    MMM-CalendarExt
    198 Posts 45 Posters 246.8k Views 45 Watching
    • V Offline
      Vauxdvihl
      @Sean
      I am not a programmer :-)
      I have played a little bit…also with big values, but the symbol size does not change.
      Maybe i am doing something wrong?
       * Magic Mirror                                      *
       * Custom CSS                                        *
       * By Michael Teeuw http://michaelteeuw.nl           *
       * MIT Licensed.                                     *
       * Add any custom CSS below.                         *
       * Changes to this files will be ignored by GIT. *
       div.CALEXT  .event .symbol {
          order:1;
          display:block;
          flex-basis: 40px; // Modify this
          text-align:center;
          min-width: 50px; // Modify this
          font-size: 800%; // Add this
      • ? Offline
        A Former User @Vauxdvihl
        @Vauxdvihl
        Ok. I know what’s the problem. I’ve forgotten emoji belongs different section.
        put this in your css.
        div.CALEXT .events .symbol.emoji {
            font-size: 100%; //Adjust this as your wish. you can use px or %
        • V Offline
          Vauxdvihl
          @Sean
          Perfect for some symbols
          But the symbol “trash-o” will be not “re-sized”.
          I have to look for a symbol in other sources == > “em”…and so on
          • ? Offline
            @Vauxdvihl
            for emoji(@em) size, see my last answer.
            for FA and MD (default and @fa & @md) sizes are related to my previous answer.
            • V Offline
              Vauxdvihl
              @Sean
              It works fine with adding this code to custom css :-)
              div.CALEXT .events .symbol.font-awesome {
                  font-size: 250%; //Adjust this as your wish. you can use px or %
              • ? Offline
                @Vauxdvihl Ye… Maybe that’s another solution. :)
                • V Offline
                  Vauxdvihl
                  @Sean
                  Sorry again but i have another question / problem
                  You can see in my above standing screens that split view => current / upcoming does not work.
                  But before doing the update it was working.
                  Here is my config code
                  				module: 'MMM-CalendarExt',
                  				position: "lower_third", //anywhere. It is not related to real position of view
                  				config: { // Read below
                  				system: {
                  				  show: ['current','upcoming','daily'],
                  				  locale: 'de', //when omitted, default value would be your system default locale by moment.js
                  				  showEmptyView: 0,
                  				  fullDayEventLocalize: 1,
                  				  redrawInterval: 30*60*1000, //minimum 60000
                  				  useProfileConfig: 0,
                  				  startProfile: ''
                  				 views: {
                  						current: {
                  						  title: "Heute",
                  						  limit: 3,
                  						upcoming: {
                  						  title: "Demnächst",
                  						  limit: 3,
                  						daily: {
                  						  position: "bottom_bar",
                  						  title: "Überblick",
                  						  counts: 7,
                  • V Offline
                    Vauxdvihl
                    @Sean
                    it is me again.
                    After having everything running, my wife wants to have the view “weekly” with 2 counts.
                    Now i have the “problem”, that i search for the config parameter which allows also to see the timings in this view (like 08:00-10:00 …and so on)
                    Is it possible in the “weekly” view?
                    Thanks again for your support and help
                    ? 2 Replies Last reply Reply Quote 0
                    • ? Offline
                      @Vauxdvihl
                      Yes possible.
                      Put this code in your css.
                      div.CALEXT .tableStyle .eventTime {
                          display:block;
                      I’m not on the console on weekends, so i didnt test it, but i think it will work.
                      Ps. that view is not ‘weekly’. It is ‘weeks’
                      • V Offline
                        Vauxdvihl
                        @Sean
                        Yes you are right…it is the view "weeks
                        Now i have in the appointment also the date within…it looks a little bit twice…because the date is also within the header of the week…
                        May be you can help me
                        Thanks a lot
                        • ? Offline
                          @Vauxdvihl
                          Maybe on Monday I’ll provide you a patch about that.
                          In ‘Month’ and ‘weeks’ view, I assume nobody needs exact time, because those views might have too many events to show with time. So I I’ve thought time displaying is needed in only daily, upcoming, current.
                          Anyway, I’ll follow opinion of my real users. :)
                          • ? Offline
                            @Vauxdvihl
                            I’ve finished the patch, re-pull the source and try again.
                            • V Offline
                              Vauxdvihl
                              Thanks a lot
                              It works
                              • cowboysdudeC Offline
                                cowboysdude Module Developer
                                @Sean this is THE best calendar module by far…awesome job!
                                • P Offline
                                  Phil_T
                                  @Sean First of all, great work! This module was exactly what I was looking for.
                                  I´ve been tinkering with it for about a day now and I got a few small issues.
                                  1. Unfortunately I can´t get this (https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics) calendar to show, any suggestions?
                                  2. As you can see on the screenshot below, there is quite some space left for calendar to use. Any tips on how can designate all this void area for the calendar?
                                  3. I can´t seem to enable the event time (eg. 17:00-19:00 next to the event title), what might be the problem here?
                                  Thanks a lot for the help!
                                  • ? Offline
                                    A Former User @Phil_T
                                    @Phil_T said in MMM-CalendarExt:
                                    Has it “Erster Advent” on 3 December? I can see that event.
                                    Did you mean whole calendar area? or each event?
                                    for whole calendar area; Add this code to your css/custom.css
                                    .CALEXT div.tableStyle {
                                     width:100%;
                                    Well, I assumed in month view and weeks view people might not need exact time, (Mirror is too small to display many things), So I disabled it by default.
                                    Add this to your css/custom.css
                                    div.CALEXT div.tableStyle div.eventContainer div.eventTime {
                                      display:block;
                                    • P Offline
                                      Phil_T
                                      Thanks a lot for the quick response!
                                      There should also be “Mariä Empfängnis” on the 8th of December, which isnt showing (maybe a problem with ä, ö and ü?).
                                      Sorry for my confusing explanation. I meant for the calendar to cover the whole screen apart from a bar at the top for time and weather.
                                      Thanks, the time is showing.
                                      edit: furthermore, how can I stop the module from cutting off the bottom part?
                                      • ? Offline
                                        @Phil_T
                                        For position, you can set your view position in config.
                                                system: {
                                                  show: ["weeks"],
                                                  locale: 'en',
                                                views: {
                                                  weeks: {
                                                    position: "bottom_bar", // Set this as your wish.
                                                    counts: 4,
                                        Ref.) https://forum.magicmirror.builders/topic/286/regions
                                        • ? Offline
                                          @Phil_T
                                          Hmmm… On my mirror, Mariä Empfängnis is shown well.
                                          I suspect your configuration contains limit or overflow options.
                                          See here. https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
                                          You could get idea how to optimize size in that page.
                                          Anyway, 4 weeks and month view are frankly a bit large for mirror (I think.).
                                          • P Offline
                                            Phil_T
                                            Wonderful, everyting works now. Thanks a lot!
                                            • 9
                                            • 10
                                            • 2 / 10
