    MMM-CalendarExt
    198 Posts 45 Posters 271.8k Views 45 Watching
    • V
      Vauxdvihl
      Thanks a lot
      Both works
      I have a few more questions
      3.)
      Having the month view, it displays me 6 weeks (2 old ones)
      Is there a “screw” where i can change it
      Display “only” 4 weeks and no “old” one
      4.)
      Can i overrite dates and make them to “complete day meetings” (like in your example “Hausmüll”)
      Here in me ical is it a entry from 10 to 11 and in the view “upcoming” there is an entry in the calendar which is viewn as [object Object] ==> Also i want to save some space with a complete date entry
      5.)
      Is there a possibility instead of using symbols to use names?
      Like “Mama” or “Papa”…
      Thanks a lot
        A Former User @Vauxdvihl
        @Vauxdvihl
        3.)
        What did you mean ‘screw’?
        Anyway month view cannot be done for that.
        But you can use ‘daily’ view for that purpose.(with ‘counts:28’) However some css adjusting might be needed for your mirror’s look.
        4.)
        Can you send me your ical file? I need to inspect.
        For fulldayevents, you should have created that events as fullday. Or you could modify event time from 00:00-24:00
        For saving space, see the wiki page. And some css technics would be help.
        5.)
        Well, I think you can prepend or append some text in specific style with css virtual selector(‘:before’).
        Sorry for my non-pragmatic answers.
        I’m not in front of device now, so I cannot make any real solution with real code. During weekends, I have no time for console works. I’ll check your questions again on Monday.
        • V
          Vauxdvihl
          3.)
          With a “screw” i mean something to adjust…no problem ok
          4.)
          Here u are…
          Seems to me i do not have the right to upload here something
          Here is some extract…
          STATUS:CONFIRMED
          END:VEVENT
          BEGIN:VEVENT
          DTSTART:20170201T080000Z
          DTEND:20170201T090000Z
          LOCATION;LANGUAGE=de:, 82343 POECKING
          TRANSP:OPAQUE
          SEQUENCE:0
          UID: 2171943
          DTSTAMP:20171014T081346Z
          DESCRIPTION;LANGUAGE=de:
          SUMMARY;LANGUAGE=de:Restmuelltonne
          PRIORITY:9
          CLASS:PUBLIC
          URL:
          STATUS:CONFIRMED
          END:VEVENT
          BEGIN:VEVENT
          DTSTART:20170215T080000Z
          DTEND:20170215T090000Z
          TRANSP:OPAQUE
          SEQUENCE:0
          UID: 2171944
          PRIORITY:9
          CLASS:PUBLIC
          URL:
          5.)
          Ok,
          i will play a little bit
          • Z
            Zooooooom
            Thank you for a great module! I second @Vauxdvihl about only wanting see the the current week, plus the next 3. Google calendar has that feature. Basically, a clone of the month view, but not starting from the 1st of the month, but from the first day of the current week.
            I tried doing what you suggested with using daily and 28 and it’s close to what I want. But I am only seeing 6 per row. What do I need to modify to make sure I am seeing 7 days?
            Also, is there a way to completely remove the icon and the space for it? I don’t see it in any on the defined styles. I would prefer to have a little more extra breathing room on my fairly narrow monitor.
            Again, thanks for a great module!
              A Former User @Zooooooom
              @Zooooooom I’ll provide some tricks for ‘next 28 days(7 per week) view’ on Monday. It needs some css tricks.
              Your other question also could be considered at that time.
              Thanks for using.
                A Former User
                @Zooooooom @Vauxdvihl
                Here is some ‘next 28 days view’ sample.
                1. Open your css/custom.css and append these code;
                /* CSS adjusting for 28days view */
                /* hide unnecessary components */
                #CALEXT_daily .eventTime,
                #CALEXT_daily .eventLocation,
                #CALEXT_daily .symbol {
                  display:none;
                /* smaller size for events */
                #CALEXT_daily .eventContent {
                  font-size:0.8em;
                  font-weight:normal;
                /* makes "slot" 1/7 of 100% */
                #CALEXT_daily .slot {
                  max-width:13%;
                  flex-basis:13%;
                #CALEXT_daily .slot .header {
                  font-size:0.5em;
                  border-radius:0;
                  font-weight:normal;
                /* add some style sample */
                #CALEXT_daily .style_custom2 {
                  background-color:rgba(255, 127, 255, 1.0);
                /* add some additional content sample */
                #CALEXT_daily .style_custom2 .eventContent::before{
                  content: "[@]";
                1. open your config.js, put these codes.
                      module: 'MMM-CalendarExt',
                      position: "top_center", // ignore this.
