    MMM-PIR doesn´t turn off monitor since update MM 2.7
    25 Posts 9 Posters 14.0k Views 9 Watching
      shgmongohh
      I have make a fresh install of MM V2.7 on my RPi3 with Raspian Jessi. Everything went well but MMM-PIR doesn´t work.
      The wiring is ok because with an old MM Version (2.1.) everything was ok.
      Has anbody the same problem respectively has a solution for this problem?
      Sebastian
        sdetweil
        i believe that you will have to force recompile in the MMM-PIR folder… as the dependent epoll module doesn’t supply a version for this version of electron
        from MMM-PIR folder do
        npm install electron-rebuild
        then
        ./node_modules/.bin/electron-rebuild
        S F 2 Replies Last reply
        Reply Quote 1
          shgmongohh @sdetweil
          Thanks for your help, but i get the follwing errer, wenn i type in
          pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $  ./node_modules/.bin/electron-rebuild
          ✖ Rebuild Failed
          An unhandled error occurred inside electron-rebuild
          gyp info it worked if it ends with ok
          gyp info using node-gyp@3.8.0
          gyp info using node@10.15.3 | linux | arm
          gyp http GET https://atom.io/download/electron/v3.0.13/iojs-v3.0.13-headers.tar.gz
          gyp http 200 https://atom.io/download/electron/v3.0.13/iojs-v3.0.13-headers.tar.gz
          gyp http GET https://atom.io/download/electron/v3.0.13/SHASUMS256.txt
          gyp http 200 https://atom.io/download/electron/v3.0.13/SHASUMS256.txt
          gyp info spawn /usr/bin/python2
          gyp info spawn args [ '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/gyp/gyp_main.py',
          gyp info spawn args   'binding.gyp',
          gyp info spawn args   '-f',
          gyp info spawn args   'make',
          gyp info spawn args   '-I',
          gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi/build/config.gypi',
          gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/addon.gypi',
          gyp info spawn args   '/root/.electron-gyp/iojs-3.0.13/common.gypi',
          gyp info spawn args   '-Dlibrary=shared_library',
          gyp info spawn args   '-Dvisibility=default',
          gyp info spawn args   '-Dnode_root_dir=/root/.electron-gyp/iojs-3.0.13',
          gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp',
          gyp info spawn args   '-Dnode_lib_file=/root/.electron-gyp/iojs-3.0.13/<(target_arch)/iojs.lib',
          gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi',
          gyp info spawn args   '-Dnode_engine=v8',
          gyp info spawn args   '--depth=.',
          gyp info spawn args   '--no-parallel',
          gyp info spawn args   '--generator-output',
          gyp info spawn args   'build',
          gyp info spawn args   '-Goutput_dir=.' ]
          gyp info spawn make
          gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
          make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi/build'
            CXX(target) Release/obj.target/wiringPi/src/addon.o
            CXX(target) Release/obj.target/wiringPi/src/wiringPi.o
          ../src/wiringPi.cc: In function 'void nodemodule::setup(const v8::FunctionCallbackInfo<v8::Value>&)':
          ../src/wiringPi.cc:52:53: warning: 'v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)' is deprecated (declared at /root/.electron-gyp/iojs-3.0.13/deps/v8/include/v8.h:2819): Use Isolate version [-Wdeprecated-declarations]
               String::Utf8Value mode(GET_ARGUMENT_AS_STRING(0));
          In file included from ../src/wiringPi.h:4:0,
                           from ../src/wiringPi.cc:1:
          ../src/wiringPi.cc: In function 'void nodemodule::initwiringPi(v8::Isolate*, v8::Handle<v8::Object>)':
          ../src/addon.h:45:15: error: 'class v8::Object' has no member named 'ForceSet'
                 target->ForceSet(v8::String::NewFromUtf8(isolate, #name, v8::String::kInternalizedString), \
          ../src/wiringPi.cc:714:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(WPI_MODE_PINS);
          ../src/wiringPi.cc:715:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(WPI_MODE_PHYS);
          ../src/wiringPi.cc:716:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(WPI_MODE_GPIO);
          ../src/wiringPi.cc:717:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(WPI_MODE_GPIO_SYS);
          ../src/wiringPi.cc:718:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(WPI_MODE_PIFACE);
          ../src/wiringPi.cc:719:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(WPI_MODE_UNINITIALISED);
          ../src/wiringPi.cc:723:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(INPUT);
          ../src/wiringPi.cc:724:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(OUTPUT);
          ../src/wiringPi.cc:725:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PWM_OUTPUT);
          ../src/wiringPi.cc:726:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(GPIO_CLOCK);
          ../src/wiringPi.cc:727:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(SOFT_PWM_OUTPUT);
          ../src/wiringPi.cc:728:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(SOFT_TONE_OUTPUT);
          ../src/wiringPi.cc:731:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PUD_OFF);
