    MMM-CalendarExt
    198 Posts 45 Posters 276.1k Views 45 Watching
      A Former User @Vauxdvihl
      a.)
      Today is “not viewable” because it is “more or less” complete white
      Any Idea
      That is my fault. After some CSS test, my experimental CSS was committed by accident, I thought.
      I’ll fix it ASAP.(after answer of this)
      b.)
      Is there a chance to increase the size of the symbols (i mean the symbols in front of the date…like the football)
      in your css/custom.css
      you can put these;
      div.CALEXT  .event .symbol {
          order:1;
          display:block;
          flex-basis: 30px; // Modify this
          text-align:center;
          min-width: 30px; // Modify this
          font-size: 150%; // Add this
      c.)
      I was wondering that your dates a looking a little bit different
      In your dates you have the information about the timing and the location.
      I have put the same infos in my google calendar but they will not be shown
      Thats a lot
      This is also same with answer of a). Sorry again.
        @Vauxdvihl
        I think I’ve fixed it. pull the source and try again.
        • V
          Vauxdvihl
          Amazing
          Thanks a lot
          • V
            Vauxdvihl
            Hi Sean,
            according to b.)
            Sorry to asked again.
            While playing a little bit with the config parameters, i can “only” adjust the size of the area within the symbol is located.
            But it doesn’t change the size of the symbol itself
            Thanks a lot
            ? 1 Reply Last reply
              @Vauxdvihl
              Did you add this?
              Give bigger value for that.(And you need to change value of *-width for adjusting)
              • V
                Vauxdvihl
                @Sean
                I am not a programmer :-)
                I have played a little bit…also with big values, but the symbol size does not change.
                Maybe i am doing something wrong?
                 * Magic Mirror                                      *
                 * Custom CSS                                        *
                 * By Michael Teeuw http://michaelteeuw.nl           *
                 * MIT Licensed.                                     *
                 * Add any custom CSS below.                         *
                 * Changes to this files will be ignored by GIT. *
                    order:1;
                    display:block;
                    flex-basis: 40px; // Modify this
                    text-align:center;
                    min-width: 50px; // Modify this
                    font-size: 800%; // Add this
                  @Vauxdvihl
                  Ok. I know what’s the problem. I’ve forgotten emoji belongs different section.
                  put this in your css.
                  div.CALEXT .events .symbol.emoji {
                      font-size: 100%; //Adjust this as your wish. you can use px or %
                  • V
                    Vauxdvihl
                    @Sean
                    Perfect for some symbols
                    But the symbol “trash-o” will be not “re-sized”.
                    I have to look for a symbol in other sources == > “em”…and so on
                      @Vauxdvihl
                      for emoji(@em) size, see my last answer.
                      for FA and MD (default and @fa & @md) sizes are related to my previous answer.
                      • V
                        Vauxdvihl
                        @Sean
                        It works fine with adding this code to custom css :-)
                        div.CALEXT .events .symbol.font-awesome {
                            font-size: 250%; //Adjust this as your wish. you can use px or %
                          @Vauxdvihl Ye… Maybe that’s another solution. :)
                          • V
                            Vauxdvihl
                            @Sean
                            Sorry again but i have another question / problem
                            You can see in my above standing screens that split view => current / upcoming does not work.
                            But before doing the update it was working.
                            Here is my config code
                            				module: 'MMM-CalendarExt',
                            				position: "lower_third", //anywhere. It is not related to real position of view
                            				config: { // Read below
                            				system: {
                            				  show: ['current','upcoming','daily'],
                            				  locale: 'de', //when omitted, default value would be your system default locale by moment.js
                            				  showEmptyView: 0,
                            				  fullDayEventLocalize: 1,
                            				  redrawInterval: 30*60*1000, //minimum 60000
                            				  useProfileConfig: 0,
                            				  startProfile: ''
                            				 views: {
                            						current: {
                            						  title: "Heute",
                            						  limit: 3,
                            						upcoming: {
                            						  title: "Demnächst",
                            						  limit: 3,
                            						daily: {
                            						  position: "bottom_bar",
                            						  title: "Überblick",
                            						  counts: 7,
                            • V
                              Vauxdvihl
                              @Sean
                              it is me again.
                              After having everything running, my wife wants to have the view “weekly” with 2 counts.
                              Now i have the “problem”, that i search for the config parameter which allows also to see the timings in this view (like 08:00-10:00 …and so on)
                              Is it possible in the “weekly” view?
                              Thanks again for your support and help
                              ? 2 Replies Last reply
                                @Vauxdvihl
                                Yes possible.
                                Put this code in your css.
                                div.CALEXT .tableStyle .eventTime {
                                    display:block;
                                I’m not on the console on weekends, so i didnt test it, but i think it will work.
                                Ps. that view is not ‘weekly’. It is ‘weeks’
                                • V
                                  Vauxdvihl
                                  @Sean
                                  Yes you are right…it is the view "weeks
                                  Now i have in the appointment also the date within…it looks a little bit twice…because the date is also within the header of the week…
                                  May be you can help me
                                  Thanks a lot
                                    @Vauxdvihl
                                    Maybe on Monday I’ll provide you a patch about that.
                                    In ‘Month’ and ‘weeks’ view, I assume nobody needs exact time, because those views might have too many events to show with time. So I I’ve thought time displaying is needed in only daily, upcoming, current.
                                    Anyway, I’ll follow opinion of my real users. :)
                                      @Vauxdvihl
                                      I’ve finished the patch, re-pull the source and try again.
                                      • V
                                        Vauxdvihl
                                        Thanks a lot
                                        It works
                                        • cowboysdudeC
                                          @Sean this is THE best calendar module by far…awesome job!
                                            Phil_T
                                            @Sean First of all, great work! This module was exactly what I was looking for.
                                            I´ve been tinkering with it for about a day now and I got a few small issues.
                                            1. Unfortunately I can´t get this (https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics) calendar to show, any suggestions?
                                            2. As you can see on the screenshot below, there is quite some space left for calendar to use. Any tips on how can designate all this void area for the calendar?
                                            3. I can´t seem to enable the event time (eg. 17:00-19:00 next to the event title), what might be the problem here?
                                            Thanks a lot for the help!
                                            • 10
                                            • 2 / 10
