    MMM 2.18 - NPM? Electron? Silly lifecycle? no MMM
    9 Posts 4 Posters 1.5k Views 4 Watching
    • karsten13K Offline
      karsten13 @OberfragGER
      @oberfragger yes, in the mm folder
      kaiK 1 Reply Last reply Reply Quote 1
      • kaiK Offline
        kai @karsten13
        Hi @karsten13,
        I had the same problem like @OberfragGER on one of my MMs and I did the clean reinstall you recommended.
        It worked well for me, perfect! Thanks a lot! :thumbs_up_medium-light_skin_tone:
        • O Offline
          OberfragGER @karsten13
          @karsten13 I have reinstalled it.
          Lets wait and cross fingers.
          • O Offline
            OberfragGER
            @karsten13 Still problems.
            Now the mirror hangs about 2-3 times a day… :(
            |MagicMirror  | Invalid MIT-MAGIC-COOKIE-1 key
            0|MagicMirror  | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
            0|MagicMirror  | npm
            0|MagicMirror  |  ERR! code ELIFECYCLE
            0|MagicMirror  | npm ERR! errno
            0|MagicMirror  |  1
            0|MagicMirror  |  magicmirror@2.18.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
            0|MagicMirror  | npm ERR! Exit status 1
            0|MagicMirror  | npm ERR! Failed at the magicmirror@2.18.0 start script.
            0|MagicMirror  | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            0|MagicMirror  | npm ERR! A complete log of this run can be found in:
            0|MagicMirror  | npm ERR!     /home/pi/.npm/_logs/2022-01-14T11_11_15_580Z-debug.log
            0|MagicMirror  | > magicmirror@2.18.0 start /home/pi/MagicMirror
            0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/
            Thats in the log-File:
            1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
            2 info using npm@6.14.15
            3 info using node@v14.18.3
            5 info lifecycle magicmirror@2.18.0~prestart: magicmirror@2.18.0
            6 info lifecycle magicmirror@2.18.0~start: magicmirror@2.18.0
            7 verbose lifecycle magicmirror@2.18.0~start: unsafe-perm in lifecycle true
            8 verbose lifecycle magicmirror@2.18.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
            9 verbose lifecycle magicmirror@2.18.0~start: CWD: /home/pi/MagicMirror
            10 silly lifecycle magicmirror@2.18.0~start: Args: [
            10 silly lifecycle   '-c',
            10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js'
            10 silly lifecycle ]
            11 silly lifecycle magicmirror@2.18.0~start: Returned: code: 1  signal: null
            12 info lifecycle magicmirror@2.18.0~start: Failed to exec start script
            13 verbose stack Error: magicmirror@2.18.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
            13 verbose stack Exit status 1
            13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
            13 verbose stack     at EventEmitter.emit (events.js:400:28)
            13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
            13 verbose stack     at ChildProcess.emit (events.js:400:28)
            13 verbose stack     at maybeClose (internal/child_process.js:1058:16)
            13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
            14 verbose pkgid magicmirror@2.18.0
            15 verbose cwd /home/pi/MagicMirror
            16 verbose Linux 5.10.63-v7l+
            17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
            18 verbose node v14.18.3
            19 verbose npm  v6.14.15
            20 error code ELIFECYCLE
            21 error errno 1
            22 error magicmirror@2.18.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
            22 error Exit status 1
            23 error Failed at the magicmirror@2.18.0 start script.
            23 error This is probably not a problem with npm. There is likely additional logging output above.
            24 verbose exit [ 1, true ]
            • mumblebajM Offline
              mumblebaj Module Developer @OberfragGER
              @oberfragger said in MMM 2.18 - NPM? Electron? Silly lifecycle? no MMM:
              You may want to update your node and npm versions.
                karsten13 @mumblebaj
                @mumblebaj
                its worth a try …
                could also caused by a module.