          ../src/wiringPi.cc:732:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PUD_DOWN);
          ../src/wiringPi.cc:733:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PUD_UP);
          ../src/wiringPi.cc:736:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(HIGH);
          ../src/wiringPi.cc:737:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(LOW);
          ../src/wiringPi.cc:740:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PWM_MODE_BAL);
          ../src/wiringPi.cc:741:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PWM_MODE_MS);
          ../src/wiringPi.cc:744:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_MODEL_UNKNOWN);
          ../src/wiringPi.cc:745:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_MODEL_A);
          ../src/wiringPi.cc:746:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_MODEL_B);
          ../src/wiringPi.cc:747:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_MODEL_BP);
          ../src/wiringPi.cc:748:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_MODEL_CM);
          ../src/wiringPi.cc:749:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_MODEL_AP);
          ../src/wiringPi.cc:750:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_MODEL_2);
          ../src/wiringPi.cc:752:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_VERSION_UNKNOWN);
          ../src/wiringPi.cc:753:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_VERSION_1);
          ../src/wiringPi.cc:754:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_VERSION_1_1);
          ../src/wiringPi.cc:755:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_VERSION_1_2);
          ../src/wiringPi.cc:756:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_VERSION_2);
          ../src/wiringPi.cc:758:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_MAKER_UNKNOWN);
          ../src/wiringPi.cc:759:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_MAKER_EGOMAN);
          ../src/wiringPi.cc:760:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_MAKER_SONY);
          ../src/wiringPi.cc:761:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_MAKER_QISDA);
          ../src/wiringPi.cc:762:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(PI_MAKER_MBEST);
          ../src/addon.h:68:17: error: 'class v8::Object' has no member named 'ForceSet'
          ../src/wiringPi.cc:764:3: note: in expansion of macro 'EXPORT_CONSTANT_STRING_ARRAY'
             EXPORT_CONSTANT_STRING_ARRAY(PI_MODEL_NAMES, piModelNames, 7);
          ../src/wiringPi.cc:765:3: note: in expansion of macro 'EXPORT_CONSTANT_STRING_ARRAY'
             EXPORT_CONSTANT_STRING_ARRAY(PI_REVISION_NAMES, piRevisionNames, 5);
          ../src/wiringPi.cc:766:3: note: in expansion of macro 'EXPORT_CONSTANT_STRING_ARRAY'
             EXPORT_CONSTANT_STRING_ARRAY(PI_MAKER_NAMES, piMakerNames, 5);
          ../src/wiringPi.cc:769:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(FSEL_INPT);
          ../src/wiringPi.cc:770:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(FSEL_OUTP);
          ../src/wiringPi.cc:771:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(FSEL_ALT0);
          ../src/wiringPi.cc:772:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(FSEL_ALT1);
          ../src/wiringPi.cc:773:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(FSEL_ALT2);
          ../src/wiringPi.cc:774:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(FSEL_ALT3);
          ../src/wiringPi.cc:775:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(FSEL_ALT4);
          ../src/wiringPi.cc:776:3: note: in expansion of macro 'EXPORT_CONSTANT_INT'
             EXPORT_CONSTANT_INT(FSEL_ALT5);
          wiringPi.target.mk:142: recipe for target 'Release/obj.target/wiringPi/src/wiringPi.o' failed
          make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi/build'
          make: *** [Release/obj.target/wiringPi/src/wiringPi.o] Error 1
          gyp ERR! build error
          gyp ERR! stack Error: `make` failed with exit code: 2
          gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/lib/build.js:262:23)
          gyp ERR! stack     at ChildProcess.emit (events.js:189:13)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
          gyp ERR! System Linux 4.9.35-v7+
          gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/.bin/node-gyp" "rebuild" "--target=3.0.13" "--arch=arm" "--dist-url=https://atom.io/download/electron" "--build-from-source"
          gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/wiring-pi
          gyp ERR! node -v v10.15.3
          gyp ERR! node-gyp -v v3.8.0
          gyp ERR! not ok
          Failed with exit code: 1
          Error: gyp info it worked if it ends with ok
          gyp info spawn make
          thedoorsfanaticT T 2 Replies Last reply
            sdetweil
            well, ain’t that a doozy…
            not sure…
            • thedoorsfanaticT
              thedoorsfanatic @shgmongohh
              @shgmongohh
              I use MMM-PIR-Sensor and it works just fine on 2.7.1
              https://github.com/paviro/MMM-PIR-Sensor
              My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
                shgmongohh @thedoorsfanatic
                @thedoorsfanatic
                Thanks for the information. I uninstall and install MMM-PIR, but it doesn´t work.
