    Google calendar link
    Scheduled Pinned Locked Moved Forum
    9 Posts 2 Posters 3.2k Views 2 Watching
    • N6NGN Offline
      N6NG @N6NG
      @n6ng This is the main screen if I click on the 3 bars on the left again.
      Dennis
        sdetweil @N6NG
        @n6ng click on n6ng@arrl.net, then the three dots
        • N6NGN Offline
          N6NG
          Solved… I found this with a lot of following links… Here is what was said.
          I found something helpful on this; It explains how to share the URL link address as well:
          "Google Calendar - how to share your calendar
          Google Calendar is used by both individuals and businesses. And what’s not to like? It’s free, simple to use and easy to share. If you want to share a Google calendar with another application just follow these instructions:
          Log in to your Google account
          Go to Google Calendar (opens new window)
          Click on the Settings menu cog button  and select Settings
          Under Settings for my calendars click on the calendar you want to share
          Scroll down to the Integrate section
          Select the url labelled Secret address in iCal format and copy it (Can't see the link? Click here)
          This is the link to your Google calendar for use in iCalendar applications"
          Read more on this here:
          https://www.smsclientreminders.com/how_to_share_your_calendar_with_other_applications
          I hope this answer helps! Thanks for your question.
            sdetweil @N6NG
            @n6ng isn’t that what I said above?
            N6NGN 1 Reply Last reply Reply Quote 0
            • N6NGN Offline
              N6NG @sdetweil
              @sdetweil Well I didn’t see anything like that on the left… I had to go to the settings through the cog on the right. After that I could follow your instructions from there…. But thanks again for everyone’s help.
              Dennis
                sdetweil @N6NG
                @n6ng your email under
                my calendars
                on the left
                I looked at your picture
                you have to move the mouse there or the 3 dots don’t appear
