    Update MM 2 not sucessfull
    2 Posts 2 Posters 839 Views 2 Watching
    • C
      chris1971
      Hi, I tried to update MM2 to 2.0.6 with git pull.
      The result is:
      pi@raspberrypi:~/MagicMirror $ git pull
      error: object file .git/objects/f2/99ba6218ab2557af8b84010ca5f5cee453bd06 is empty
      fatal: loose object f299ba6218ab2557af8b84010ca5f5cee453bd06 (stored in .git/objects/f2/99ba6218ab2557af8b84010ca5f5cee453bd06) is corrupt
      fatal: The remote end hung up unexpectedly
      Any ideas whats going wrong? Where can I see the version number from the installed MM?
      Thanks, Chris
      • N
        nolanchrist007
        You can take a look at this post which may help you in your problem.
        https://www.cs.swarthmore.edu/~adanner/help/git/git-merge.php
        Let me know if it helped you. Also fix sim not provisioned error.
