    Update Help
    12 Posts 5 Posters 7.5k Views 5 Watching
      jhwwhite
      Hello,
      I’m having some trouble with the update when I tried to install I get this error
      Updating de57daa..b508a62
      error: Your local changes to the following files would be overwritten by merge:
      	package-lock.json
      Please commit your changes or stash them before you merge.
      Aborting
      when I try to remove the offending file I get this
      rm: cannot remove 'pacage-lock.json': No such file or directory
      pi@raspberrypi:~/MagicMirror $ rm package-lock.json
      rm: cannot remove 'package-lock.json': No such file or directory
      Does anyone have any clue how I proceed?
      thedoorsfanaticT DæmonEyesD 2 Replies Last reply Reply Quote 1
      • thedoorsfanaticT Offline
        thedoorsfanatic @jhwwhite
        @jhwwhite
        I had a similar problem.
        Have you tried this?
        Inside the MagicMirror directory:
        git stash
        Then
        git pull
        Then
        npm install
        Afte that search in which module the package file is located and
        npm install
        My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
        DæmonEyesD 1 Reply Last reply Reply Quote 1
          jhwwhite
          That did it! Thanks so much!
          thedoorsfanaticT 1 Reply Last reply Reply Quote 0
          • DæmonEyesD Offline
            DæmonEyes @thedoorsfanatic
            @thedoorsfanatic I tried this but this happened when I tried git stash
              DæmonEyes @jhwwhite
              @jhwwhite I’m a similar situation, but with a few more lines to my error message
              • CyruS1337C Offline
                CyruS1337 Project Sponsor
                Try it like this:
                Run the following command in the MagicMirror folder
                rm vendor/package-lock.json
                Then execute in the folder the usual command for the upload
                git pull && npm install
                Now it should work
                  thedoorsfanatic @DæmonEyes
                  @DæmonEyes
                  Just fill in your github user email and username
                    @DæmonEyes
                    This is what worked for me but I am a beginner, too
                    git stash
                    Then
                    git pull
                    Then
                    npm install
                    After that search for modules that use package.json files, go to their directories and
                    npm install
                      @jhwwhite
                      Great, I am glad that worked for you, too!
                        @thedoorsfanatic Thanks, I wasn’t sure what email/username they wanted and I didn’t even have a github profile, so I created one. And then everything worked after that!
