    MMM-CalendarExt
    198 Posts 45 Posters 276.6k Views 45 Watching
      A Former User
      @Zooooooom @Vauxdvihl
      Here is some ‘next 28 days view’ sample.
      1. Open your css/custom.css and append these code;
      /* CSS adjusting for 28days view */
      /* hide unnecessary components */
      #CALEXT_daily .eventTime,
      #CALEXT_daily .eventLocation,
      #CALEXT_daily .symbol {
        display:none;
      /* smaller size for events */
      #CALEXT_daily .eventContent {
        font-size:0.8em;
        font-weight:normal;
      /* makes "slot" 1/7 of 100% */
      #CALEXT_daily .slot {
        max-width:13%;
        flex-basis:13%;
      #CALEXT_daily .slot .header {
        font-size:0.5em;
        border-radius:0;
        font-weight:normal;
      /* add some style sample */
      #CALEXT_daily .style_custom2 {
        background-color:rgba(255, 127, 255, 1.0);
      /* add some additional content sample */
      #CALEXT_daily .style_custom2 .eventContent::before{
        content: "[@]";
      1. open your config.js, put these codes.
            module: 'MMM-CalendarExt',
            position: "top_center", // ignore this.
              system: {
                show: ['daily'],
                locale: 'en',
              views: {
                daily: {
                  position:'bottom_bar',
                  counts:28,
                  //overflowRolling:1,
                  //overflowHeight:50,
              calendars :[
                  styleName: "style_custom1",
                  oneLineEvent: 1,
                  url: "webcal://www.google.com/calendar/ical/en5624jps9pfbtgsd7op2him0k%40group.calendar.google.com/public/basic.ics",
                  styleName: "style_custom2",
                  //oneLineEvent: 1,
                  url: "webcal://www.google.com/calendar/ical/0efdnrqt4c9qruabf7u33742ps%40group.calendar.google.com/public/basic.ics",
                  styleName: "style_custom3",
                  oneLineEvent: 1,
                  url: "http://ical.grips-theater.de/grips.ics",
      1. You can refer also https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks
      2. Main trick is
        max-width:13%;
        flex-basis:13%;
      You might need to adjust the value 13% to your circumstances. Because of margin and padding, 14% might not work.
      1. You can also consider overflow and oneLineEvent and titleReplace for saving spaces.
      Anyway, under 700px width, this could not work. That is too narrow to display 7 slots.
      N 1 Reply Last reply
        A Former User @Vauxdvihl
        @Vauxdvihl said in MMM-CalendarExt:
        BEGIN:VEVENT
        DTSTART:20170201T080000Z
        DTEND:20170201T090000Z
        LOCATION;LANGUAGE=de:, 82343 POECKING
        TRANSP:OPAQUE
        SEQUENCE:0
        UID: 2171943
        DTSTAMP:20171014T081346Z
        DESCRIPTION;LANGUAGE=de:
        SUMMARY;LANGUAGE=de:Restmuelltonne
        PRIORITY:9
        CLASS:PUBLIC
        URL:
        STATUS:CONFIRMED
        END:VEVENT
        I found what’s wrong. you ical location format is slightly different with others.
        I’ve committed hotfix for that. git pull again and re-run your mirror.
          A Former User
          And I also added weeks view for your exact wish. pull new source and see the wiki.
          So, you have two options.
          28days view
          vs
          4weeks view.
          both are slightly different. 28days always starts from today. 4weeks always starts from weekday(0) - Monday or Sunday - of this week.
          Use anything you want.
          Z 1 Reply Last reply
          • Z
            Zooooooom @Guest
            @Sean Beautiful! Exactly what I wanted.
            • V
              Vauxdvihl
              Great Job
              Thanks a lot
              • V
                Vauxdvihl
                Hi Sean,
                i have a few more questions
                Please look to my attached screen:
                a.)
                Today is “not viewable” because it is “more or less” complete white
                Any Idea
                b.)
                Is there a chance to increase the size of the symbols (i mean the symbols in front of the date…like the football)
                c.)
                I was wondering that your dates a looking a little bit different
                In your dates you have the information about the timing and the location.
                I have put the same infos in my google calendar but they will not be shown
                Thats a lot
                ? 2 Replies Last reply
                  a.)
                  Any Idea
                  That is my fault. After some CSS test, my experimental CSS was committed by accident, I thought.
