    MMM-PIR -Sensor doesn't work after update
    6 Posts 3 Posters 1.2k Views 3 Watching
      sdetweil @selyjohns
      @selyjohns see
      https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more?page=1
        selyjohns @sdetweil
        @sdetweil Perfect ! Thank you for this sharing :)
        I’ve leave a post to thanks bugsounet.
        Si my #1 problem is now solved.
        Any idea for the #2 ? I’ve always theses lines
        0|mm     | [7143:0119/191711.084830:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
        0|mm     | [7219:0119/191711.800740:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
        Thank you :)
          sdetweil @selyjohns
          @selyjohns ignore them nothing we can do.
          u can try my fixsandbox script from here. might work
          • karsten13K Offline
            karsten13 @sdetweil
            The sandbox error is mentioned in this github electron issue. It’s a chromium bug and everything should still work normally.
              selyjohns
              Ok, so I’ll just ignore it.
              Thank you guys, have a nice day.
