Solved v2.18.0 update gave black screen, then nothing.
MM said I was 122 commits behind.
Ran the update script:bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
Eeeeek, black screen! Searched forum, found this:
https://forum.magicmirror.builders/topic/15240/black-screen/2?_=1641460034694Did as suggested:
pi@magicmirror:~/MagicMirror $ npm run config:check > magicmirror@2.18.0 config:check > node js/check_config.js /home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2359 const require$1 = Module.createRequire((typeof document === 'undefined' ? new (require('u' + 'rl').URL)('file:' + __filename).href : (document.currentScript && document.currentScript.src || new URL('eslintrc.cjs', document.baseURI).href))); ^ TypeError: Module.createRequire is not a function at Object.<anonymous> (/home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2359:26) at Module._compile (internal/modules/cjs/loader.js:778:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10) at Module.load (internal/modules/cjs/loader.js:653:32) at tryModuleLoad (internal/modules/cjs/loader.js:593:12) at Function.Module._load (internal/modules/cjs/loader.js:585:3) at Module.require (internal/modules/cjs/loader.js:692:17) at require (internal/modules/cjs/helpers.js:25:18) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/eslint/lib/cli-engine/cli-engine.js:33:5) at Module._compile (internal/modules/cjs/loader.js:778:30)
pi@magicmirror:~/MagicMirror $ npm init -y
Wrote to /home/pi/MagicMirror/package.json: { "name": "magicmirror", "version": "2.18.0", "description": "The open source modular smart mirror platform.", "main": "js/electron.js", "scripts": { "start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js", "start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev", "server": "node ./serveronly", "install": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error", "install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error", "postinstall": "npm run install-fonts && echo \"MagicMirror installation finished successfully! \n\"", "test": "NODE_ENV=test jest -i --forceExit", "test:coverage": "NODE_ENV=test nyc --reporter=lcov --reporter=text jest -i --forceExit", "test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit", "test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit", "test:unit": "NODE_ENV=test jest --selectProjects unit -i --forceExit", "test:prettier": "prettier . --check", "test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --config .eslintrc.json", "test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json", "test:calendar": "node ./modules/default/calendar/debug.js", "config:check": "node js/check_config.js", "lint:prettier": "prettier . --write", "lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --config .eslintrc.json --fix", "lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix", "lint:staged": "pretty-quick --staged", "prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed." }, "repository": { "type": "git", "url": "git+https://github.com/MichMich/MagicMirror.git" }, "keywords": [ "magic mirror", "smart mirror", "mirror UI", "modular" ], "author": "Michael Teeuw", "contributors": [ "https://github.com/MichMich/MagicMirror/graphs/contributors" ], "license": "MIT", "bugs": { "url": "https://github.com/MichMich/MagicMirror/issues" }, "homepage": "https://magicmirror.builders", "devDependencies": { "eslint-config-prettier": "^8.3.0", "eslint-plugin-jest": "^25.3.0", "eslint-plugin-jsdoc": "^37.4.0", "eslint-plugin-prettier": "^4.0.0", "express-basic-auth": "^1.2.1", "husky": "^7.0.4", "jest": "^27.4.5", "jsdom": "^19.0.0", "lodash": "^4.17.21", "nyc": "^15.1.0", "playwright": "^1.17.1", "prettier": "^2.5.1", "pretty-quick": "^3.1.3", "sinon": "^12.0.1", "stylelint": "^14.2.0", "stylelint-config-prettier": "^9.0.3", "stylelint-config-standard": "^24.0.0", "stylelint-prettier": "^2.0.0", "suncalc": "^1.8.0" }, "optionalDependencies": { "electron": "^16.0.5" }, "dependencies": { "colors": "^1.4.0", "console-stamp": "^3.0.3", "digest-fetch": "^1.2.1", "eslint": "^8.5.0", "express": "^4.17.2", "express-ipfilter": "^1.2.0", "feedme": "^2.0.2", "helmet": "^4.6.0", "iconv-lite": "^0.6.3", "module-alias": "^2.2.2", "moment": "^2.29.1", "node-fetch": "^2.6.6", "node-ical": "^0.13.0", "socket.io": "^4.4.0" }, "engines": { "node": ">=12" }, "jest": { "verbose": true, "testTimeout": 10000, "projects": [ { "displayName": "unit", "moduleNameMapper": { "logger": "<rootDir>/js/logger.js" }, "testMatch": [ "**/tests/unit/**/*.[jt]s?(x)" ], "testPathIgnorePatterns": [ "<rootDir>/tests/unit/mocks" ] }, { "displayName": "electron", "testMatch": [ "**/tests/electron/**/*.[jt]s?(x)" ] }, { "displayName": "e2e", "setupFilesAfterEnv": [ "<rootDir>/tests/e2e/mock-console.js" ], "testMatch": [ "**/tests/e2e/**/*.[jt]s?(x)" ], "modulePaths": [ "<rootDir>/js/" ], "testPathIgnorePatterns": [ "<rootDir>/tests/e2e/modules/mocks", "<rootDir>/tests/e2e/modules/basic-auth.js", "<rootDir>/tests/e2e/global-setup.js", "<rootDir>/tests/e2e/mock-console.js" ] } ] }, "directories": { "test": "tests" } } pi@magicmirror:~/MagicMirror $
