    Would this be possible?
    17 Posts 4 Posters 4.9k Views 4 Watching
      motdog
      I have the Spotify module that I love, but when I am not playing music I hate the black space in the corner where I have it located. Could I set it up so that when I am not playing Spotify music that another module shows in the space and when I play music, the module disappears? I know on the remote module I can manually hide and show modules but I want it done automatically. Can it be done?
        bolish
        I believe you can do it with MMM-NotificationTrigger and MMM-RemoteControl.
        i.e :
        When Spotify stops, send notification “SPOTIFY STOP”. (within Spotify module)
        When “SPOTIFY STOP” is received by MMM-NotificationTrigger, send “HIDE MODULE Spotify” to MMM-RemoteControl.
        Of course, code is not correctly written, but that’s how I would do it. MMM-NotificationTrigger and MMM-RemoteControl are pretty easy to use.
        FYI, I’m already doing that with news / compliments modules. When news article is made bigger by the “Article_more-details” notification, then the compliment module is hidden.
        Once “article-less-details” is triggered, then the compliment module is shown again.
        Regards
          motdog @bolish
          @bolish Thanks. I guess then I could also reverse it so when spotify plays music, it would hide the other module and then spotify would appear on my mirror.
            bolish
            Correct.
            • ? Offline
              A Former User @motdog
              @motdog
              Are you talking about “MMM-Spotify”?
              You can do it more simple way.
              Add this into your css/custom.css
              #SPOTIFY.pausing {
              display:none;
              This could make module hiding when paused.
              M S 2 Replies Last reply Reply Quote 0
                bolish
                When the boss talks… :-)
                Indeed it seems easier as @Sean proposed if you use his new MMM-Spotify module. (Which I will try soon also).
                I’ve learnt one more thing myself.
                Thanks.
                  motdog @Guest
                  @Sean yep. That’s it. So if I put another module in the same spot but after it in the config, Spotify would show up when playing and when paused/shut down the other module would show up?
                  • ? Offline
                    @motdog
                    Later module will jump down when spotify is appeared.
                      motdog @Guest
                      @Sean after further review I am using MMM-NowPlayingonSpotify Would it work on that or do I need to install MMM-Spotify. Looks like they do the same thing, MMM-Spotify lets you control via voice if you so choose, which I don’t have set up but it shouldn’t be a problem I assume.
                      • ? Offline
                        @motdog
                        Controlling spotify on MM (besides voice, there could be many possibilities, - sensors, or any programmable condition) is difference. If you need not, nothing different.
