    MMM 2.18 - NPM? Electron? Silly lifecycle? no MMM
    9 Posts 4 Posters 1.4k Views 4 Watching
    • O Offline
      OberfragGER
      after Updating to 2.18 (from 2.17) - every 2 days the MM freezes… I dont have any clue why. The raspberryPi is still rechable.
      NPM Version 6.14.15
      pm2 log MagicMirror:
      ERR! magicmirror@2.18.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      Logfile:
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.14.15
      3 info using node@v14.18.2
      5 info lifecycle magicmirror@2.18.0~prestart: magicmirror@2.18.0
      6 info lifecycle magicmirror@2.18.0~start: magicmirror@2.18.0
      7 verbose lifecycle magicmirror@2.18.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.18.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.18.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.18.0~start: Args: [
      10 silly lifecycle   '-c',
      10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js'
      10 silly lifecycle ]
      11 silly lifecycle magicmirror@2.18.0~start: Returned: code: 1  signal: null
      12 info lifecycle magicmirror@2.18.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.18.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      13 verbose stack Exit status 1
      13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack     at EventEmitter.emit (events.js:400:28)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:400:28)
      13 verbose stack     at maybeClose (internal/child_process.js:1058:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
      14 verbose pkgid magicmirror@2.18.0
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 5.10.63-v7l+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      18 verbose node v14.18.2
      19 verbose npm  v6.14.15
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.18.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.18.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      • karsten13K Offline
        karsten13 @OberfragGER
        @oberfragger
        such things are hard to find. We have a new electron version (v16) with mm v2.18.
        Googling ELIFECYCLE you find often to do a clean reinstall which would mean
        rm -f package-lock.json
        rm -rf node_modules
        npm install
        Depends on how you updated, if you did these steps already then it won’t help.
        O 2 Replies Last reply Reply Quote 0
        • O Offline
          OberfragGER @karsten13
          @karsten13 I have used the “rguglar way” with
          git pull && npm install
          In which folder do i have to perform this coommands? Regular MagicMirror-Folder?
            @oberfragger yes, in the mm folder
            kaiK 1 Reply Last reply Reply Quote 1
            • kaiK Offline
              kai @karsten13
              Hi @karsten13,
              I had the same problem like @OberfragGER on one of my MMs and I did the clean reinstall you recommended.
              It worked well for me, perfect! Thanks a lot! :thumbs_up_medium-light_skin_tone:
              • O Offline
                @karsten13 I have reinstalled it.
                Lets wait and cross fingers.
                • O Offline
                  OberfragGER
                  @karsten13 Still problems.
                  Now the mirror hangs about 2-3 times a day… :(
                  |MagicMirror  | Invalid MIT-MAGIC-COOKIE-1 key
                  0|MagicMirror  | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
                  0|MagicMirror  | npm
                  0|MagicMirror  |  ERR! code ELIFECYCLE
                  0|MagicMirror  | npm ERR! errno
                  0|MagicMirror  |  1
                  0|MagicMirror  |  magicmirror@2.18.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                  0|MagicMirror  | npm ERR! Exit status 1
                  0|MagicMirror  | npm ERR! Failed at the magicmirror@2.18.0 start script.
                  0|MagicMirror  | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  0|MagicMirror  | npm ERR! A complete log of this run can be found in:
                  0|MagicMirror  | npm ERR!     /home/pi/.npm/_logs/2022-01-14T11_11_15_580Z-debug.log
                  0|MagicMirror  | > magicmirror@2.18.0 start /home/pi/MagicMirror
                  0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/
                  Thats in the log-File:
                  3 info using node@v14.18.3
                  18 verbose node v14.18.3
                  21 error errno 1
                  • mumblebajM Offline
                    mumblebaj Module Developer @OberfragGER
                    @oberfragger said in MMM 2.18 - NPM? Electron? Silly lifecycle? no MMM:
                    You may want to update your node and npm versions.
                      karsten13 @mumblebaj
                      @mumblebaj
                      its worth a try …
                      could also caused by a module.