pi@magicmirror:~/MagicMirror $ pm2 logs --lines=50 [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option) /home/pi/.pm2/pm2.log last 50 lines: PM2 | 2021-12-22T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2021-12-23T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2021-12-23T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2021-12-24T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2021-12-24T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2021-12-25T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2021-12-25T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2021-12-26T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2021-12-26T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2021-12-27T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2021-12-27T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2021-12-28T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2021-12-28T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2021-12-29T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2021-12-29T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2021-12-30T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2021-12-30T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2021-12-31T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2021-12-31T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2022-01-01T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2022-01-01T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2022-01-02T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2022-01-02T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2022-01-03T13:52:37: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2022-01-03T13:52:37: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2022-01-04T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2022-01-04T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2022-01-05T13:52:36: PM2 log: [PM2] This PM2 is not UP TO DATE PM2 | 2022-01-05T13:52:36: PM2 log: [PM2] Upgrade to version 5.1.2 PM2 | 2022-01-06T08:25:26: PM2 log: Stopping app:MagicMirror id:0 PM2 | 2022-01-06T08:25:27: PM2 log: pid=32642 msg=failed to kill - retrying in 100ms PM2 | 2022-01-06T08:25:27: PM2 log: pid=32642 msg=failed to kill - retrying in 100ms PM2 | 2022-01-06T08:25:27: PM2 log: pid=32642 msg=failed to kill - retrying in 100ms PM2 | 2022-01-06T08:25:27: PM2 log: pid=32642 msg=failed to kill - retrying in 100ms PM2 | 2022-01-06T08:25:27: PM2 log: pid=32642 msg=failed to kill - retrying in 100ms PM2 | 2022-01-06T08:25:27: PM2 log: pid=32642 msg=failed to kill - retrying in 100ms PM2 | 2022-01-06T08:25:28: PM2 log: pid=32642 msg=failed to kill - retrying in 100ms PM2 | 2022-01-06T08:25:28: PM2 log: pid=32642 msg=failed to kill - retrying in 100ms PM2 | 2022-01-06T08:25:28: PM2 log: pid=32642 msg=failed to kill - retrying in 100ms PM2 | 2022-01-06T08:25:28: PM2 log: pid=32642 msg=failed to kill - retrying in 100ms PM2 | 2022-01-06T08:25:28: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2022-01-06T08:25:28: PM2 log: pid=32642 msg=process killed PM2 | 2022-01-06T08:31:27: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2022-01-06T08:31:27: PM2 log: App [MagicMirror:0] online PM2 | 2022-01-06T08:33:57: PM2 log: Stopping app:MagicMirror id:0 PM2 | 2022-01-06T08:33:58: PM2 log: pid=12095 msg=failed to kill - retrying in 100ms PM2 | 2022-01-06T08:33:58: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2022-01-06T08:33:58: PM2 log: pid=12095 msg=process killed PM2 | 2022-01-06T08:34:05: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2022-01-06T08:34:05: PM2 log: App [MagicMirror:0] online /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines: 0|MagicMir | [06.01.2022 08:31.32.828] [LOG] Module helper loaded: currentweather 0|MagicMir | [06.01.2022 08:31.32.833] [LOG] Initializing new module helper ... 0|MagicMir | [06.01.2022 08:31.32.835] [LOG] Module helper loaded: weatherforecast 0|MagicMir | [06.01.2022 08:31.32.843] [LOG] Loading module helpers ... 0|MagicMir | [06.01.2022 08:31.32.845] [LOG] No helper found for module: alert. 0|MagicMir | [06.01.2022 08:31.32.847] [LOG] Initializing new module helper ... 0|MagicMir | [06.01.2022 08:31.32.849] [LOG] Module helper loaded: updatenotification 0|MagicMir | [06.01.2022 08:31.32.850] [LOG] No helper found for module: clock. 0|MagicMir | [06.01.2022 08:31.32.852] [LOG] Initializing new module helper ... 