    MMM-temp-ds18b20
    2 Posts 2 Posters 763 Views 2 Watching
      core
      Hi all,
      just re-installed my Magic Mirror and I wanted to use my sensor for monitoring room temperature again.
      I installed the MMM-temp-ds18b20 module. All went fine during installation, but when I edited my config and started my Magic mirror (via PM2 command), the screen just stays black (but I can see my mouse cursor). So probably, something went wrong by loading this module. Removing the module from the config and everything is okay.
      Additional information: By using the command (ls /sys/bus/w1/devices) I can find my sensor, which is correctly attached to my Pi3B+ and I can read the temperature. But I realized that my sensor ID does not start with 28-XXX but rather 10-XXX.
      Therefore, I edited my config like this:
      module: ‘MMM-temp-ds18b20’,
      position: ‘top_right’,
      header: ‘Temperature sensors’,
      refreshInterval: 10, // in seconds
      displayMode: ‘x-stack’,
      sensors:[
      label: “inside”
      So maybe you can help with the issue that the screen stays black.
      Thank you very much!
      Best regards!
        sdetweil @core
        @core probably this
