    Error while starting Magic Mirror
    29 Posts 2 Posters 9.3k Views 2 Watching
      sdetweil @1BlauNitrox
      @1blaunitrox just trying to see what changed
      every 3 months MM releases a new version… 2.18 now… (January 1)
      1 1 Reply Last reply Reply Quote 0
      • 1 Offline
        1BlauNitrox @sdetweil
        @sdetweil I can try to update. Where should I execute the command “git pull”?
          @1blaunitrox use my script
          see
          • 1 Offline
            @sdetweil I can execute the command from any location?
              @1blaunitrox which command?
              from my scripts? yes, they figure it out
              • 1 Offline
                @sdetweil I executed bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" but the Error is the same
                  @1blaunitrox notice that upgrade is a TWO part process…
                  part 1, no parameter, does a TEST to checkout if there are any issues
                  then
                  part 2, with apply at the end will DO the upgrade…
                  looks like you only did part 1
                  • 1 Offline
                      @1blaunitrox ok, so on latest… when did u do that?
                      • 1 Offline
                        @sdetweil I installed the mm software 5 days ago. I have executed the command few minutes ago.
                        S 1 2 Replies Last reply Reply Quote 0
                          @1blaunitrox said in Error while starting Magic Mirror:
                          I install the mm software 5 days ago
                          hm… about the time u started having trouble
                          did u go back to modules that had package.json and redo the npm install???
                          redo my update with
                          force
                          at the end
                          it will redo all the modules
                          • 1 Offline
                            1BlauNitrox @1BlauNitrox
                            @1blaunitrox I will go to every module and execute npm install -f
                            • 1 Offline
                              @sdetweil same error
                              • 1 Offline
                                @1blaunitrox I will remove the MagicMirror software with all of its modules and install it new
                                  @1blaunitrox use my install script…
                                  • 1 Offline
                                    @sdetweil I will do
                                      @1blaunitrox rename the existing folder out of the way
                                      mv MagicMirror MagicMirror.old
                                      • 1 Offline
                                        @sdetweil It works btw