0|MagicMir | [06.01.2022 08:31.32.853] [LOG] Module helper loaded: calendar 0|MagicMir | [06.01.2022 08:31.32.855] [LOG] No helper found for module: compliments. 0|MagicMir | [06.01.2022 08:31.32.857] [LOG] No helper found for module: MMM-doomsDay. 0|MagicMir | [06.01.2022 08:31.32.859] [LOG] Initializing new module helper ... 0|MagicMir | [06.01.2022 08:31.32.860] [LOG] Module helper loaded: currentweather 0|MagicMir | [06.01.2022 08:31.32.862] [LOG] Initializing new module helper ... 0|MagicMir | [06.01.2022 08:31.32.863] [LOG] Module helper loaded: weatherforecast 0|MagicMir | [06.01.2022 08:31.33.522] [LOG] Launching application. 0|MagicMir | 0|MagicMir | > magicmirror@2.18.0 start 0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMir | 0|MagicMir | [06.01.2022 08:34.09.207] [LOG] Starting MagicMirror: v2.18.0 0|MagicMir | [06.01.2022 08:34.09.220] [LOG] Loading config ... 0|MagicMir | [06.01.2022 08:34.09.232] [LOG] Loading module helpers ... 0|MagicMir | [06.01.2022 08:34.09.238] [LOG] No helper found for module: alert. 0|MagicMir | [06.01.2022 08:34.09.272] [LOG] Initializing new module helper ... 0|MagicMir | [06.01.2022 08:34.09.275] [LOG] Module helper loaded: updatenotification 0|MagicMir | [06.01.2022 08:34.09.279] [LOG] No helper found for module: clock. 0|MagicMir | [06.01.2022 08:34.09.600] [LOG] Initializing new module helper ... 0|MagicMir | [06.01.2022 08:34.09.603] [LOG] Module helper loaded: calendar 0|MagicMir | [06.01.2022 08:34.09.606] [LOG] No helper found for module: compliments. 0|MagicMir | [06.01.2022 08:34.09.609] [LOG] No helper found for module: MMM-doomsDay. 0|MagicMir | [06.01.2022 08:34.09.614] [LOG] Initializing new module helper ... 0|MagicMir | [06.01.2022 08:34.09.616] [LOG] Module helper loaded: currentweather 0|MagicMir | [06.01.2022 08:34.09.620] [LOG] Initializing new module helper ... 0|MagicMir | [06.01.2022 08:34.09.622] [LOG] Module helper loaded: weatherforecast 0|MagicMir | [06.01.2022 08:34.09.630] [LOG] Loading module helpers ... 0|MagicMir | [06.01.2022 08:34.09.632] [LOG] No helper found for module: alert. 0|MagicMir | [06.01.2022 08:34.09.634] [LOG] Initializing new module helper ... 0|MagicMir | [06.01.2022 08:34.09.635] [LOG] Module helper loaded: updatenotification 0|MagicMir | [06.01.2022 08:34.09.637] [LOG] No helper found for module: clock. 0|MagicMir | [06.01.2022 08:34.09.638] [LOG] Initializing new module helper ... 0|MagicMir | [06.01.2022 08:34.09.640] [LOG] Module helper loaded: calendar 0|MagicMir | [06.01.2022 08:34.09.641] [LOG] No helper found for module: compliments. 0|MagicMir | [06.01.2022 08:34.09.643] [LOG] No helper found for module: MMM-doomsDay. 0|MagicMir | [06.01.2022 08:34.09.645] [LOG] Initializing new module helper ... 0|MagicMir | [06.01.2022 08:34.09.646] [LOG] Module helper loaded: currentweather 0|MagicMir | [06.01.2022 08:34.09.648] [LOG] Initializing new module helper ... 0|MagicMir | [06.01.2022 08:34.09.649] [LOG] Module helper loaded: weatherforecast 0|MagicMir | [06.01.2022 08:34.10.239] [LOG] Launching application. /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines: 0|MagicMir | - 0|MagicMir | [06.01.2022 08:34.09.653] [ERROR] App threw an error during load 0|MagicMir | [06.01.2022 08:34.09.658] [ERROR] Error: Cannot find module 'mysql' 0|MagicMir | Require stack: 0|MagicMir | - /home/pi/MagicMirror/modules/MMM-MysqlQuery/node_helper.js 0|MagicMir | - /home/pi/MagicMirror/js/app.js 0|MagicMir | - /home/pi/MagicMirror/js/electron.js 0|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js 0|MagicMir | - 0|MagicMir | at Module._resolveFilename (node:internal/modules/cjs/loader:940:15) 0|MagicMir | at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1128) 0|MagicMir | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) 0|MagicMir | at Module._load (node:internal/modules/cjs/loader:785:27) 0|MagicMir | at Function.c._load (node:electron/js2c/asar_bundle:5:13331) 0|MagicMir | at Module.require (node:internal/modules/cjs/loader:1012:19) 0|MagicMir | at require (node:internal/modules/cjs/helpers:94:18) 0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MysqlQuery/node_helper.js:10:13) 0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1116:14) 0|MagicMir | at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) 0|MagicMir | [06.01.2022 08:34.09.660] [ERROR] Whoops! There was an uncaught exception... **0|MagicMir | [06.01.2022 08:34.09.672] [ERROR] Error: Cannot find module 'mysql'** 0|MagicMir | Require stack: 0|MagicMir | - /home/pi/MagicMirror/modules/MMM-MysqlQuery/node_helper.js 0|MagicMir | - /home/pi/MagicMirror/js/app.js 0|MagicMir | - /home/pi/MagicMirror/js/electron.js 0|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js 0|MagicMir | - 0|MagicMir | at Module._resolveFilename (node:internal/modules/cjs/loader:940:15) 0|MagicMir | at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1128) 0|MagicMir | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) 0|MagicMir | at Module._load (node:internal/modules/cjs/loader:785:27) 0|MagicMir | at Function.c._load (node:electron/js2c/asar_bundle:5:13331) 0|MagicMir | at Module.require (node:internal/modules/cjs/loader:1012:19) 0|MagicMir | at require (node:internal/modules/cjs/helpers:94:18) 0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MysqlQuery/node_helper.js:10:13) 0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1116:14) 0|MagicMir | at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) { 0|MagicMir | code: 'MODULE_NOT_FOUND', 0|MagicMir | requireStack: [ 0|MagicMir | '/home/pi/MagicMirror/modules/MMM-MysqlQuery/node_helper.js', 0|MagicMir | '/home/pi/MagicMirror/js/app.js', 0|MagicMir | '/home/pi/MagicMirror/js/electron.js', 0|MagicMir | '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js', 0|MagicMir | undefined 0|MagicMir | ] 0|MagicMir | } 0|MagicMir | [06.01.2022 08:34.09.674] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|MagicMir | [06.01.2022 08:34.09.675] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|MagicMir | [12904:0106/083411.118170:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization 0|MagicMir | [12927:0106/083411.471839:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
pi@magicmirror:~/MagicMirror $ npm install mysql
npm WARN EBADENGINE Unsupported engine { package: 'magicmirror@2.18.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@es-joy/jsdoccomment@0.13.0', npm WARN EBADENGINE required: { node: '^12 || ^14 || ^16 || ^17' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@eslint/eslintrc@1.0.5', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/experimental-utils@5.8.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/scope-manager@5.8.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/types@5.8.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/typescript-estree@5.8.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/visitor-keys@5.8.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'commander@8.3.0', npm WARN EBADENGINE required: { node: '>= 12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'comment-parser@1.3.0', npm WARN EBADENGINE required: { node: '>= 12.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'data-urls@3.0.1', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'domexception@4.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'eslint@8.5.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'eslint-plugin-jest@25.3.0', npm WARN EBADENGINE required: { node: '^12.13.0 || ^14.15.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'eslint-plugin-jsdoc@37.4.0', npm WARN EBADENGINE required: { node: '^12 || ^14 || ^16 || ^17' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'eslint-scope@7.1.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'eslint-visitor-keys@3.1.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'espree@9.2.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'html-encoding-sniffer@3.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'husky@7.0.4', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'jsdoc-type-pratt-parser@2.0.0', npm WARN EBADENGINE required: { node: '>=12.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'jsdom@19.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'playwright@1.17.1', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'playwright-core@1.17.1', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'postcss-safe-parser@6.0.0', npm WARN EBADENGINE required: { node: '>=12.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'stylelint@14.2.0', npm WARN EBADENGINE required: { node: '^12.20.0 || ^14.13.1 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'stylelint-config-prettier@9.0.3', npm WARN EBADENGINE required: { node: '>= 12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'stylelint-prettier@2.0.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'tr46@3.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'w3c-xmlserializer@3.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'webidl-conversions@7.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'whatwg-encoding@2.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'whatwg-mimetype@3.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'whatwg-url@10.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'xml-name-validator@4.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. added 494 packages, and audited 761 packages in 6m 66 packages are looking for funding run `npm fund` for details found 0 vulnerabilities pi@magicmirror:~/MagicMirror $
Now when I start MM, I get just a blank page.