                        system: {
                          show: ['daily'],
                          locale: 'en',
                        views: {
                          daily: {
                            position:'bottom_bar',
                            counts:28,
                            //overflowRolling:1,
                            //overflowHeight:50,
                        calendars :[
                            styleName: "style_custom1",
                            oneLineEvent: 1,
                            url: "webcal://www.google.com/calendar/ical/en5624jps9pfbtgsd7op2him0k%40group.calendar.google.com/public/basic.ics",
                            styleName: "style_custom2",
                            //oneLineEvent: 1,
                            url: "webcal://www.google.com/calendar/ical/0efdnrqt4c9qruabf7u33742ps%40group.calendar.google.com/public/basic.ics",
                            styleName: "style_custom3",
                            oneLineEvent: 1,
                            url: "http://ical.grips-theater.de/grips.ics",
                1. You can refer also https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks
                2. Main trick is
                  max-width:13%;
                  flex-basis:13%;
                You might need to adjust the value 13% to your circumstances. Because of margin and padding, 14% might not work.
                1. You can also consider overflow and oneLineEvent and titleReplace for saving spaces.
                Anyway, under 700px width, this could not work. That is too narrow to display 7 slots.
                N 1 Reply Last reply Reply Quote 1
                  @Vauxdvihl said in MMM-CalendarExt:
                  BEGIN:VEVENT
                  TRANSP:OPAQUE
                  SEQUENCE:0
                  UID: 2171943
                  PRIORITY:9
                  CLASS:PUBLIC
                  URL:
                  STATUS:CONFIRMED
                  END:VEVENT
                  I found what’s wrong. you ical location format is slightly different with others.
                  I’ve committed hotfix for that. git pull again and re-run your mirror.
                    A Former User
                    And I also added weeks view for your exact wish. pull new source and see the wiki.
                    So, you have two options.
                    28days view
                    vs
                    4weeks view.
                    both are slightly different. 28days always starts from today. 4weeks always starts from weekday(0) - Monday or Sunday - of this week.
                    Use anything you want.
                    Z 1 Reply Last reply Reply Quote 1
                    • Z
                      Zooooooom @Guest
                      @Sean Beautiful! Exactly what I wanted.
                      • V
                        Vauxdvihl
                        Great Job
                        Thanks a lot
                        • V
                          Vauxdvihl
                          Hi Sean,
                          i have a few more questions
                          Please look to my attached screen:
                          a.)
                          Today is “not viewable” because it is “more or less” complete white
                          Any Idea
                          b.)
                          Is there a chance to increase the size of the symbols (i mean the symbols in front of the date…like the football)
                          c.)
                          I was wondering that your dates a looking a little bit different
                          In your dates you have the information about the timing and the location.
                          I have put the same infos in my google calendar but they will not be shown
                          Thats a lot
                            a.)
                            Any Idea
                            That is my fault. After some CSS test, my experimental CSS was committed by accident, I thought.
                            I’ll fix it ASAP.(after answer of this)
                            b.)
                            in your css/custom.css
                            you can put these;
                            div.CALEXT  .event .symbol {
                                order:1;
                                display:block;
                                flex-basis: 30px; // Modify this
                                text-align:center;
                                min-width: 30px; // Modify this
                                font-size: 150%; // Add this
                            c.)
                            Thats a lot
                            This is also same with answer of a). Sorry again.
                              @Vauxdvihl
                              I think I’ve fixed it. pull the source and try again.
                              • V
                                Vauxdvihl
                                Amazing
                                Thanks a lot
                                • V
                                  Vauxdvihl
                                  Hi Sean,
                                  according to b.)
                                  Sorry to asked again.
                                  While playing a little bit with the config parameters, i can “only” adjust the size of the area within the symbol is located.
                                  But it doesn’t change the size of the symbol itself
                                  Thanks a lot
                                    @Vauxdvihl
                                    Did you add this?
                                    Give bigger value for that.(And you need to change value of *-width for adjusting)
                                    • V
                                      Vauxdvihl
                                      @Sean
                                      I am not a programmer :-)
                                      I have played a little bit…also with big values, but the symbol size does not change.
                                      Maybe i am doing something wrong?
                                       * Magic Mirror                                      *
                                       * Custom CSS                                        *
                                       * By Michael Teeuw http://michaelteeuw.nl           *
                                       * MIT Licensed.                                     *
                                       * Add any custom CSS below.                         *
                                       * Changes to this files will be ignored by GIT. *
                                          order:1;
                                          display:block;
                                          flex-basis: 40px; // Modify this
                                          text-align:center;
                                          min-width: 50px; // Modify this
                                          font-size: 800%; // Add this
                                        @Vauxdvihl
                                        Ok. I know what’s the problem. I’ve forgotten emoji belongs different section.
                                        put this in your css.
                                        div.CALEXT .events .symbol.emoji {
                                            font-size: 100%; //Adjust this as your wish. you can use px or %
                                        • V
                                          Vauxdvihl
                                          @Sean
                                          Perfect for some symbols
                                          But the symbol “trash-o” will be not “re-sized”.
                                          I have to look for a symbol in other sources == > “em”…and so on
                                            @Vauxdvihl
                                            for emoji(@em) size, see my last answer.
                                            for FA and MD (default and @fa & @md) sizes are related to my previous answer.
                                            • 10
                                            • 1 / 10