                  I’ll fix it ASAP.(after answer of this)
                  b.)
                  in your css/custom.css
                  you can put these;
                  div.CALEXT  .event .symbol {
                      order:1;
                      display:block;
                      flex-basis: 30px; // Modify this
                      text-align:center;
                      min-width: 30px; // Modify this
                      font-size: 150%; // Add this
                  c.)
                  Thats a lot
                  This is also same with answer of a). Sorry again.
                    @Vauxdvihl
                    I think I’ve fixed it. pull the source and try again.
                    • V
                      Vauxdvihl
                      Amazing
                      Thanks a lot
                      • V
                        Vauxdvihl
                        Hi Sean,
                        according to b.)
                        Sorry to asked again.
                        While playing a little bit with the config parameters, i can “only” adjust the size of the area within the symbol is located.
                        But it doesn’t change the size of the symbol itself
                        Thanks a lot
                        ? 1 Reply Last reply
                          @Vauxdvihl
                          Did you add this?
                          Give bigger value for that.(And you need to change value of *-width for adjusting)
                          • V
                            Vauxdvihl
                            @Sean
                            I am not a programmer :-)
                            I have played a little bit…also with big values, but the symbol size does not change.
                            Maybe i am doing something wrong?
                             * Magic Mirror                                      *
                             * Custom CSS                                        *
                             * By Michael Teeuw http://michaelteeuw.nl           *
                             * MIT Licensed.                                     *
                             * Add any custom CSS below.                         *
                             * Changes to this files will be ignored by GIT. *
                                order:1;
                                display:block;
                                flex-basis: 40px; // Modify this
                                text-align:center;
                                min-width: 50px; // Modify this
                                font-size: 800%; // Add this
                              @Vauxdvihl
                              Ok. I know what’s the problem. I’ve forgotten emoji belongs different section.
                              put this in your css.
                              div.CALEXT .events .symbol.emoji {
                                  font-size: 100%; //Adjust this as your wish. you can use px or %
                              • V
                                Vauxdvihl
                                @Sean
                                Perfect for some symbols
                                But the symbol “trash-o” will be not “re-sized”.
                                I have to look for a symbol in other sources == > “em”…and so on
                                  @Vauxdvihl
                                  for emoji(@em) size, see my last answer.
                                  for FA and MD (default and @fa & @md) sizes are related to my previous answer.
                                  • V
                                    Vauxdvihl
                                    @Sean
                                    It works fine with adding this code to custom css :-)
                                    div.CALEXT .events .symbol.font-awesome {
                                        font-size: 250%; //Adjust this as your wish. you can use px or %
                                      @Vauxdvihl Ye… Maybe that’s another solution. :)
                                      • V
                                        Vauxdvihl
                                        @Sean
                                        Sorry again but i have another question / problem
                                        You can see in my above standing screens that split view => current / upcoming does not work.
                                        But before doing the update it was working.
                                        Here is my config code
                                        				position: "lower_third", //anywhere. It is not related to real position of view
                                        				config: { // Read below
                                        				system: {
                                        				  show: ['current','upcoming','daily'],
                                        				  locale: 'de', //when omitted, default value would be your system default locale by moment.js
                                        				  showEmptyView: 0,
                                        				  fullDayEventLocalize: 1,
                                        				  redrawInterval: 30*60*1000, //minimum 60000
                                        				  useProfileConfig: 0,
                                        				  startProfile: ''
                                        				 views: {
                                        						current: {
                                        						  title: "Heute",
                                        						  limit: 3,
                                        						upcoming: {
                                        						  title: "Demnächst",
                                        						  limit: 3,
                                        						daily: {
                                        						  position: "bottom_bar",
                                        						  title: "Überblick",
                                        						  counts: 7,
                                        • V
                                          Vauxdvihl
                                          @Sean
                                          it is me again.
                                          After having everything running, my wife wants to have the view “weekly” with 2 counts.
                                          Now i have the “problem”, that i search for the config parameter which allows also to see the timings in this view (like 08:00-10:00 …and so on)
                                          Is it possible in the “weekly” view?
                                          Thanks again for your support and help
                                            @Vauxdvihl
                                            Yes possible.
                                            Put this code in your css.
                                            div.CALEXT .tableStyle .eventTime {
                                                display:block;
                                            I’m not on the console on weekends, so i didnt test it, but i think it will work.
                                            Ps. that view is not ‘weekly’. It is ‘weeks’
                                            • 10
                                            • 1 / 10
