    Problem with mmm-openhabfloorplan after fresh install
    4 Posts 2 Posters 540 Views 2 Watching
      maxheartrate
      Hi everyone,
      I updated my Magic Mirror and something must have gone wrong. Afterwards, I reinstalled Magic Mirror into a new folder. Everything works fine until I start to load custom modules. My most important one is mmm-openhabfloorplan.
      After installation, Magic Mirror won’t start anymore. I get the following message:
      > magicmirror@2.17.1 start /home/pi/MagicMirror
      [23.12.2021 21:26.41.242] [LOG]   Starting MagicMirror: v2.17.1
      [23.12.2021 21:26.41.255] [LOG]   Loading config ...
      [23.12.2021 21:26.41.274] [LOG]   Loading module helpers ...
      [23.12.2021 21:26.41.281] [LOG]   No helper found for module: alert.
      [23.12.2021 21:26.41.318] [LOG]   Initializing new module helper ...
      [23.12.2021 21:26.41.320] [LOG]   Module helper loaded: updatenotification
      [23.12.2021 21:26.41.322] [LOG]   No helper found for module: clock.
      [23.12.2021 21:26.41.751] [LOG]   Initializing new module helper ...
      [23.12.2021 21:26.41.753] [LOG]   Module helper loaded: calendar
      [23.12.2021 21:26.41.757] [LOG]   Initializing new module helper ...
      [23.12.2021 21:26.41.760] [LOG]   Module helper loaded: currentweather
      [23.12.2021 21:26.41.768] [LOG]   Initializing new module helper ...
      [23.12.2021 21:26.41.770] [LOG]   Module helper loaded: weatherforecast
      [23.12.2021 21:26.41.781] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
      Require stack:
      - /home/pi/MagicMirror/modules/mmm-openhabfloorplan/node_helper.js
      [23.12.2021 21:26.41.783] [LOG]   Loading module helpers ...
      [23.12.2021 21:26.41.785] [LOG]   No helper found for module: alert.
      [23.12.2021 21:26.41.787] [LOG]   Initializing new module helper ...
      [23.12.2021 21:26.41.788] [LOG]   Module helper loaded: updatenotification
      [23.12.2021 21:26.41.790] [LOG]   No helper found for module: clock.
      [23.12.2021 21:26.41.792] [LOG]   Initializing new module helper ...
      [23.12.2021 21:26.41.794] [LOG]   Module helper loaded: calendar
      [23.12.2021 21:26.41.797] [LOG]   Initializing new module helper ...
      [23.12.2021 21:26.41.800] [LOG]   Module helper loaded: currentweather
      [23.12.2021 21:26.41.803] [LOG]   Initializing new module helper ...
      [23.12.2021 21:26.41.805] [LOG]   Module helper loaded: weatherforecast
      [23.12.2021 21:26.41.812] [ERROR] App threw an error during load
      [23.12.2021 21:26.41.817] [ERROR] Error: Cannot find module 'request'
      Require stack:
          at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
          at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (internal/modules/cjs/loader.js:732:27)
          at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
          at Module.require (internal/modules/cjs/loader.js:959:19)
          at require (internal/modules/cjs/helpers.js:88:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/mmm-openhabfloorplan/node_helper.js:1:17)
          at Module._compile (internal/modules/cjs/loader.js:1078:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
      [23.12.2021 21:26.41.820] [ERROR] Whoops! There was an uncaught exception...
      [23.12.2021 21:26.41.833] [ERROR] Error: Cannot find module 'request'
      Require stack:
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/home/pi/MagicMirror/modules/mmm-openhabfloorplan/node_helper.js',
          '/home/pi/MagicMirror/js/app.js',
          '/home/pi/MagicMirror/js/electron.js',
          '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
          undefined
      [23.12.2021 21:26.41.842] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [23.12.2021 21:26.41.844] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [23.12.2021 21:26.42.328] [LOG]   Launching application.
      Does anyone know how to fix this error?
      Best, Max
        maxheartrate @maxheartrate
        @maxheartrate I found a fix. I had to install the request module manually:
        npm install request.
        Explanation in this post:
        https://issueexplorer.com/issue/MichMich/MagicMirror/2688
          sdetweil @maxheartrate
          @maxheartrate and here
          more than just request could be not found
            maxheartrate @sdetweil
            @sdetweil Thank you. Everything is working fine now.
