Solved Hello-Lucy using Adafruit Voice Bonnet
I’m trying to bring up Hello-Lucy on a “new” Magic Mirror. I’m running on a Pi 3B+, and installed the Adafruit Voice Bonnet for audio.
I can do
arecord --format cd --duration 7 --channels 1 test2.wav
then
aplay test2.wav
and I hear the recording from the Voice Bonnet speaker. I don’t have to specify he device for these to work.When I list my audio devices, I get:
pi@Magic:~/MagicMirror/config $ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 1: vc4hdmi [vc4-hdmi], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
Subdevices: 1/1
card 2: seeed2micvoicec [seeed-2mic-voicecard], device 0: bcm2835-i2s-wm8960-hifi wm8960-hifi-0 [bcm2835-i2s-wm8960-hifi wm8960-hifi-0]
Subdevices: 1/1
pi@Magic:~/MagicMirror/config $ arecord -l
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
Subdevice #0: subdevice #0Card 2 for both play and capture is the Voice Bonnet.
When I restart MMM with Hello-Lucy, I hear the default greeting, but always get the microphone shown with ERROR. Even though the lists indicate card 2, I’ve tried 0 and 1 since card 2 is the only thing listed, but still no microphone.
Here’s my config.js file:
/* Magic Mirror Config Sample
*- By Michael Teeuw https://michaelteeuw.nl
- MIT Licensed.
let config = {
// - “0.0.0.0”, “::” to listen on any interface
// Default, when address config is left out or empty, is “localhost”
port: 8081,
basePath: “/”, // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],useHttps: false, // Support HTTPS or not, default "false" will use HTTP httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true language: "en", locale: "en-US", logLevel: ["INFO", "LOG", "WARN", "ERROR"], // Add "DEBUG" for even more logging timeFormat: 24, units: "imperial", // serverOnly: true/false/"local" , // local for armv6l processors, default // starts serveronly and then starts chrome browser // false, default for all NON-armv6l devices // true, force serveronly mode, because you want to.. no UI on this device modules: [ { disabled: false, module: "Hello-Lucy", position: "top_center", config: { keyword: 'HELLO LUCY', // keyword to activate listening for a command/sentence timeout: 15, // timeout listening for a command/sentence standByMethod: 'DPMS', // 'DPMS' = anything else than RPi or 'PI' microphone: "1,0", // run "arecord -l" card # and device # mine is "0,0" sounds: ["1.mp3", "11.mp3"], // welcome sound at startup. Add several for a random greetings confirmationSound: "ding.mp3", // name and extension of sound file startHideAll: true, // All modules start as hidden EXCEPT PAGE ONE // *** Page One is your default startup page *** This overrides startHideAll: true, pageOneModules: ["Hello-Lucy","MMM-EasyPix"], // default modules to show on page one/startup pageTwoModules: ["Hello-Lucy", "MMM-BMW-DS", "MMM-EventHorizon"], // modules to show on page two pageThreeModules: ["Hello-Lucy", "MMM-Lunartic"], // modules to show on page three pageFourModules: ["Hello-Lucy", "MMM-PC-Stats"], // modules to show on page four pageFiveModules: ["Hello-Lucy", "MMM-Searchlight"], // modules to show on page five pageSixModules: ["Hello-Lucy", "MMM-NOAA3"], // modules to show on page six pageSevenModules: ["Hello-Lucy", "MMM-Recipe"], // modules to show on page seven pageEightModules: ["Hello-Lucy", "MMM-rfacts"], // modules to show on page eight pageNineModules: ["Hello-Lucy", "MMM-History"], // modules to show on page nine pageTenModules: ["Hello-Lucy", "MMM-HardwareMonitor"] // modules to show on page ten } }, ]
if (typeof module !== “undefined”) {module.exports = config;}Any help would be appreciated.
Well, I gave up on the Adafruit Voice Bonnet, and instead installed a USB microphone with output (Samson GoMic). Now, mic and speakers work every time whether MM/Hello-Lucy starts up automatically at boot, or if I start it using npm start.
I’ll probably mark it resolved, even thought the fundamental issue is not.
A BIG thanks to @sdetweil for all of his patience and help.
@sinbad339 said in Hello-Lucy using Adafruit Voice Bonnet:
microphone: "1,0",
so arecord says card 2,0
arecord -l **** List of CAPTURE Hardware Devices **** card 2: seeed2micvoicec [seeed-2mic-voicecard], device 0: bcm2835-i2s-wm8960-hifi wm8960-hifi-0 [bcm2835-i2s-wm8960-hifi wm8960-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0
so it should be
microphone: "2,0",
@sdetweil said in Hello-Lucy using Adafruit Voice Bonnet:
so it should be
microphone: “2,0”,Thanks for replying. This config is what I had when I posted. As I mentioned, I’ve tried “0,0”, “1,0”, and “2,0”; all result in the microphone error.
@sinbad339 can u try this
arecord -D default -q -r 16000 -c 1 -t wav -f S16_LE >test.wav
the replace default with
arecord -D hw:2,0 -q -r 16000 -c 1 -t wav -f S16_LE >test.wav
With MM running, if I issuearecord -D default -q -r 16000 -c 1 -t wav -f S16_LE >test.wav
I get a good .wave file that I can play.
With MM still running, specifying the hw explicitly results in an error.arecord -D hw:2,0 -q -r 16000 -c 1 -t wav -f S16_LE >test2.wav arecord: main:830: audio open error: Device or resource busy pi@Magic:~/MagicMirror/config $ arecord -l **** List of CAPTURE Hardware Devices **** card 2: seeed2micvoicec [seeed-2mic-voicecard], device 0: bcm2835-i2s-wm8960-hifi wm8960-hifi-0 [bcm2835-i2s-wm8960-hifi wm8960-hifi-0] Subdevices: 0/1 Subdevice #0: subdevice #0
ok, so MM is using that device
while mm is running do
ps -ef | grep arec
u should see the arecord process and the parms passed
from one of my apps that uses arecordarecord -D default -q -r 16000 -c 1 -t wav -f S16_LE -
the trailing dash means stream content to stdout (which is captured by the upstream library)
So the arecord -l lists card2 as my expected capture device (seeed-2mic-voicecard). I find it interesting that it enumverates as #2 with no #0 or #1.Anyway, I ran your ps command; not sure what this output means (as I’m sure you’re aware by now, I’m a Noob on Linux).
ps -ef | grep arec pi 1953 1927 0 11:04 pts/0 00:00:00 grep --color=auto arec
@sinbad339 hm…
should have used arecord…
try
ps -ef | grep rec
(there are only 2 apps… arecord or rec )
the output from ps
user that started process
the process id
the parent process id +
(i don’t know, 0)
the time the process was started
(i don’t know, pts/ )
how much cpu time has been used since started, in seconds
the string used to start the process, pgm name and then parms -
ps -ef | grep rec root 76 2 0 11:02 ? 00:00:00 [vchiq-recy/0] pi 2320 1927 0 11:24 pts/0 00:00:00 grep --color=auto rec
Not sure what vchiq-recy is…
But no arec or arecord.
