    MMM-CalendarExt
    198 Posts 45 Posters 276.1k Views 45 Watching
    • V
      Vauxdvihl
      Amazing
      Thanks a lot
      • V
        Vauxdvihl
        Hi Sean,
        according to b.)
        Sorry to asked again.
        While playing a little bit with the config parameters, i can “only” adjust the size of the area within the symbol is located.
        But it doesn’t change the size of the symbol itself
        Thanks a lot
        ? 1 Reply Last reply
          A Former User @Vauxdvihl
          @Vauxdvihl
          Did you add this?
           font-size: 150%; // Add this
          Give bigger value for that.(And you need to change value of *-width for adjusting)
          • V
            Vauxdvihl
            @Sean
            I am not a programmer :-)
            I have played a little bit…also with big values, but the symbol size does not change.
            Maybe i am doing something wrong?
             * Magic Mirror                                      *
             * Custom CSS                                        *
             * By Michael Teeuw http://michaelteeuw.nl           *
             * MIT Licensed.                                     *
             * Add any custom CSS below.                         *
             * Changes to this files will be ignored by GIT. *
             div.CALEXT  .event .symbol {
                order:1;
                display:block;
                flex-basis: 40px; // Modify this
                text-align:center;
                min-width: 50px; // Modify this
                font-size: 800%; // Add this
              @Vauxdvihl
              Ok. I know what’s the problem. I’ve forgotten emoji belongs different section.
              put this in your css.
              div.CALEXT .events .symbol.emoji {
                  font-size: 100%; //Adjust this as your wish. you can use px or %
              • V
                Vauxdvihl
                @Sean
                Perfect for some symbols
                But the symbol “trash-o” will be not “re-sized”.
                I have to look for a symbol in other sources == > “em”…and so on
                  @Vauxdvihl
                  for emoji(@em) size, see my last answer.
                  for FA and MD (default and @fa & @md) sizes are related to my previous answer.
                  • V
                    Vauxdvihl
                    @Sean
                    It works fine with adding this code to custom css :-)
                    div.CALEXT .events .symbol.font-awesome {
                        font-size: 250%; //Adjust this as your wish. you can use px or %
                      @Vauxdvihl Ye… Maybe that’s another solution. :)
                      • V
                        Vauxdvihl
                        @Sean
                        Sorry again but i have another question / problem
                        You can see in my above standing screens that split view => current / upcoming does not work.
                        But before doing the update it was working.
                        Here is my config code
                        				module: 'MMM-CalendarExt',
                        				position: "lower_third", //anywhere. It is not related to real position of view
                        				config: { // Read below
                        				system: {
                        				  show: ['current','upcoming','daily'],
                        				  locale: 'de', //when omitted, default value would be your system default locale by moment.js
                        				  showEmptyView: 0,
                        				  fullDayEventLocalize: 1,
                        				  redrawInterval: 30*60*1000, //minimum 60000
                        				  useProfileConfig: 0,
                        				  startProfile: ''
                        				 views: {
                        						current: {
                        						  title: "Heute",
                        						  limit: 3,
                        						upcoming: {
                        						  title: "Demnächst",
                        						  limit: 3,
                        						daily: {
                        						  position: "bottom_bar",
                        						  title: "Überblick",
                        						  counts: 7,
                        • V
                          Vauxdvihl
                          @Sean
                          it is me again.
                          After having everything running, my wife wants to have the view “weekly” with 2 counts.
                          Now i have the “problem”, that i search for the config parameter which allows also to see the timings in this view (like 08:00-10:00 …and so on)
                          Is it possible in the “weekly” view?
                          Thanks again for your support and help
                          ? 2 Replies Last reply
                            @Vauxdvihl
                            Yes possible.
                            Put this code in your css.
                            div.CALEXT .tableStyle .eventTime {
                                display:block;
                            I’m not on the console on weekends, so i didnt test it, but i think it will work.
                            Ps. that view is not ‘weekly’. It is ‘weeks’
                            • V
                              Vauxdvihl
                              @Sean
                              Yes you are right…it is the view "weeks
                              Now i have in the appointment also the date within…it looks a little bit twice…because the date is also within the header of the week…
                              May be you can help me
                              Thanks a lot
                                @Vauxdvihl
                                Maybe on Monday I’ll provide you a patch about that.
                                In ‘Month’ and ‘weeks’ view, I assume nobody needs exact time, because those views might have too many events to show with time. So I I’ve thought time displaying is needed in only daily, upcoming, current.
                                Anyway, I’ll follow opinion of my real users. :)
                                  @Vauxdvihl
                                  I’ve finished the patch, re-pull the source and try again.
                                  • V
                                    Vauxdvihl
                                    Thanks a lot
                                    It works
                                    • cowboysdudeC
                                      @Sean this is THE best calendar module by far…awesome job!
                                        Phil_T
                                        @Sean First of all, great work! This module was exactly what I was looking for.
                                        I´ve been tinkering with it for about a day now and I got a few small issues.
                                        1. Unfortunately I can´t get this (https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics) calendar to show, any suggestions?
                                        2. As you can see on the screenshot below, there is quite some space left for calendar to use. Any tips on how can designate all this void area for the calendar?
                                        3. I can´t seem to enable the event time (eg. 17:00-19:00 next to the event title), what might be the problem here?
                                        Thanks a lot for the help!
                                          A Former User @Phil_T
                                          @Phil_T said in MMM-CalendarExt:
                                          Has it “Erster Advent” on 3 December? I can see that event.
                                          Did you mean whole calendar area? or each event?
                                          for whole calendar area; Add this code to your css/custom.css
                                          .CALEXT div.tableStyle {
                                           width:100%;
                                          Well, I assumed in month view and weeks view people might not need exact time, (Mirror is too small to display many things), So I disabled it by default.
                                          Add this to your css/custom.css
                                          div.CALEXT div.tableStyle div.eventContainer div.eventTime {
                                            display:block;
                                            Phil_T
                                            Thanks a lot for the quick response!
                                            There should also be “Mariä Empfängnis” on the 8th of December, which isnt showing (maybe a problem with ä, ö and ü?).
                                            Sorry for my confusing explanation. I meant for the calendar to cover the whole screen apart from a bar at the top for time and weather.
                                            Thanks, the time is showing.
                                            edit: furthermore, how can I stop the module from cutting off the bottom part?
                                            • 10
                                            • 2 / 10
