Trouble with install MM
8 Posts 2 Posters 1.1k Views 2 Watching
  • F Offline
    fischi87
    Hello guys, I try to start a second mirror but I get this error: somebody a solution?
    is a fresh install!
    pi@raspberrypi:~/MagicMirror $ cat /home/pi/.npm/_logs/2022-02-26T20_40_40_863Z-debug.log
    1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'start' ]
    2 info using npm@6.14.12
    3 info using node@v10.24.1
    5 info lifecycle magicmirror@2.18.0~prestart: magicmirror@2.18.0
    6 info lifecycle magicmirror@2.18.0~start: magicmirror@2.18.0
    7 verbose lifecycle magicmirror@2.18.0~start: unsafe-perm in lifecycle true
    8 verbose lifecycle magicmirror@2.18.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
    9 verbose lifecycle magicmirror@2.18.0~start: CWD: /home/pi/MagicMirror
    10 silly lifecycle magicmirror@2.18.0~start: Args: [ '-c',
    10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
    11 silly lifecycle magicmirror@2.18.0~start: Returned: code: 1  signal: null
    12 info lifecycle magicmirror@2.18.0~start: Failed to exec start script
    13 verbose stack Error: magicmirror@2.18.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
    13 verbose stack Exit status 1
    13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
    13 verbose stack     at EventEmitter.emit (events.js:198:13)
    13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
    13 verbose stack     at ChildProcess.emit (events.js:198:13)
    13 verbose stack     at maybeClose (internal/child_process.js:982:16)
    13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    14 verbose pkgid magicmirror@2.18.0
    15 verbose cwd /home/pi/MagicMirror
    16 verbose Linux 5.10.63-v7l+
    17 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "start"
    18 verbose node v10.24.1
    19 verbose npm  v6.14.12
    20 error code ELIFECYCLE
    21 error errno 1
    22 error magicmirror@2.18.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
    22 error Exit status 1
    23 error Failed at the magicmirror@2.18.0 start script.
    23 error This is probably not a problem with npm. There is likely additional logging output above.
    24 verbose exit [ 1, true ]
    S 1 Reply Last reply Feb 26, 2022, 9:01 PM Reply Quote 0
    • F Offline
      fischi87 @sdetweil
      @sdetweil said in Trouble with install MM:
      @fischi87 are u running system in graphics mode? must have desktop, before starting mm
      yes I do!
      i don’t had the display connected. now it works!
        sdetweil @fischi87
        @fischi87 need node 14 or 16.
        use my install script.
        see
        erase the MagicMirror folder first
        F 1 Reply Last reply Feb 26, 2022, 9:03 PM Reply Quote 0
        • F Offline
          fischi87 @sdetweil
          tried already but I get this:
          install log being saved to /home/pi/install.log
          system running in command line mode, configured for graphical desktop, please reboot
          S 1 Reply Last reply Feb 26, 2022, 9:20 PM Reply Quote 0
            sdetweil @fischi87
            @fischi87 yes, needs to be in desktop mode. electron/browser draws graphics
            cannot be lite version
            F 2 Replies Last reply Feb 26, 2022, 9:21 PM Reply Quote 0
            • F Offline
              fischi87 @sdetweil
              i upgrade and now I get this after npm run start:
              /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTRAP
              S 1 Reply Last reply Feb 26, 2022, 9:34 PM Reply Quote 0
              • F Offline
                fischi87 @sdetweil
                what can I do to geht the electron/browser draws graphics?
                  sdetweil @fischi87
                  F 1 Reply Last reply Feb 27, 2022, 10:35 AM Reply Quote 0
                  • F Offline
                    fischi87 @sdetweil
                    yes I do!
