    Help with Update to 2.7.0
    13 Posts 5 Posters 5.9k Views 5 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor
      pi@raspberrypi:~ $ cd MagicMirror
      pi@raspberrypi:~/MagicMirror $ git stash
      fatal: Unable to create '/home/pi/MagicMirror/.git/index.lock': File exists.
      Another git process seems to be running in this repository, e.g.
      an editor opened by 'git commit'. Please make sure all processes
      are terminated then try again. If it still fails, a git process
      may have crashed in this repository earlier:
      remove the file manually to continue.
      Cannot save the current index state
      pi@raspberrypi:~/MagicMirror $ git pull
      Updating de57daa..b508a62
      pi@raspberrypi:~/MagicMirror $ npm install
      > magicmirror@2.6.0 install /home/pi/MagicMirror
      > cd vendor && npm install
      npm notice created a lockfile as package-lock.json. You should commit this file.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      audited 220 packages in 11.323s
      found 4 low severity vulnerabilities
        run `npm audit fix` to fix them, or `npm audit` for details
      > magicmirror@2.6.0 postinstall /home/pi/MagicMirror
      > sh installers/postinstall/postinstall.sh && npm run install-fonts
      MagicMirror installation successful!
      > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
      > cd fonts && npm install
      audited 1 package in 2.065s
      found 0 vulnerabilities
      npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
      audited 2427 packages in 54.343s
      found 12 vulnerabilities (6 low, 6 moderate)
      still not working…
        sdetweil
        @swvalenti said in Help with Update to 2.7.0:
        ok, erase that file, or rename it out of the way
        then
        git pull
          Thanks @sdetweil had to remove all the .json/locks and the .git after I had to enable show hidden files as I couldn’t find same. You da man Sam.
