    Camera capture cannot be performed on the Magic Mirror.
    5 Posts 3 Posters 2.2k Views 3 Watching
    • E Offline
      emrhssla
      I installed openv and python etc in the raspberry pie for camera capture.
      So I executed a simple Python code.
      test.py:
      import cv2
      cap = cv2.VideoCapture(0)
      ret, frame = cap.read()
      cv2.imwrite('chan.jpg',frame)
      cap.release()
      cv2.destroyAllWindows()
      print("1")
      Successfully 1(print(“1”) in test.py) was printed and the picture was saved on pi/Desktop.
      Then, I deleted the pi/Desktop/chan.jpg.
      However, we tried to run test.py with MagicMirror, but failed.
      The code for node_helper.js to run test.py is as follows.
      var NodeHelper = require("node_helper");
      var {PythonShell} = require('python-shell');
      var socketTestpython;
        start: function() {
          socketTestpython=this;
          console.log(this.name+"node_helper started")
          switch(notification) {
            case "TEST":
              console.log("notification : " + notification)
      	    PythonShell.run('/home/pi/Desktop/test.py', null, function (err, result) {
                  if (err) throw err;
                  console.log(result);
                  socketTestpython.sendSocketNotification("I_DID",result);
              break
      ‘1’ was successfully outputed on the console as follows:
      But as you can see in the image, there is no capture picture file on the desktop.
      What is the problem?
      I didn’t do anything on npm install about openv.
      Is there anything I should install in the magic mirror?
      For example, should I do npm install opencv4nodejs?
        sdetweil
        @emrhssla said in Camera capture cannot be performed on the Magic Mirror.:
        cv2.imwrite(‘chan.jpg’,frame)
        i agree with sean… u need to be specific in your python script WHERE u write the file… here it defaults to the current directory at the time (which is NOT where the script is located)
        maybe like this
        cv2.imwrite('/home/pi/Desktop/chan.jpg',frame)
        E 1 Reply Last reply Reply Quote 1
        • ? Offline
          A Former User @emrhssla
          @emrhssla
          Your image might be saved in MagicMirror directory. Have you checked?
            sdetweil
            maybe like this
            • E Offline
              emrhssla @sdetweil
              @sdetweil thank you!
              • E Offline
                emrhssla
                @Sean thank you!
