    Installation of Magicmirror failed!
    2 Posts 2 Posters 935 Views 1 Watching
    • T Offline
      ThePierce
      So today i bought myself a new SD card because the old one is faulty :(
      After a fresh install of rasbian i tried to install MagicMirror using either the automatic install or the manual install.
      Unfortunatly after the command npm install && npm start i receive the following error:
      npm ERR! Unexpected end of JSON input while parsing near ‘…“eslint”:"./bin/eslin’
      npm ERR! /home/pi/.npm/_logs/2019-04-14T14_27_41_163Z-debug.log
      anyone had this issue? if so, what is the solution?
      Tnx in advance,
      ThePierce
        bhepler Module Developer
        First, please use the markdown features of the board when posting errors & code.
        Second, what version of Node and npm are you running?
        npm -v
        node -v
