    Error while starting Magic Mirror
    29 Posts 2 Posters 9.7k Views 2 Watching
      sdetweil @1BlauNitrox
      @1blaunitrox that looks like a bad position for a module
      module:
      position: ???
      see the list here
      https://docs.magicmirror.builders/modules/configuration.html
      1 1 Reply Last reply Reply Quote 0
        1BlauNitrox @sdetweil
        This is my config:
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			position: "top_left"
        			module: "calendar_monthly",
        			module: "weather",
        				type: "current",
        				locationID: "cityID", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        				apiKey: "mykey"
        			module: "weather",
        			header: "Wettervorhersage",
        				type: "forecast",
        				apiKey: "mykey"
                    		 module: "MMM-NowPlayingOnSpotify",
         			 position: "bottom_left",
           				 clientID: "myid",
            				 clientSecret: "myid",
            				 accessToken: "mytoken",
            				 refreshToken: "mytoken"
          @1blaunitrox I don’t see a calendar_monthly module
            @sdetweil What do you mean?
            https://github.com/KirAsh4/calendar_monthly/
              @1blaunitrox thx… I used your module list and dont see any issues…
              you did npm install in both new module folders, right?
                @sdetweil no, it worked without
                S 1 2 Replies Last reply Reply Quote 0
                  @1blaunitrox both modules provide a package.json file, which means u must
                  npm install
                  in their folders
                    1BlauNitrox @1BlauNitrox
                    @1blaunitrox my mistake. I did it
                      @1blaunitrox did u update MM?? git pull?
                      did you npm install after?
                        @sdetweil what do you mean “update”. Is there a new update?
                          @1blaunitrox just trying to see what changed
                          every 3 months MM releases a new version… 2.18 now… (January 1)
                            @sdetweil I can try to update. Where should I execute the command “git pull”?
                              @1blaunitrox use my script
                              see
                                @sdetweil I can execute the command from any location?
                                  @1blaunitrox which command?
                                  from my scripts? yes, they figure it out
                                    @sdetweil I executed bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" but the Error is the same
                                      @1blaunitrox notice that upgrade is a TWO part process…
                                      part 1, no parameter, does a TEST to checkout if there are any issues
                                      then
                                      part 2, with apply at the end will DO the upgrade…
                                      looks like you only did part 1
                                          @1blaunitrox ok, so on latest… when did u do that?
                                            @sdetweil I installed the mm software 5 days ago. I have executed the command few minutes ago.