pi@magicmirror:~/MagicMirror $ pm2 start MagicMirror [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0) [PM2] [MagicMirror](0) ✓ [PM2] Process successfully started ┌────┬────────────────────┬──────────┬──────┬───────────┬──────────┬──────────┐ │ id │ name │ mode │ ↺ │ status │ cpu │ memory │ ├────┼────────────────────┼──────────┼──────┼───────────┼──────────┼──────────┤ │ 0 │ MagicMirror │ fork │ 45 │ online │ 0% │ 2.6mb │ └────┴────────────────────┴──────────┴──────┴───────────┴──────────┴──────────┘ pi@magicmirror:~/MagicMirror $
Hope it’s a simple fix, thank you.
@richard238 if you haven’t deleted yet, can u try something
because you did
in the mm folder, instead of the module folder, this overwrote the shipped package.json
so,
do
cd ~/MagicMirror.save git checkout package.json rm -rf node_modules rm package.lock.json npm install --only=prod
then stop good mm if running and then do , in the MagicMirror.save folder
npm start
Powered it down, switched it on. Shows MM splash screen, then goes to desktop.
No sign of MM :(
Nothing new logged in either .npm or .pm2 log files.
@richard238 Have a look at the below post. It might solve some of your issues.
@richard238 said in v2.18.0 update gave black screen, then nothing.:
0|MagicMir | [06.01.2022 08:34.09.658] [ERROR] Error: Cannot find module ‘mysql’Your error!
@richard238 No, You need to do the following:
cd ~.MagicMirror/modules/MMM-MysqlQuery npm init -y npm install mysql --save
There may be other missing modules.
pi@magicmirror:~ $ cd ~/MagicMirror/modules/MMM-MysqlQuery pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm init -y Wrote to /home/pi/MagicMirror/modules/MMM-MysqlQuery/package.json: { "name": "mmm-mysqlquery", "version": "1.0.0", "description": "MagicMirror module to display result of MySQL query", "license": "MIT", "main": "MMM-MysqlQuery.js", "scripts": { "test": "./node_modules/grunt/bin/grunt" }, "author": "Rich Alberth", "repository": { "type": "git", "url": "git+https://github.com/ralberth/MMM-MysqlQuery.git" }, "keywords": [ "MagicMirror", "module", "mysql" ], "dependencies": { "mysql": "latest", "npm": "^6.4.1" }, "devDependencies": { "grunt": "latest", "grunt-eslint": "latest", "grunt-jsonlint": "latest", "grunt-markdownlint": "^1.0.13", "grunt-stylelint": "latest", "grunt-yamllint": "^0.3.0", "stylelint": "^8.3.0", "stylelint-config-standard": "latest", "time-grunt": "latest", "electron-rebuild": "^1.8.2" }, "bugs": { "url": "https://github.com/ralberth/MMM-MysqlQuery/issues" }, "homepage": "https://github.com/ralberth/MMM-MysqlQuery#readme" } pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm install mysql --save npm ERR! code ERESOLVE npm ERR! ERESOLVE unable to resolve dependency tree npm ERR! npm ERR! While resolving: mmm-mysqlquery@1.0.0 npm ERR! Found: stylelint@8.4.0 npm ERR! node_modules/stylelint npm ERR! dev stylelint@"^8.3.0" from the root project npm ERR! npm ERR! Could not resolve dependency: npm ERR! peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0 npm ERR! node_modules/grunt-stylelint npm ERR! dev grunt-stylelint@"latest" from the root project npm ERR! npm ERR! Fix the upstream dependency conflict, or retry npm ERR! this command with --force, or --legacy-peer-deps npm ERR! to accept an incorrect (and potentially broken) dependency resolution. npm ERR! npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2022-01-06T11_56_31_385Z-debug.log pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $
@richard238 I think you installed the latest version in the MagicMirror folder whereas the MysqlQuery wants version 6.4.1. Go to the root of MagicMirror and run
npm uninstall mysql
. Once that is done thencd modules/MMM-MysqlQuery
. Then just run npm install in the folder. It should then install the dependencies that it require. -
