    Update to MagicMirror² v2.7.0 fails
    6 Posts 3 Posters 3.2k Views 3 Watching
    • D
      drfukc
      Hi MagicMirror fans,
      I try to update my v2.6.0 installation to v2.7.0 with executing the following steps:
      1. sudo apt-get update
      2. sudo apt-get dist-upgrade
      3. reboot
      all steps above without errors, and now from inside the MagicMirror directory:
      1. git pull && npm install
      This throws me the following errors lines:
      Aktualisiere de57daa..b508a62
      error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
      überschrieben werden:
      	package-lock.json
      	vendor/package-lock.json
      Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen.
      Please, commit your changes or stash them before you can merge.
      Abbruch
      Looks like a simple git issue, but what are the recommended steps to solve this issue?
      How do I commit my changes?
      running this command?
      git commit -m
      Hope you can help :-)
      Cheers
      ukc
        sdetweil @drfukc
        @drfukc erase those two files
        git pull, then npm install in MM, and then each module that has a package.json file
        • D
          drfukc
          partially it worked though the upgrade still terminates with this error message after running “sudo npm install” in the MM directory and all external modules that have a package.json file.
          However, all of these have prompted me that they are already up-to-date.
          These are my steps:
          pi@magicmirror:~/MagicMirror $ sudo npm install
          npm WARN tar ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/.staging/eslint-8983ee3d/LICENSE'
          npm WARN tar ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/.staging/eslint-8983ee3d/README.md'
          ... tons of similar WARNINGS in between ... and removed here for better removed for better readability
          npm WARN tar ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/.staging/lodash-9ecaa656/lastIndexOf.js'
          npm WARN tar ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/.staging/lodash-9ecaa656/LICENSE'
          npm WARN tar ENOENT: no such file or directory, open '/home/pi/MagicMirror/node_modules/.staging/lodash-9ecaa656/lodash.js'
          npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
          npm ERR! err.code.match is not a function
          npm ERR!     /root/.npm/_logs/2019-04-05T07_27_16_446Z-debug.log
          now I check “2019-04-05T07_27_16_446Z-debug.log” but unfortunately this does not help me either:
          842 silly saveTree ├── valid-url@1.0.9
          842 silly saveTree └─┬ walk@2.3.14
          842 silly saveTree   └── foreachasync@3.0.0
          843 warn acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
          844 warn grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
          845 verbose stack TypeError: err.code.match is not a function
          845 verbose stack     at BB.try.catch.err (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/with-tarball-stream.js:110:55)
          845 verbose stack     at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
          845 verbose stack     at Promise._settlePromiseFromHandler (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:512:31)
          845 verbose stack     at Promise._settlePromise (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:569:18)
          845 verbose stack     at Promise._settlePromise0 (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:614:10)
          845 verbose stack     at Promise._settlePromises (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:690:18)
          845 verbose stack     at _drainQueueStep (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:138:12)
          845 verbose stack     at _drainQueue (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:131:9)
          845 verbose stack     at Async._drainQueues (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:147:5)
          845 verbose stack     at Immediate.Async.drainQueues (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
          845 verbose stack     at runCallback (timers.js:794:20)
          845 verbose stack     at tryOnImmediate (timers.js:752:5)
          845 verbose stack     at processImmediate [as _immediateCallback] (timers.js:729:5)
          846 verbose cwd /home/pi/MagicMirror
          847 verbose Linux 4.14.98-v7+
          848 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "install"
          849 verbose node v8.11.1
          850 verbose npm  v6.9.0
          851 error err.code.match is not a function
          852 verbose exit [ 1, true ]
          When opening MagicMirror it looks like I have v2.7.0 installed, since the upgrading message has disappeared and things seem functional.
          However my feeling is that the upgrade is just in the middle of somewhere, though the mirror is working.
          Cheers
          ukc
            sdetweil
            you should not have done sudo npm install… this does the setup as root… which will cause problems later
            also, looks like npm is downlevel , so do
            all these from the MagicMirror folder
            npm -v
            npm install -g npm
            npm -v
            this will show old and new versions
            then
             sudo rm -rf node_modules
            and then
            npm install
            again
            • D
              drfukc
              Hi Sam,
              thanks for your support, but unfortunately this takes me to the next issue when executing:
              pi@magicmirror:~ $ npm -v
              6.9.0
              pi@magicmirror:~/MagicMirror $ npm install -g npm
              npm WARN checkPermissions Missing write access to /usr/lib/node_modules
              npm ERR! path /usr/lib/node_modules
              npm ERR! code EACCES
              npm ERR! errno -13
              npm ERR! syscall access
              After, I changed permissions for /usr/lib/node_modules, but it simply took me to the next error.
              I think I will re-start from scratch.
              Cheers
              ukc
              • DæmonEyesD
                DæmonEyes
                Check out this thread: https://forum.magicmirror.builders/topic/10212/update-help
                @thedoorsfanatic helped me fix this problem on mine.
