    MMM-CalendarExt
    198 Posts 45 Posters 267.5k Views 45 Watching
      dolszews89
      I can´t seem to enable the event time (eg. 17:00-19:00 next to the event title), what might be the problem here?
      Well, I assumed in month view and weeks view people might not need exact time, (Mirror is too small to display many things), So I disabled it by default.
      Add this to your css/custom.css
      div.CALEXT div.tableStyle div.eventContainer div.eventTime {
        display:block;
      This is from a while ago but I am running into a problem. I would also like to add time stamps to my month view. I have add the recommended code to the end of my custom.css file but the time stamps still do not appear. Should be code refer to the “month” view somewhere?
      • ? Offline
        A Former User @dolszews89
        @dolszews89
        I don’t recommend to display event time on tableStyle (weeks, month), but if you want,
        Add this into your css/custom.css
        .CALEXT .tableStyle .eventTime {
          display:block;
          font-size:10px;
        .CALEXT .tableStyle .fulldayevent  .eventTime {
          display:block;
          font-size:10px;
        PS : There is no other modification in my css/custom.css
          migitcheetah
          Is there a way to set my month view to start on Monday instead of Sunday? I have events that are Monday through Sunsay, and would like to avoid them wrapping from one line to the next, and instead have them on one single line from Monday to Sunday.
          • ? Offline
            A Former User @migitcheetah
            @migitcheetah
            It depends on your locale.
              migitcheetah @Guest
              @Sean ok,
              How would I know which locals have a monday start date, and would that change the entire mirrors language? Can I change local just for the calendar?
              • ? Offline
                @migitcheetah
                So, what is your default language of MM?
                https://github.com/eouia/MMM-CalendarExt/wiki/Configuration#system
                If you are using English, use en-GB. In UK, a week would start from Monday. (but in US, starts from Sunday.)
                  migitcheetah @Guest
                  @Sean thanks!
                  My default language is English US.
                  So I was looking at the calendar config and will set its local to en-gb and see if that works, if not, I can use en-gb for the entire mirror.
                  Thanks for your reply.
                    migitcheetah
                    How can I change the background color on the month view day of the week header? I have fixed everything else to look the way I like, but the background is transparent, and the text is white, and I would like to make the background solid black, but just cant seem to find the right css block.
                    • ? Offline
                      @migitcheetah
                      Easily, you can use like this;
                      .CALEXT #CALEXT_month {
                        background-color:black;
                      I put the blue color to body intentionally to check.
                        migitcheetah @Guest
                        @Sean Thanks for this, that is a great solution, but before I commit to it, I wanted to just check in and see if I could just change the background on the day of the week headers?
                        I like the rest as I have it in my screen shot, but if it is not possible, then your solution will work.
                        Thanks for all your help.
                        • ? Offline
                          @migitcheetah
                          css/custom.css
                          .CALEXT .calendarMonth .weekHeader {
                            background-color:#FF00FF;
                          .CALEXT .calendarMonth .weekHeader .day_1 {
                            background-color: #00FFFF;
                            migitcheetah @Guest
                            @Sean said in MMM-CalendarExt:
                            Thanks!:folded_hands:
                            • K Offline
                              Keith
                              Is there any way to get a “month” view of the following month? I can do it in CalendarExt2 but I like the layout of CalendarExt better.
                              Both are excellent modules BTW
                                JRB1988
                                Re: MMM-CalendarExt
                                I’m trying to change the background colors of slot headers for the the next two months but can’t seem to find where to change that in the CSS. Was hoping to get some direction where to find change this. Thanks.
                                • C Offline
                                  Clubjack
                                  Hello together.
                                  I have an upcoming View with some calendars.
                                  One calendar has descriptions in the events.
                                  Possible to disable this in the configs?
                                  • C Offline
                                    Clubjack
                                    I got it with…
                                    .CALEXT. eventLocation
                                    • N Offline
                                      nobita @Guest
                                      @sean when no event , the calendarExt show only frame . if i want to replace empty view with word such as " No Events" or other word. how can i do?
                                        sdetweil @nobita
                                        @nobita see my other post
                                        also pleasr dont post the ssme question in multiple places
                                        • 6
                                        • 7
                                        • 8
                                        • 9
                                        • 10
                                        • 10 / 10
