Trouble with calendar.js
Scheduled Pinned Locked Moved Unsolved System
14 Posts 2 Posters 3.1k Views 2 Watching
    MMM-kludo
    Hi:
    After the update to the current version failed at the weekend, I have completely reinstalled my MagicMirror². This has also worked in principle. However, the calendar module now always shows me absolute timeFormat. This was not the case before and I cannot change it. The setting [timeFormat: “relative”] does not work. Even with the unedited config.js.sample this behavior shows up.
    I replaced the “calendar.js” with the previous version, so the display works as desired. Only I am not release able with it.
    Does anyone have an idea?
    S 1 Reply Last reply Dec 20, 2021, 4:32 PM Reply Quote 0
    • S Online
      sdetweil @MMM-kludo
      @mmm-kludo can u show the config.js entry for calendar
      you can xx out the url so it doesn’t work
           module: 'calendar',
            config:{
      M 1 Reply Last reply Dec 20, 2021, 5:27 PM Reply Quote 0
        MMM-kludo @sdetweil
        @sdetweil The URL works, the display of the timeFormat is incorrect!
        S 1 Reply Last reply Dec 20, 2021, 6:33 PM Reply Quote 0
        • S Online
          sdetweil @MMM-kludo
          @mmm-kludo not my point. I want to see the config entry for calendar and do NOT want others to see your working calendar url
          M 1 Reply Last reply Dec 21, 2021, 10:55 AM Reply Quote 0
            MMM-kludo @sdetweil
            @sdetweil Sorry, I must have misunderstood. For me, the behavior that no relative times are displayed already after the Installtion. Without that I have made changes in the configfile. Although the default setting is “relative”.
            All attempts on my part failed, except replacing the calendar.js.
            RaspOS version: more 5.10.63-v7l+
            Mirror version: “2.17.1”
            S 1 Reply Last reply Dec 21, 2021, 1:05 PM Reply Quote 0
            • S Online
              sdetweil @MMM-kludo
              @mmm-kludo again, you haven’t provided the config.js section for the calendar.
              I want to see the exact text
              M 1 Reply Last reply Dec 21, 2021, 3:08 PM Reply Quote 0
                MMM-kludo @sdetweil
                @sdetweil I have not changed anything, the exact text is:
                                        header: "US Holidays",
        symbol: "calendar-check",
        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                and on the mirror I see this:
                Christmas           Saturday at 00:00
                New Year's Day                Jan 1st
                but I would like, for example, this:
                Help me                        Today
                Christmas                   Tomorrow
                New Year's Day             in 5 Days
                S 1 Reply Last reply Dec 21, 2021, 3:19 PM Reply Quote 0
                • S Online
                  sdetweil @MMM-kludo
                  @mmm-kludo ok, you say timeFormat: doesn’t work but u haven’t specified it in the config
                  ALL config for ANY module goes in config.js
                                                 timeFormat: "relative",
                                                 ...  whatever other parms
                  you NEVER change the source code itself…
                  config info for cal
                  https://docs.magicmirror.builders/modules/calendar.html
                  note the getRelative parm …
                  calendar has too many options (in my opinion),
                  M 1 Reply Last reply Dec 21, 2021, 3:33 PM Reply Quote 0
                    MMM-kludo @sdetweil
                    @sdetweil Thank you for your help. I have changed the value as you recommended. According to my understanding, this setting is also the default value. However, my display has not changed.
                    S 1 Reply Last reply Dec 21, 2021, 3:35 PM Reply Quote 0
                    • S Online
                      sdetweil @MMM-kludo
                      @mmm-kludo
                      how far in front of the event does the thing change to relative? in HOURS
                      xmas is 4 DAYS (48 hours), default is 6 (HOURS)
                      M 2 Replies Last reply Dec 21, 2021, 3:59 PM Reply Quote 0