pi@magicmirror:~/MagicMirror $ npm uninstall mysql npm WARN EBADENGINE Unsupported engine { package: 'magicmirror@2.18.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@es-joy/jsdoccomment@0.13.0', npm WARN EBADENGINE required: { node: '^12 || ^14 || ^16 || ^17' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@eslint/eslintrc@1.0.5', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/experimental-utils@5.8.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/scope-manager@5.8.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/types@5.8.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/typescript-estree@5.8.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: '@typescript-eslint/visitor-keys@5.8.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'commander@8.3.0', npm WARN EBADENGINE required: { node: '>= 12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'comment-parser@1.3.0', npm WARN EBADENGINE required: { node: '>= 12.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'data-urls@3.0.1', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'domexception@4.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'eslint@8.5.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'eslint-plugin-jest@25.3.0', npm WARN EBADENGINE required: { node: '^12.13.0 || ^14.15.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'eslint-plugin-jsdoc@37.4.0', npm WARN EBADENGINE required: { node: '^12 || ^14 || ^16 || ^17' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'eslint-scope@7.1.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'eslint-visitor-keys@3.1.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'espree@9.2.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'html-encoding-sniffer@3.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'husky@7.0.4', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'jsdoc-type-pratt-parser@2.0.0', npm WARN EBADENGINE required: { node: '>=12.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'jsdom@19.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'playwright@1.17.1', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'playwright-core@1.17.1', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'postcss-safe-parser@6.0.0', npm WARN EBADENGINE required: { node: '>=12.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'stylelint@14.2.0', npm WARN EBADENGINE required: { node: '^12.20.0 || ^14.13.1 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'stylelint-config-prettier@9.0.3', npm WARN EBADENGINE required: { node: '>= 12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'stylelint-prettier@2.0.0', npm WARN EBADENGINE required: { node: '^12.22.0 || ^14.17.0 || >=16.0.0' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'tr46@3.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'w3c-xmlserializer@3.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'webidl-conversions@7.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'whatwg-encoding@2.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'whatwg-mimetype@3.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'whatwg-url@10.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } npm WARN EBADENGINE Unsupported engine { package: 'xml-name-validator@4.0.0', npm WARN EBADENGINE required: { node: '>=12' }, npm WARN EBADENGINE current: { node: 'v10.24.1', npm: '7.24.2' } } removed 4 packages, and audited 758 packages in 14s 66 packages are looking for funding run `npm fund` for details found 0 vulnerabilities pi@magicmirror:~/MagicMirror $ cd modules/MMM-MysqlQuery pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $ npm install npm ERR! code ERESOLVE npm ERR! ERESOLVE unable to resolve dependency tree npm ERR! npm ERR! While resolving: mmm-mysqlquery@1.0.0 npm ERR! Found: stylelint@8.4.0 npm ERR! node_modules/stylelint npm ERR! dev stylelint@"^8.3.0" from the root project npm ERR! npm ERR! Could not resolve dependency: npm ERR! peer stylelint@"^14.0.0" from grunt-stylelint@0.17.0 npm ERR! node_modules/grunt-stylelint npm ERR! dev grunt-stylelint@"latest" from the root project npm ERR! npm ERR! Fix the upstream dependency conflict, or retry npm ERR! this command with --force, or --legacy-peer-deps npm ERR! to accept an incorrect (and potentially broken) dependency resolution. npm ERR! npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2022-01-06T12_07_55_731Z-debug.log pi@magicmirror:~/MagicMirror/modules/MMM-MysqlQuery $
@richard238 It seems your versions of npm and node might be older than the required versions. run the following
node -v npm -v
