    Help with Update to 2.7.0
    13 Posts 5 Posters 7.2k Views 5 Watching
      sdetweil @Kenny
      @Kenny could u do
      git remote -v
      • K
        Kenny
        git remote -v
        RESPONSE:
        origin https://github.com/MichMich/MagicMirror.git (fetch)
        origin https://github.com/MichMich/MagicMirror.git (push)
        • CyruS1337C
          CyruS1337 Project Sponsor
          Run the following command in the MagicMirror folder
          rm package-lock.json
          rm vendor/package-lock.json
          Then execute in the folder the usual command for the upload
          git pull && npm install
          Now it should work
          Atelier-Made-in-iKiA 1 Reply Last reply
          Reply Quote 2
          • K
            Kenny
            Thanks for the help @sdetweil and @CyruS1337. The latest suggestion gave me the same "Updating … " response.
            I just renamed my MagicMirror folder and did a clean install. Everything is working great again. THANKS!
            • Atelier-Made-in-iKiA
              Atelier-Made-in-iKi @CyruS1337
              @CyruS1337 said in Help with Update to 2.7.0:
              Now it should work
              @CyruS1337 this solved the firt install command but…
              ownloading tmp-2822-0-electron-v3.0.13-linux-armv7l.zip
              Error: read ECONNRESET
              /home/pi/MagicMirror/node_modules/electron/install.js:49
                throw err
                  at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
              npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
              npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! electron@3.0.13 postinstall: `node install.js`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the electron@3.0.13 postinstall script.
              npm ERR!     /home/pi/.npm/_logs/2019-04-05T19_09_38_688Z-debug.log
              pi@raspberrypi:~/MagicMirror $
              > magicmirror@2.7.1 start /home/pi/MagicMirror
              > sh run-start.sh
              run-start.sh: 4: run-start.sh: electron: not found
              npm ERR! file sh
              npm ERR! errno ENOENT
              npm ERR! syscall spawn
              npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
              npm ERR! spawn ENOENT
              npm ERR!
              npm ERR! Failed at the magicmirror@2.7.1 start script.
              if an idea
              thanks
              Jean-Philippe
              • swvalentiS
                swvalenti Project Sponsor
                pi@raspberrypi:~ $ cd MagicMirror
                pi@raspberrypi:~/MagicMirror $ git remote -v
                pi@raspberrypi:~/MagicMirror $ rm package-lock.json
                pi@raspberrypi:~/MagicMirror $ rm vendor/package-lock.json
                pi@raspberrypi:~/MagicMirror $ git pull && npm install
                Updating de57daa..b508a62
                Still have the same issue and can’t update…any help would be appreciated.
                  @swvalenti said in Help with Update to 2.7.0:
                  ok, lets try this
                  git stash
                  git pull
                  if ok, then npm install
                  • swvalentiS
                    pi@raspberrypi:~/MagicMirror $ git stash
                    fatal: Unable to create '/home/pi/MagicMirror/.git/index.lock': File exists.
                    Another git process seems to be running in this repository, e.g.
                    an editor opened by 'git commit'. Please make sure all processes
                    are terminated then try again. If it still fails, a git process
                    may have crashed in this repository earlier:
                    remove the file manually to continue.
                    Cannot save the current index state
                    pi@raspberrypi:~/MagicMirror $ npm install
                    > magicmirror@2.6.0 install /home/pi/MagicMirror
                    > cd vendor && npm install
                    npm notice created a lockfile as package-lock.json. You should commit this file.
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    audited 220 packages in 11.323s
                    found 4 low severity vulnerabilities
                      run `npm audit fix` to fix them, or `npm audit` for details
                    > magicmirror@2.6.0 postinstall /home/pi/MagicMirror
                    > sh installers/postinstall/postinstall.sh && npm run install-fonts
                    MagicMirror installation successful!
                    > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
                    > cd fonts && npm install
                    audited 1 package in 2.065s
                    found 0 vulnerabilities
                    audited 2427 packages in 54.343s
                    found 12 vulnerabilities (6 low, 6 moderate)
                    still not working…
                      ok, erase that file, or rename it out of the way
                      then
                      git pull
                      • swvalentiS
                        Thanks @sdetweil had to remove all the .json/locks and the .git after I had to enable show hidden files as I couldn’t find same. You da man Sam.
