    Even a simple node_help.js example does not run.
    13 Posts 2 Posters 4.0k Views 2 Watching
    • E Offline
      emrhssla
      MMM-Testpython
      var Testpythons;
      Module.register("MMM-Testpython", {
          defaults: {},
          start: function (){
              Testpythons = this;
        getDom: function() {
          var element = document.createElement("div")
          element.className = "myContent"
          element.id="divid"
          element.innerHTML = "Hello, World!!! " + this.config.foo
          var subElement = document.createElement("p")
          subElement.innerHTML = "Click"
          subElement.id = "clickid"
          element.appendChild(subElement)
          return element
        notificationReceived: function(notification, payload, sender) {
          switch(notification) {
            case "DOM_OBJECTS_CREATED":
            var elem = document.getElementById("clickid")
            elem.addEventListener("click", () => {
              Testpythons.sendSocketNotification("TEST")
              console.log("hello~hello~hello~hello~hello~hello~hello~hello~hello~hello~")
              elem.innerHTML = "click success"
              break
      node_helper.js
      var NodeHelper = require("node_helper");
      var {PythonShell} = require('python-shell');
        start: function() {},
            case "TEST":
              console.log("notification : " + notification)
              this.sendSocketNotification("I_DID")
              break
      The notification I_DID in node_helper.js was well communicated and executed. However, the console in node_helper.js is not output…
      What is the problem?
          Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
        sdetweil
        @emrhssla said in Even a simple node_help.js example does not run.:
        as I posted in the other topic, the node_helper content would be displayed in the terminal window
        where u started MM…
        also
        Log.log will not work in node helper. that is only available in the module.js
          sdetweil
          also, you need to install the python-shell component…
          need a package.json file
            "name": "MMM-Testpython",
            "description": "sample",
            "version": "0.0.1",
            "dependencies": {
              "python-shell": "latest"
          and then run
          npm install
          in the module folder
          the updated node_helper.js is
              console.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
          and produces this message in the terminal window, when the UI component is clicked
          MMM-Testpython received a socket notification: TEST - Payload: [object Object]
          E 2 Replies Last reply Reply Quote 0
          • E Offline
            emrhssla @sdetweil
            Is it normal for these errors to occur?
            /modules/MMM-Testpython/package.json
            • E Offline
              emrhssla @sdetweil
              @sdetweil said in Even a simple node_help.js example does not run.:
              //var {PythonShell} = require('python-shell');
              omg…
                sdetweil @emrhssla
                @emrhssla sorry, I had a name of “sample” when I did it. I guess the - is not allowed
                  sdetweil @emrhssla
                  @emrhssla that log is only from the module file. Not node_helper
                  • E Offline
                    emrhssla @sdetweil
                      "name": "MMMTestpython",
                      "description": "samples",
                      "version": "0.0.1",
                      "dependencies": {
                    Do I have to change it like this and install it again? npm install
                      sdetweil @emrhssla
                      @emrhssla I don’t understand… mine worked perfectly
                      package.json
                        "keywords": [
                          "   none"
                        "version": "0.0.1",
                        "dependencies": {
                      /MagicMirror/modules/MMM-Testpython$ npm install
                      npm WARN MMM-Testpython@0.0.1 No repository field.
                      npm WARN MMM-Testpython@0.0.1 No license field.
                      added 1 package from 1 contributor and audited 1 package in 0.821s
                      found 0 vulnerabilities
                      odroid@odroid:~/MagicMirror/modules/MMM-Testpython$
                      what version of npm do you have
                      npm -v
                      • E Offline
                        emrhssla @sdetweil
                        This post is deleted!
                          sdetweil @emrhssla
                          @emrhssla no…
                          mine is uppercase… oh well… anyhow u got it…
                          same npm version
                          • E Offline
                            emrhssla @sdetweil
                            omg…
                              sdetweil
                              Looks like your system doesn’t have python installed.
