    MMM-NowPlayingOnSpotify no longer working?
    21 Posts 3 Posters 6.4k Views 3 Watching
      droidus
      I followed the instructions, and even deleted/created a new app in spotify dev, but after submitting step 2, the step 2 fields go away, and step 3 says it is waiting for step 2 to complete.
        sdetweil @droidus
        @droidus sorry, we(I) don’t know what steps you are talking about
          droidus @sdetweil
          @sdetweil The steps are listed here: https://github.com/raywo/MMM-NowPlayingOnSpotify
            sdetweil @droidus
            @droidus are you doing this
            “When the app is running you can access it by opening localhost:8888 in your browser. Provided you are doing this directly on your Raspberry Pi”
              droidus @sdetweil
              @sdetweil said in MMM-NowPlayingOnSpotify no longer working?:
              No, I am accessing via the 192. address.
                sdetweil @droidus
                @droidus did u try on the pi?
                  droidus @sdetweil
                  @sdetweil No, this is a LXC container.
                    sdetweil @droidus
                    @droidus so are the ports mapped? 8888 on the container to something on the host?
                    unless u did that, that is not accessible
                    the request will cause a callback to that system
                      droidus @sdetweil
                      @sdetweil I don’t see port 8888 running on the container.
                        sdetweil @droidus
                        @droidus
                        the authorization , step 2
                        cd authorization
                        node app
                        should run forever
                        and app.js uses port 8888
                        so u have to run this IN the container, right?
                          droidus @sdetweil
                          @sdetweil Yes, it looks like the ports are mapped. I can reach the IP/port from my laptop.
                            sdetweil @droidus
                            @droidus ip:8888 right?
                            so when u open that with your laptop browser, you should see
                            this page https://github.com/raywo/MMM-NowPlayingOnSpotify/authorization/public/index.html
                              droidus @sdetweil
                              @sdetweil Correct. I see that.
                                sdetweil @droidus
                                @droidus and u fill in the fields from the spotify dev account
                                what did you do for this step in the doc?
                                u had to do the host address, right?
                                Click on “Edit Settings” and add http://localhost:8888/callback to the Redirect URIs and save your settings.
                                I just did this on my spotify account and it brought up the auth page as expected… and authorize click brought the page with the code in
                                  droidus @sdetweil
                                  @sdetweil so before for the ip, I was using my 192. address, but I tried localhost, and it errors saying: “INVALID_CLIENT: Invalid redirect URI”.
                                    sdetweil @droidus
                                    @droidus I did that, forgot to add the /callback on the redirect on the Spotify page and the mapped port is 8888 on both sides, yes?
                                    on the host opens the auth page from the container
                                      droidus @sdetweil
                                      @sdetweil This is what I am seeing after entering those fields:
                                        sdetweil @droidus
                                        @droidus so , is there any info on the node app running in the container?
                                        also open the developers window on the auth page before login, ctrl-shift-i on the keyboard, select the console tab
                                          droidus @sdetweil
                                          @sdetweil Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://api.spotify.com/v1/me. (Reason: CORS request did not succeed). Status code: (null).
                                          karsten13K S 2 Replies Last reply Reply Quote 0
                                          • karsten13K Offline
                                            karsten13 @droidus
                                            @droidus
                                            https://github.com/raywo built some nice modules but they are now unmaintained since 4 years. So there will be no fixes, may you find a fork which is still maintained.
                                            You could may fix it using a cors proxy (google will help) or you could use the built in cors proxy of mm which is not released yet (you have to use the develop branch for this).
                                            You find the url to proxy in this line.
