    MMM-CalendarExt
    198 Posts 45 Posters 265.3k Views 45 Watching
      A Former User @Vauxdvihl
      @Vauxdvihl said in MMM-CalendarExt:
      BEGIN:VEVENT
      DTSTART:20170201T080000Z
      DTEND:20170201T090000Z
      LOCATION;LANGUAGE=de:, 82343 POECKING
      TRANSP:OPAQUE
      SEQUENCE:0
      UID: 2171943
      DTSTAMP:20171014T081346Z
      DESCRIPTION;LANGUAGE=de:
      SUMMARY;LANGUAGE=de:Restmuelltonne
      PRIORITY:9
      CLASS:PUBLIC
      URL:
      STATUS:CONFIRMED
      END:VEVENT
      I found what’s wrong. you ical location format is slightly different with others.
      I’ve committed hotfix for that. git pull again and re-run your mirror.
        A Former User
        @Zooooooom @Vauxdvihl
        And I also added weeks view for your exact wish. pull new source and see the wiki.
        So, you have two options.
        28days view
        vs
        4weeks view.
        both are slightly different. 28days always starts from today. 4weeks always starts from weekday(0) - Monday or Sunday - of this week.
        Use anything you want.
        Z 1 Reply Last reply Reply Quote 1
        • Z Offline
          Zooooooom @Guest
          @Sean Beautiful! Exactly what I wanted.
          • V Offline
            Vauxdvihl
            Great Job
            Thanks a lot
            • V Offline
              Vauxdvihl
              Hi Sean,
              i have a few more questions
              Please look to my attached screen:
              a.)
              Today is “not viewable” because it is “more or less” complete white
              Any Idea
              b.)
              Is there a chance to increase the size of the symbols (i mean the symbols in front of the date…like the football)
              c.)
              I was wondering that your dates a looking a little bit different
              In your dates you have the information about the timing and the location.
              I have put the same infos in my google calendar but they will not be shown
              Thats a lot
                a.)
                Any Idea
                That is my fault. After some CSS test, my experimental CSS was committed by accident, I thought.
                I’ll fix it ASAP.(after answer of this)
                b.)
                in your css/custom.css
                you can put these;
                div.CALEXT  .event .symbol {
                    order:1;
                    display:block;
                    flex-basis: 30px; // Modify this
                    text-align:center;
                    min-width: 30px; // Modify this
                    font-size: 150%; // Add this
                c.)
                Thats a lot
                This is also same with answer of a). Sorry again.
                  @Vauxdvihl
                  I think I’ve fixed it. pull the source and try again.
                  • V Offline
                    Vauxdvihl
                    Amazing
                    Thanks a lot
                    • V Offline
                      Vauxdvihl
                      Hi Sean,
                      according to b.)
                      Sorry to asked again.
                      While playing a little bit with the config parameters, i can “only” adjust the size of the area within the symbol is located.
                      But it doesn’t change the size of the symbol itself
                      Thanks a lot
                        @Vauxdvihl
                        Did you add this?
                        Give bigger value for that.(And you need to change value of *-width for adjusting)
                        • V Offline
                          Vauxdvihl
                          @Sean
                          I am not a programmer :-)
                          I have played a little bit…also with big values, but the symbol size does not change.
                          Maybe i am doing something wrong?
                           * Magic Mirror                                      *
                           * Custom CSS                                        *
                           * By Michael Teeuw http://michaelteeuw.nl           *
                           * MIT Licensed.                                     *
                           * Add any custom CSS below.                         *
                           * Changes to this files will be ignored by GIT. *
                              order:1;
                              display:block;
                              flex-basis: 40px; // Modify this
                              text-align:center;
                              min-width: 50px; // Modify this
                              font-size: 800%; // Add this
                            @Vauxdvihl
                            Ok. I know what’s the problem. I’ve forgotten emoji belongs different section.
                            put this in your css.
                            div.CALEXT .events .symbol.emoji {
                                font-size: 100%; //Adjust this as your wish. you can use px or %
                            • V Offline
                              Vauxdvihl
                              @Sean
                              Perfect for some symbols
                              But the symbol “trash-o” will be not “re-sized”.
                              I have to look for a symbol in other sources == > “em”…and so on
                                @Vauxdvihl
                                for emoji(@em) size, see my last answer.
                                for FA and MD (default and @fa & @md) sizes are related to my previous answer.
                                • V Offline
                                  Vauxdvihl
                                  @Sean
                                  It works fine with adding this code to custom css :-)
                                  div.CALEXT .events .symbol.font-awesome {
                                      font-size: 250%; //Adjust this as your wish. you can use px or %
                                    @Vauxdvihl Ye… Maybe that’s another solution. :)
                                    • V Offline
                                      Vauxdvihl
                                      @Sean
                                      Sorry again but i have another question / problem
                                      You can see in my above standing screens that split view => current / upcoming does not work.
                                      But before doing the update it was working.
                                      Here is my config code
                                      				module: 'MMM-CalendarExt',
                                      				position: "lower_third", //anywhere. It is not related to real position of view
                                      				config: { // Read below
                                      				system: {
                                      				  show: ['current','upcoming','daily'],
                                      				  locale: 'de', //when omitted, default value would be your system default locale by moment.js
                                      				  showEmptyView: 0,
                                      				  fullDayEventLocalize: 1,
                                      				  redrawInterval: 30*60*1000, //minimum 60000
                                      				  useProfileConfig: 0,
                                      				  startProfile: ''
                                      				 views: {
                                      						current: {
                                      						  title: "Heute",
                                      						  limit: 3,
                                      						upcoming: {
                                      						  title: "Demnächst",
                                      						  limit: 3,
                                      						daily: {
                                      						  position: "bottom_bar",
                                      						  title: "Überblick",
                                      						  counts: 7,
                                      • V Offline
                                        Vauxdvihl
                                        @Sean
                                        it is me again.
                                        After having everything running, my wife wants to have the view “weekly” with 2 counts.
                                        Now i have the “problem”, that i search for the config parameter which allows also to see the timings in this view (like 08:00-10:00 …and so on)
                                        Is it possible in the “weekly” view?
                                        Thanks again for your support and help
                                          @Vauxdvihl
                                          Yes possible.
                                          Put this code in your css.
                                          div.CALEXT .tableStyle .eventTime {
                                              display:block;
                                          I’m not on the console on weekends, so i didnt test it, but i think it will work.
                                          Ps. that view is not ‘weekly’. It is ‘weeks’
                                          • V Offline
                                            Vauxdvihl
                                            @Sean
                                            Yes you are right…it is the view "weeks
                                            Now i have in the appointment also the date within…it looks a little bit twice…because the date is also within the header of the week…
                                            May be you can help me
                                            Thanks a lot
                                            • 10
                                            • 1 / 10
