    Error while starting Magic Mirror
    29 Posts 2 Posters 8.9k Views 2 Watching
    • 1 Offline
      1BlauNitrox @sdetweil
      @sdetweil no, it worked without
      S 1 2 Replies Last reply Reply Quote 0
        sdetweil @1BlauNitrox
        @1blaunitrox both modules provide a package.json file, which means u must
        npm install
        in their folders
        • 1 Offline
          1BlauNitrox @1BlauNitrox
          @1blaunitrox my mistake. I did it
            @1blaunitrox did u update MM?? git pull?
            did you npm install after?
            1 1 Reply Last reply Reply Quote 0
            • 1 Offline
              @sdetweil what do you mean “update”. Is there a new update?
                @1blaunitrox just trying to see what changed
                every 3 months MM releases a new version… 2.18 now… (January 1)
                • 1 Offline
                  @sdetweil I can try to update. Where should I execute the command “git pull”?
                    @1blaunitrox use my script
                    see
                    • 1 Offline
                      @sdetweil I can execute the command from any location?
                        @1blaunitrox which command?
                        from my scripts? yes, they figure it out
                        • 1 Offline
                          @sdetweil I executed bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" but the Error is the same
                            @1blaunitrox notice that upgrade is a TWO part process…
                            part 1, no parameter, does a TEST to checkout if there are any issues
                            then
                            part 2, with apply at the end will DO the upgrade…
                            looks like you only did part 1
                            • 1 Offline
                                @1blaunitrox ok, so on latest… when did u do that?
                                • 1 Offline
                                  @sdetweil I installed the mm software 5 days ago. I have executed the command few minutes ago.
                                    @1blaunitrox said in Error while starting Magic Mirror:
                                    I install the mm software 5 days ago
                                    hm… about the time u started having trouble
                                    did u go back to modules that had package.json and redo the npm install???
                                    redo my update with
                                    force
                                    at the end
                                    it will redo all the modules
                                    • 1 Offline
                                      @1blaunitrox I will go to every module and execute npm install -f
                                      • 1 Offline
                                        @sdetweil same error
                                        • 1 Offline
                                          @1blaunitrox I will remove the MagicMirror software with all of its modules and install it new
                                            @1blaunitrox use my install script…
