    Error while starting Magic Mirror
    29 Posts 2 Posters 9.7k Views 2 Watching
      1BlauNitrox @sdetweil
      @sdetweil What do you mean?
      https://github.com/KirAsh4/calendar_monthly/
        sdetweil @1BlauNitrox
        @1blaunitrox thx… I used your module list and dont see any issues…
        you did npm install in both new module folders, right?
        1 1 Reply Last reply Reply Quote 0
          @sdetweil no, it worked without
          S 1 2 Replies Last reply Reply Quote 0
            @1blaunitrox both modules provide a package.json file, which means u must
            npm install
            in their folders
              1BlauNitrox @1BlauNitrox
              @1blaunitrox my mistake. I did it
                @1blaunitrox did u update MM?? git pull?
                did you npm install after?
                  @sdetweil what do you mean “update”. Is there a new update?
                    @1blaunitrox just trying to see what changed
                    every 3 months MM releases a new version… 2.18 now… (January 1)
                      @sdetweil I can try to update. Where should I execute the command “git pull”?
                        @1blaunitrox use my script
                        see
                          @sdetweil I can execute the command from any location?
                            @1blaunitrox which command?
                            from my scripts? yes, they figure it out
                              @sdetweil I executed bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" but the Error is the same
                                @1blaunitrox notice that upgrade is a TWO part process…
                                part 1, no parameter, does a TEST to checkout if there are any issues
                                then
                                part 2, with apply at the end will DO the upgrade…
                                looks like you only did part 1
                                    @1blaunitrox ok, so on latest… when did u do that?
                                      @sdetweil I installed the mm software 5 days ago. I have executed the command few minutes ago.
                                        @1blaunitrox said in Error while starting Magic Mirror:
                                        I install the mm software 5 days ago
                                        hm… about the time u started having trouble
                                        did u go back to modules that had package.json and redo the npm install???
                                        redo my update with
                                        force
                                        at the end
                                        it will redo all the modules
                                          @1blaunitrox I will go to every module and execute npm install -f
                                            @sdetweil same error
