    MMM-CalendarExt
    198 Posts 45 Posters 276.1k Views 45 Watching
    • Z
      Zooooooom @Guest
      @Sean Beautiful! Exactly what I wanted.
      • V
        Vauxdvihl
        Great Job
        Thanks a lot
        • V
          Vauxdvihl
          Hi Sean,
          i have a few more questions
          Please look to my attached screen:
          a.)
          Today is “not viewable” because it is “more or less” complete white
          Any Idea
          b.)
          Is there a chance to increase the size of the symbols (i mean the symbols in front of the date…like the football)
          c.)
          I was wondering that your dates a looking a little bit different
          In your dates you have the information about the timing and the location.
          I have put the same infos in my google calendar but they will not be shown
          Thats a lot
          ? 2 Replies Last reply
            A Former User @Vauxdvihl
            a.)
            Any Idea
            That is my fault. After some CSS test, my experimental CSS was committed by accident, I thought.
            I’ll fix it ASAP.(after answer of this)
            b.)
            in your css/custom.css
            you can put these;
            div.CALEXT  .event .symbol {
                order:1;
                display:block;
                flex-basis: 30px; // Modify this
                text-align:center;
                min-width: 30px; // Modify this
                font-size: 150%; // Add this
            c.)
            Thats a lot
            This is also same with answer of a). Sorry again.
              @Vauxdvihl
              I think I’ve fixed it. pull the source and try again.
              • V
                Vauxdvihl
                Amazing
                Thanks a lot
                • V
                  Vauxdvihl
                  Hi Sean,
                  according to b.)
                  Sorry to asked again.
                  While playing a little bit with the config parameters, i can “only” adjust the size of the area within the symbol is located.
                  But it doesn’t change the size of the symbol itself
                  Thanks a lot
                  ? 1 Reply Last reply
                    @Vauxdvihl
                    Did you add this?
                    Give bigger value for that.(And you need to change value of *-width for adjusting)
                    • V
                      Vauxdvihl
                      @Sean
                      I am not a programmer :-)
                      I have played a little bit…also with big values, but the symbol size does not change.
                      Maybe i am doing something wrong?
                       * Magic Mirror                                      *
                       * Custom CSS                                        *
                       * By Michael Teeuw http://michaelteeuw.nl           *
                       * MIT Licensed.                                     *
                       * Add any custom CSS below.                         *
                       * Changes to this files will be ignored by GIT. *
                          order:1;
                          display:block;
                          flex-basis: 40px; // Modify this
                          text-align:center;
                          min-width: 50px; // Modify this
                          font-size: 800%; // Add this
                        @Vauxdvihl
                        Ok. I know what’s the problem. I’ve forgotten emoji belongs different section.
                        put this in your css.
                        div.CALEXT .events .symbol.emoji {
                            font-size: 100%; //Adjust this as your wish. you can use px or %
                        • V
                          Vauxdvihl
                          @Sean
                          Perfect for some symbols
                          But the symbol “trash-o” will be not “re-sized”.
                          I have to look for a symbol in other sources == > “em”…and so on
                            @Vauxdvihl
                            for emoji(@em) size, see my last answer.
                            for FA and MD (default and @fa & @md) sizes are related to my previous answer.
                            • V
                              Vauxdvihl
                              @Sean
                              It works fine with adding this code to custom css :-)
                              div.CALEXT .events .symbol.font-awesome {
                                  font-size: 250%; //Adjust this as your wish. you can use px or %
                                @Vauxdvihl Ye… Maybe that’s another solution. :)
                                • V
                                  Vauxdvihl
                                  @Sean
                                  Sorry again but i have another question / problem
                                  You can see in my above standing screens that split view => current / upcoming does not work.
                                  But before doing the update it was working.
                                  Here is my config code
                                  				module: 'MMM-CalendarExt',
                                  				position: "lower_third", //anywhere. It is not related to real position of view
                                  				config: { // Read below
                                  				system: {
                                  				  show: ['current','upcoming','daily'],
                                  				  locale: 'de', //when omitted, default value would be your system default locale by moment.js
                                  				  showEmptyView: 0,
                                  				  fullDayEventLocalize: 1,
                                  				  redrawInterval: 30*60*1000, //minimum 60000
                                  				  useProfileConfig: 0,
                                  				  startProfile: ''
                                  				 views: {
                                  						current: {
                                  						  title: "Heute",
                                  						  limit: 3,
                                  						upcoming: {
                                  						  title: "Demnächst",
                                  						  limit: 3,
                                  						daily: {
                                  						  position: "bottom_bar",
                                  						  title: "Überblick",
                                  						  counts: 7,
                                  • V
                                    Vauxdvihl
                                    @Sean
                                    it is me again.
                                    After having everything running, my wife wants to have the view “weekly” with 2 counts.
                                    Now i have the “problem”, that i search for the config parameter which allows also to see the timings in this view (like 08:00-10:00 …and so on)
                                    Is it possible in the “weekly” view?
                                    Thanks again for your support and help
                                      @Vauxdvihl
                                      Yes possible.
                                      Put this code in your css.
                                      div.CALEXT .tableStyle .eventTime {
                                          display:block;
                                      I’m not on the console on weekends, so i didnt test it, but i think it will work.
                                      Ps. that view is not ‘weekly’. It is ‘weeks’
                                      • V
                                        Vauxdvihl
                                        @Sean
                                        Yes you are right…it is the view "weeks
                                        Now i have in the appointment also the date within…it looks a little bit twice…because the date is also within the header of the week…
                                        May be you can help me
                                        Thanks a lot
                                          @Vauxdvihl
                                          Maybe on Monday I’ll provide you a patch about that.
                                          In ‘Month’ and ‘weeks’ view, I assume nobody needs exact time, because those views might have too many events to show with time. So I I’ve thought time displaying is needed in only daily, upcoming, current.
                                          Anyway, I’ll follow opinion of my real users. :)
                                            @Vauxdvihl
                                            I’ve finished the patch, re-pull the source and try again.
                                            • 10
                                            • 2 / 10
