    MMM-NotificationTrigger second trigger not working
    14 Posts 3 Posters 4.3k Views 3 Watching
      Arynio
      Basically, I want to use MMM-NotificationTrigger to turn my TV on and off by using the notification(MOTION_DETECTED with some value) from MMM-MotionDetector.
      This is my config for MMM-NotificationTrigger:
      module: “MMM-NotificationTrigger”,
      triggers:[
      trigger: “MOTION_DETECTED”,
      fires: [
      fire:“TURN_OFF”,
      exec: “echo ‘on 0.0.0.0’ | cec-client -s -d 1”,
      trigger: “TURN_OFF”,
      fires: [
      delay: 20000,
      fire: “OKAY”,
      exec: “echo ‘standby 0.0.0.0’ | cec-client -s -d 1”,
      The turning on part works, however the second trigger never reacts to the TURN_OFF and never sends an OKAY. Am I doing something wrong ?
      S M 3 Replies Last reply Reply Quote 0
        sdetweil @Arynio
        @arynio delay is 20 seconds… a long time
        maybe try 2000
          Arynio @sdetweil
          @sdetweil Have tried that, but that doesn’t change anything.
          My main problem is that the second trigger never reacts.
          I have never seen it fire a OKAY as an answer
            sdetweil @Arynio
            @arynio who is listening for the fire notification?
            not in your config.
            turn_off fires okay after 20 seconds
            but no one is listening for it
              Arynio @sdetweil
              @sdetweil Yeah TURN_OFF fires fine.
              MMM-NotificationTrigger is supposed to listen to its own TURN_OFF and fire again so that it will turn the screen off after a 20-second delay
                sdetweil @Arynio
                @arynio add a module that reports all the notifications
                my SampleModule does this
                https://github.com/sdetweil/SampleModule
                then open the developers window, ctrl-shift-i on the keyboard, and select the console tab to see the messages
                  Arynio @sdetweil
                  @sdetweil Can i do this via ssh or do I have to connect my keyboard to my pi?
                    sdetweil @Arynio
                    @arynio if u set
                    address:“0.0.0.0”,
                    ipWhitelist:[],
                    in config.js for mm
                    then you can use a browser on your PC to access mm, and do the same debugging
                      Arynio
                      This is what happens when motion is detected:
                      MMM-MotionDetector: Motion detected, score 28
                      MMM-NotificationTrigger.js:84 [NOTTRG] TURN_OFF is emitted.
                      MMM-MotionDetector.js:89 MMM-MotionDetector: Motion detected, score 29
                      MMM-MotionDetector.js:89 MMM-MotionDetector: Motion detected, score 67
                      null:1 GET http://localhost:8080/null 404 (Not Found)
                      Image (async)
                      getDom @ MMM-EveryNews.js:118
                      (anonymous) @ main.js:113
                      updateDom @ main.js:111
                      updateDom @ main.js:550
                      updateDom @ module.js:358
                      (anonymous) @ MMM-EveryNews.js:146
                      MMM-NotificationTrigger.js:42 [NOTTRG] Execution Result: {trigger: ‘MOTION_DETECTED’, fire: ‘TURN_OFF’, error: null, stdout: ‘opening a connection to the CEC adapter…\n’, stderr: ‘’}
                      MMM-NotificationTrigger.js:42 [NOTTRG] Execution Result: {trigger: ‘MOTION_DETECTED’, fire: ‘TURN_OFF’, error: null, stdout: ‘opening a connection to the CEC adapter…\nERROR: … 4085]\tcould not open a connection (try 5)\n’, std>
                      MMM-NotificationTrigger.js:42 [NOTTRG] Execution Result: {trigger: ‘MOTION_DETECTED’, fire: ‘TURN_OFF’, error: {…}, stdout: ‘opening a connection to the CEC adapter…\nERROR: … 10208]\tcould not start CEC communications\n’, stde>null:1 GET http://localhost:8080/null 404 (Not Found)
                      So i know that there are some erros about not being able to connect but it still works fine regardless.
                      Still the main problem is that TURN_OFF is emitted but I never get a reaction to it from my second trigger.
                        sdetweil @Arynio
                        @arynio said in MMM-NotificationTrigger second trigger not working:
                        so there was an error
                        did it get emitted? (NOTTRG)
                        does it depend on the results from exec?
                        ( I do not know anything about module, just guessing)
                        do u see it on the notifications received by other modules?