                Regards,
                Sebastian
                • F
                  Fonfon
                  same problem with MMM-PIR-sensor and 2.7.1
                  i do that :
                  from the MMM-PIR-Sensor folder
                  then run it to force the epoll rebuild
                  Reply Quote 1
                    shgmongohh @Fonfon
                    @Fonfon
                    How do you force the epoll rebuild?
                    • F
                      Fonfon
                      @sdetweil said in MMM-PIR doesn´t turn off monitor since update MM 2.7:
                      @sdetweil give the solution
                        sdetweil @Fonfon
                        @Fonfon did give the solution?
                        • F
                          Fonfon @sdetweil
                          then
                          i do that but not in my MMM-PIR folder but in my MMM-PIR-Sensor folder
                            sdetweil @Fonfon
                            @Fonfon and all is good?
                            F 1 Reply Last reply
                            • F
                              Fonfon @sdetweil
                              @sdetweil for me yes
                              • T
                                toucherts @shgmongohh
                                @shgmongohh did you fix it ? TutuApp Adam4adam AppValley
                                  shgmongohh
                                  I get a failure message and I don´t know, how to fix it. npm audit fix doesnt work.
                                  pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install electron-rebuild
                                  + electron-rebuild@1.8.4
                                  updated 1 package and audited 301 packages in 17.922s
                                  found 1 high severity vulnerability
                                    run `npm audit fix` to fix them, or `npm audit` for details
                                  pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm audit
                                                         === npm audit security report ===
        Manual Review
                                               Some vulnerabilities require your attention to resolve
                                            Visit https://go.npm.me/audit-guide for additional guidance
                                    High            Arbitrary File Overwrite
                                    Package         tar
                                    Patched in      >=4.4.2
                                    Dependency of   electron-rebuild [dev]
                                    Path            electron-rebuild > node-gyp > tar
                                    More info       https://nodesecurity.io/advisories/803
                                  found 1 high severity vulnerability in 301 scanned packages
                                    1 vulnerability requires manual review. See the full report for details.
                                  • D
                                    djay07
                                    I did the recommended above, but it’s still just nothing happening. Any further ideas?
                                    I have a RCWL-0516 connected right now and a small python script which shows me it’s activity. but the module won’t shutdown the screen after minutes without motion (delay set to 10 secs).
                                    Edit:
                                    Maybe i should add:
                                    I tried this with MMM-PIR -> interface not starting, error:
                                    WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR/node_helper.js:11:18)
                                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR/node_helper.js:67:3)
                                        at Module._compile (internal/modules/cjs/loader.js:711:30)
                                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                                        at Module.load (internal/modules/cjs/loader.js:620:32)
                                        at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                                        at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                                        at Module.require (internal/modules/cjs/loader.js:658:17)
                                        at require (internal/modules/cjs/helpers.js:20:18)
                                        at loadModule (/home/pi/MagicMirror/js/app.js:127:17)
                                    App threw an error during load
                                    And MMM-PIR-Sensor is not reacting at all.
                                      sdetweil @djay07
                                      @djay07 after you did the git pull update, did you do npm install in the MagicMirror folder
                                      AND every module that has a package.json file???
                                      you must
                                      D 1 Reply Last reply
                                      • D
                                        djay07 @sdetweil
                                        morning,
                                        well i didn’t do it in every single subfolder where a package.json is placed, since i didn’t expect this to be necessary.
                                        I did:
                                        • git pull
                                        • in the module folder “npm install”
                                        • npm install electron-rebuild
                                        • ./node_modules/.bin/electron-rebuild
                                        the result is the above.
                                        Currently i solved it with external scripts running in system.d, but if you tell me i need to run “npm install” in each folder with a package.json, i would give it a try, just to report back.
                                        • L
                                          lxne Project Sponsor
                                          @djay07 Hi, have you been able to solve the MMM-PIR problem? I am stuck with the same thing.
                                          • F
                                            FruityBebbles @lxne
                                            @lxne @djay07 Same…
