of the area within the symbol is located.
                                      But it doesn’t change the size of the symbol itself
                                      Thanks a lot
                                        @Vauxdvihl
                                        Did you add this?
                                        Give bigger value for that.(And you need to change value of *-width for adjusting)
                                        • V
                                          Vauxdvihl
                                          @Sean
                                          I am not a programmer :-)
                                          I have played a little bit…also with big values, but the symbol size does not change.
                                          Maybe i am doing something wrong?
                                           * Magic Mirror                                      *
                                           * Custom CSS                                        *
                                           * By Michael Teeuw http://michaelteeuw.nl           *
                                           * MIT Licensed.                                     *
                                           * Add any custom CSS below.                         *
                                           * Changes to this files will be ignored by GIT. *
                                              order:1;
                                              display:block;
                                              flex-basis: 40px; // Modify this
                                              text-align:center;
                                              min-width: 50px; // Modify this
                                              font-size: 800%; // Add this
                                            @Vauxdvihl
                                            Ok. I know what’s the problem. I’ve forgotten emoji belongs different section.
                                            put this in your css.
                                            div.CALEXT .events .symbol.emoji {
                                                font-size: 100%; //Adjust this as your wish. you can use px or %
                                            • 10
                                            • 1 / 10
