    Facial Recognition Module - Step by Step Guide
    28 Posts 14 Posters 37.6k Views 22 Watching
    • A
      amsuvarna27 @konradwalsh
      @konradwalsh
      I’m using Raspberry pi CSI camera.
      How to do with it.
      Please help me.
      • O
        OGElijah @sdetweil
        @sdetweil Hey, buddy… I’m not sure what it is you’re telling me to do here. I wrote what you sent into the terminal but it didn’t do anything. In fact, it’s treating the = sign as a syntax error… what am I doing wrong?
          sdetweil @OGElijah
          @ogelijah u have to edit the failing py script
          and change the failing line
          O 1 Reply Last reply
          • O
            OGElijah @sdetweil
            @sdetweil I get you! I was being an idiot and I went into the wrong script. But now I’ve reached the point where it says “no module named cv2”
              sdetweil @OGElijah
              @ogelijah no idea. that’s a python lib, which should have been installed from the prior setup steps
              • O
                OGElijah @sdetweil
                @sdetweil Ah, okay. I’ll keep on working on this. Cheers
                  sdetweil @OGElijah
                  @ogelijah because you replaced a line that used cv2, with another line that used cv2
                    mraeymaekers @sdetweil
                    This fix worked! Thank you.
                    My error message:
                    python capture.py
                    File “capture.py”, line 18, in
                    import lib.capture as capture
                    File “/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/capture.py”, line 21, in
                    from . import config
                    File “/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/config.py”, line 15, in
                    (CV_MAJOR_VER, CV_MINOR_VER, mv1, mv2) = cv2.version.split(“.”)
                    ValueError: need more than 3 values to unpack
                    Steps to fix:
                    cd ~/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/
                    nano config.py
                    go to line 15 … I commented out the original line and added a line with ‘,mv2’ removed.
                    #(CV_MAJOR_VER, CV_MINOR_VER, mv1, mv2) = cv2.version.split(“.”)
                    (CV_MAJOR_VER, CV_MINOR_VER, mv1) = cv2.version.split(“.”)
                    • O
                      OGElijah
                      I can’t get the .xml file no matter how hard I try… I keep running the train.py file and wait, but nothing happens
                        sdetweil @OGElijah
                        @ogelijah how many images do you have for different people,?
                        what pi is this?
