    Need Help with MMM-Remote-Control
    6 Posts 3 Posters 1.1k Views 3 Watching
      ccrichtx
      I get the following error when trying to access http://192.168.1.38:8080/remote.html from my laptop or cell phone that are on the same network. Magic Mirror starts with no errors. I have tried with no success to fix the problem and just don’t no enough find the problem. I would appreciate some help.
      Error in Chrome browser:
      “This device is not allowed to access your mirror.
      Please check your config.js or config.js.sample to change this.”
      Config.js
      let config = {
      address: “0.0.0.0”, // Address to listen on, can be:
      // - “0.0.0.0”, “::” to listen on any interface
      // Default, when address config is left out or empty, is “localhost”
      port: 8080,
      basePath: “/”, // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.20”, “::ffff:192.168.1.26”],
      module: ‘MMM-Remote-Control’,
      position: ‘bottom_left’,
      customCommand: {}, // Optional, See “Using Custom Commands” below
      showModuleApiMenu: true, // Optional, Enable the Module Controls menu
      secureEndpoints: true, // Optional, See API/README.md
      // uncomment any of the lines below if you’re gonna use it
      // customMenu: “custom_menu.json”, // Optional, See “Custom Menu Items” below
      // apiKey: “b741bc26c4b044db9ff9b57b3666d2093”, // Optional, See API/README.md for details
      // classes: {} // Optional, See “Custom Classes” below
      • karsten13K Online
        karsten13 @ccrichtx
        @ccrichtx
        propably a problem with ipWhitelist, you could try with ipWhitelist: [], and if this work you should set correct values, more infos here.
          ccrichtx @karsten13
          @karsten13
          Karsten thanks for you input. removing ipWhitelist parameters worked and leaving it blank [],
          Log file nohup.out showed the following error:
          [30.01.2022 19:55.51.116] [LOG] Access denied to IP address: 192.168.1.20
          [30.01.2022 19:55.54.685] [LOG] Access denied to IP address: 192.168.1.20
          My network is running IPv6 and I tried CIDR /47, /55, /63 and the changes did not work. I will check my home router and see what i can configure to allow.
          I appreciate your expert advise and the time to look at my post.
            ccrichtx @ccrichtx
            @ccrichtx
            I also tried: “::fff:192.168.1.1/112” and “::ffff:192.168.1.1/120” and they did not work.
              sdetweil @ccrichtx
              @ccrichtx ip6 doesn’t use any of the ip4 numbers!
              completely different
              no reason to use ip6 in a home network
              I recommend not using any ipWhitelist unless u are worried your kids, friends or spouse might access mm when u don’t want them to.
                ccrichtx @sdetweil
                Thanks and appreciate the advise! I will leave IPWhitelist blank. I appreciate your input.
