    MMM-CalendarExt
    198 Posts 45 Posters 276.1k Views 45 Watching
    • V
      Vauxdvihl
      @Sean
      Yes you are right…it is the view "weeks
      Now i have in the appointment also the date within…it looks a little bit twice…because the date is also within the header of the week…
      May be you can help me
      Thanks a lot
      ? 1 Reply Last reply
        A Former User @Vauxdvihl
        @Vauxdvihl
        Maybe on Monday I’ll provide you a patch about that.
        In ‘Month’ and ‘weeks’ view, I assume nobody needs exact time, because those views might have too many events to show with time. So I I’ve thought time displaying is needed in only daily, upcoming, current.
        Anyway, I’ll follow opinion of my real users. :)
          @Vauxdvihl
          I’ve finished the patch, re-pull the source and try again.
          • V
            Vauxdvihl
            Thanks a lot
            It works
            • cowboysdudeC
              @Sean this is THE best calendar module by far…awesome job!
                Phil_T
                @Sean First of all, great work! This module was exactly what I was looking for.
                I´ve been tinkering with it for about a day now and I got a few small issues.
                1. Unfortunately I can´t get this (https://calendar.google.com/calendar/ical/de.austrian%23holiday%40group.v.calendar.google.com/public/basic.ics) calendar to show, any suggestions?
                2. As you can see on the screenshot below, there is quite some space left for calendar to use. Any tips on how can designate all this void area for the calendar?
                3. I can´t seem to enable the event time (eg. 17:00-19:00 next to the event title), what might be the problem here?
                Thanks a lot for the help!
                  A Former User @Phil_T
                  @Phil_T said in MMM-CalendarExt:
                  Has it “Erster Advent” on 3 December? I can see that event.
                  Did you mean whole calendar area? or each event?
                  for whole calendar area; Add this code to your css/custom.css
                  .CALEXT div.tableStyle {
                   width:100%;
                  Well, I assumed in month view and weeks view people might not need exact time, (Mirror is too small to display many things), So I disabled it by default.
                  Add this to your css/custom.css
                  div.CALEXT div.tableStyle div.eventContainer div.eventTime {
                    display:block;
                    Phil_T
                    Thanks a lot for the quick response!
                    There should also be “Mariä Empfängnis” on the 8th of December, which isnt showing (maybe a problem with ä, ö and ü?).
                    Sorry for my confusing explanation. I meant for the calendar to cover the whole screen apart from a bar at the top for time and weather.
                    Thanks, the time is showing.
                    edit: furthermore, how can I stop the module from cutting off the bottom part?
                    ? 2 Replies Last reply
                      @Phil_T
                      For position, you can set your view position in config.
                              system: {
                                show: ["weeks"],
                                locale: 'en',
                              views: {
                                weeks: {
                                  position: "bottom_bar", // Set this as your wish.
                                  counts: 4,
                      Ref.) https://forum.magicmirror.builders/topic/286/regions
                        @Phil_T
                        Hmmm… On my mirror, Mariä Empfängnis is shown well.
                        I suspect your configuration contains limit or overflow options.
                        See here. https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
                        You could get idea how to optimize size in that page.
                        Anyway, 4 weeks and month view are frankly a bit large for mirror (I think.).
                          Phil_T
                          Wonderful, everyting works now. Thanks a lot!
                          • H
                            helmi
                            MMM-CalendarExt not updating calendar events.**
                            I have configured two calendar views: “daily” and “upcoming”. I have set the redrawInterval to minimum: 60000 ms. I have two calendars: Private Google Calendar and local ics calendar file. When I update one or another of my calendars, my calendars don’t update at all. Updates happen only when I restart MMM from the beginning. For testing purposes I have also the “default” calendar in my configuration and it updates normally. For testing purposes I have added command 'self.sendSocketNotification(‘RESET_CALENDARS’) to the MMM-CalendarExt.js code inside the redrawTimer function. This dirty patch resets the calendars every 60 seconds, but I don’t think this is the right way to solve my problem. Please help.
                              A Former User @helmi
                              @helmi
                              Well, I tested and found nothing problem.
                              So, I suspect there might be some errors in front-electron views. Front-view error(from any module) could cause interfering other modules working. You can test by npm start dev.
                              H 2 Replies Last reply
                              • H
                                helmi @Guest
                                @Sean I have been using the ‘npm start dev’ and it shows no errors. From the console log I can see that the timer triggers as expected. From the Calendar.js log (terminal view) I can see that the calendars fetching happens only when I start MMM from the beginning.
                                • H
                                  helmi @Guest
                                  @Sean FYI: I have removed all other modules, only MMM-CalendarExt existing. I have also removed local calendar file, only Google Calendar URL existing. I have done shutdown and restart (both Rpi and MMM) several times. Problem still exists. For me looks like problem is where the calendars fetching should trigger. They happen only once when I start MMM from the beginning.
                                    @helmi
                                    Hmmmm… weird.
                                    Anyway, Calendar fetching interval([calendar].interval) is different with front-view redrawing(system.redrawInterval). There is some possibility of you’ve been confusing.
                                    H 1 Reply Last reply
                                    • H
                                      helmi @Guest
                                      @Sean Ok - So does that mean that the redrawInterval parameter (my setting 60000) has nothing to do with Calendar fetching interval? If so, could you please give me some testing procedure in order to test those parts of the code where the fetching interval is working (or for me: not working)? I have some coding experience, but js is not my best knowledge.
                                        @helmi
                                        system.redrawInterval is used for refreshing calendar view. It is set to 30 minutes by default. It doesn’t affect calendar fetching. With already fetched data, module redraws views per this interval value.
                                        system: {
                                          show: ['upcoming', 'daily'],
                                          redrawInterval: 30*60*1000, //minimum 60000
                                        [calendar].interval is used for reading iCal file and fetching. If you set this value to one hour, the calendar will be re-parsed per one hour. But, if there is no changed event or new event, the module doesn’t load newly-parsed-but-same data and use previous data already loaded.
                                        The process is like this;
                                        1. node_helper.js reads calendars per interval time.
                                        2. it fetches calendars and compares them with previously fetched data.
                                        3. If nothing changed, nothing happens.
                                        4. If something changed, newly fetched data will be sent to the module.
                                        5. Module loads fetched events data on the memory.
                                        6. Every redrawInterval time, module redraw views with loaded events data.
                                        • H
                                          helmi @Guest
                                          @Sean Thank you for the clarifying information. Apparently I was expecting the calendars fetching to happen by system.redrawInterval, which was set at one minute (60000 ms). Now I waited for 30 minutes and fetching happened and events were updated as I expected. No problem so far!
                                          Seems to me that the [calendar].interval (fetching) is set to 30 minutes by default.
                                          Now only one question remains: How can I change the [calendar].interval to for example 5 minutes? This is the interval in “default” calendar, and I have some events needing to be updated more often than 30 minutes.
                                          • H
                                            helmi @Guest
                                            @Sean Solved! No need to answer my last question. Sorry I didn’t read the documentation carefully enough. It is a very clever solution to have refresh interval setting for each calendar individually!
                                            Thank you very much for nice conversation and happy Christmas greetings from snowy Finland!
                                            • 10
                                            • 2 / 10
